    Atom Pymakr Serialport.node
    pymakratom
    35 Posts 12 Posters 15.1k Views 12 Watching
      ssmith
      Getting the following after my PC rebooted and Atom updated to 1.19. Any ideas? I've treid all the suggestions I could find in various posts. Running on Windows 10 and same issue on 2 different PCs.
      [Enter steps to reproduce:]
      1. ...
      2. ...
      Atom: 1.19.0 x64
      Electron: 1.6.9
      OS: Microsoft Windows 10 Pro
      Thrown From: Pymakr package 1.0.3
      Stack Trace
      Failed to load the Pymakr package
      At The module '\\?\C:\Users\Steve\.atom\packages\Pymakr\build\Release\serialport.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 49. This version of Node.js requires
      NODE_MODULE_VERSION 53. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or`npm install`).
      Error: The module '\\?\C:\Users\Steve\.atom\packages\Pymakr\build\Release\serialport.node'
          at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
          at Object.Module._extensions..node (module.js:598:18)
          at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
          at Module.load (module.js:488:32)
          at tryModuleLoad (module.js:447:12)
          at Function.Module._load (module.js:439:3)
          at Module.require (~/AppData/Local/atom/app-1.19.0/resources/app/static/index.js:47:45)
          at require (~/AppData/Local/atom/app-1.19.0/resources/app/src/native-compile-cache.js:66:33)
          at bindings (/packages/Pymakr/node_modules/bindings/bindings.js:76:44)
          at /packages/Pymakr/lib/connections/serialport-linux/lib/bindings.js:3:35)
          at /packages/Pymakr/lib/connections/serialport-linux/lib/bindings.js:36:3)
          at Module.get_Module._compile (~/AppData/Local/atom/app-1.19.0/resources/app/src/native-compile-cache.js:106:36)
          at Object.value [as .js] (~/AppData/Local/atom/app-1.19.0/resources/app/src/compile-cache.js:239:29)
          at /packages/Pymakr/lib/connections/serialport-linux/lib/serialport.js:12:25)
          at /packages/Pymakr/lib/connections/serialport-linux/lib/serialport.js:476:3)
          at /packages/pymakr/lib/connections/pyserial.js:20:18)
          at /packages/pymakr/lib/connections/pyserial.js:26:30)
      Commands
      Non-Core Packages
      node_modules undefined
      Pymakr 1.0.3
      • RobTuDelftR Offline
        RobTuDelft
        @ssmith What happens if you re-install the module?
        Without data you're just another person with an opinion.
        Hackster | About me
          jojo
          I also encounter the same issue.
          I already tried to reinstall the pymakr plugin and even uninstall Atom, download the latest version and reinstall it, but without any luck so far (I'm on Windows 10).
          If someone has a solution, that would be great!
            duffo64
            I also was having this error with atom 1.19
            Uninstalling Atom itself is not enough. You should even delete the .atom folder with preferences and packages, and then reinstall (I'm on a Mac, tho').
            /Claudio
              jojo
              I forgot to mention that, but I did remove the .atom folder after uninstalling Atom and it did not change anything.
              RobTuDelftR 1 Reply Last reply Reply Quote 0
                RobTuDelft @jojo
                @jojo Can you try npm rb from within the module directory?
                Hackster | About me
                  jojo
                  @RobTuDelft
                  I tried that (well with apm rebuild instead of npm rb), but I still get this error:
                  The module '\\?\C:\Users\Johan\.atom\packages\Pymakr\precompiles\serialport-win\build\Release\serialport.node'
                    RobTuDelft @jojo
                    @jojo maybe go to the package.json file and add "buildDependenciesFromSource": true under the build property and run the command again.
                    Hackster | About me
                    P J 2 Replies Last reply Reply Quote 0
                      politick
                      Same problem here. This morning was my first time installation on that laptop, Win10. I actually tried VSCode first and that failed but with very little error information. Atom was my backup plan, but it failed also with at least much more information. I've updated Java and even JDK SE 8 just in case.
                        politick @RobTuDelft
                        @RobTuDelft said in Atom Pymakr Serialport.node:
                        Which package.json ?
                        .atom\packages\Pymakr\package.json
                        .atom\packages\Pymakr\precompiles\serialport-win\package.json
                        Under what scope is the "build property" ?
                        Here's my serialport-win\package.json
                        BTW, this path does not exist on my laptop: C:\Users\devel\Projects\pymakr-atom
                        "_args": [
                        "raw": "serialport@^4.0.7",
                        "scope": null,
                        "escapedName": "serialport",
                        "name": "serialport",
                        "rawSpec": "^4.0.7",
                        "spec": ">=4.0.7 <5.0.0",
                        "type": "range"
                        "C:\Users\devel\Projects\pymakr-atom"
                        "_from": "serialport@>=4.0.7 <5.0.0",
                        "_id": "serialport@4.0.7",
                        "_inCache": true,
                        "_location": "/serialport",
                        "_nodeVersion": "0.12.7",
                        "_npmOperationalInternal": {
                        "host": "packages-12-west.internal.npmjs.com",
                        "tmp": "tmp/serialport-4.0.7.tgz_1481518569217_0.2832766058854759"
                        "_npmUser": {
                        "name": "reconbot",
                        "email": "wizard@roborooter.com"
                        "_npmVersion": "2.15.6",
                        "_phantomChildren": {
                        "commander": "2.10.0"
                        "_requested": {
                        "scope": null,
                        "type": "range"
                        "_requiredBy": [
                        "#USER",
                        "_resolved": "https://registry.npmjs.org/serialport/-/serialport-4.0.7.tgz",
                        "_shasum": "421c618a8a612bd40cfa461b4a46154daf2229a5",
                        "_shrinkwrap": null,
                        "_spec": "serialport@^4.0.7",
                        "_where": "C:\Users\devel\Projects\pymakr-atom",
                        "author": {
                        "name": "Chris Williams",
                        "email": "voodootikigod@gmail.com",
                        "url": "http://www.voodootikigod.com"
                        "bin": {
                        "serialport-list": "./bin/serialport-list.js",
                        "serialport-term": "./bin/serialport-terminal.js"
                        "binary": {
                        "module_name": "serialport",
                        "module_path": "build/{configuration}/",
                        "host": "https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7"
                        "bugs": {
                        "url": "https://github.com/EmergingTechnologyAdvisors/node-serialport/issues"
                        "bundleDependencies": [
                        "node-pre-gyp"
                        "dependencies": {
                        "bindings": "1.2.1",
                        "commander": "^2.9.0",
                        "debug": "^2.3.2",
                        "lie": "^3.1.0",
                        "nan": "^2.4.0",
                        "node-pre-gyp": "^0.6.32",
                        "object.assign": "^4.0.3"
                        "description": "Node.js package to access serial ports. Welcome your robotic javascript overlords. Better yet, program them!",
                        "devDependencies": {
                        "chai": "^3.5.0",
                        "chai-subset": "^1.2.2",
                        "coveralls": "^2.11.9",
                        "eslint-config-standard": "^5.1.0",
                        "eslint-plugin-promise": "^1.1.0",
                        "eslint-plugin-standard": "^1.3.2",
                        "grunt": "^1.0.0",
                        "grunt-mocha-test": "^0.12.7",
                        "gruntify-eslint": "^2.0.0",
                        "mocha": "^2.4.5",
                        "node-pre-gyp-github": "^1.1.2",
                        "nyc": "^6.4.4",
                        "sandboxed-module": "^2.0.3",
                        "sinon": "^1.17.3",
                        "sinon-chai": "^2.8.0"
                        "directories": {},
                        "dist": {
                        "shasum": "421c618a8a612bd40cfa461b4a46154daf2229a5",
                        "tarball": "https://registry.npmjs.org/serialport/-/serialport-4.0.7.tgz"
                        "engines": {
                        "node": ">= 0.10.0"
                        "gitHead": "4a2a3cfae7ecba4e22e9c6d4cf7dfb7ec64324f6",
                        "gypfile": true,
                        "homepage": "https://github.com/EmergingTechnologyAdvisors/node-serialport#readme",
                        "keywords": [
                        "serialport",
                        "johnny-five",
                        "serial port",
                        "hardware",
                        "iot",
                        "nodebots"
                        "license": "MIT",
                        "main": "./lib/serialport",
                        "maintainers": [
                        "name": "jjrosent",
                        "email": "jakerosenthal@gmail.com"
                        "name": "reconbot",
                        "name": "voodootikigod",
                        "optionalDependencies": {},
                        "readme": "ERROR: No README data found!",
                        "repository": {
                        "type": "git",
                        "url": "git://github.com/EmergingTechnologyAdvisors/node-serialport.git"
                        "scripts": {
                        "coverage": "nyc report --reporter=text-lcov | coveralls",
                        "grunt": "grunt",
                        "gyp-rebuild": "node-gyp rebuild",
                        "install": "node-pre-gyp install --fallback-to-build",
                        "integration": "mocha test/arduinoTest/integration.js test/integration-lite.js",
                        "lint": "grunt --verbose lint",
                        "rebuild-all": "npm rebuild && node-gyp rebuild",
                        "stress": "mocha --no-timeouts test/arduinoTest/stress.js",
                        "test": "nyc grunt --verbose test",
                        "valgrind": "valgrind --leak-check=full --show-possibly-lost=no node --expose-gc --trace-gc node_modules/.bin/grunt test"
                        "version": "4.0.7"
                        • U Offline
                          urblau
                          Got The Same Problem! Reinstalled Atom 1.18. Theres is a Problem with pymakr and Atom 1.19!!!
                          P 1 Reply Last reply Reply Quote 1
                            jojo @RobTuDelft
                            I just tried that, but without any success. Any other idea? :)
                              RobTuDelft @jojo
                              @jojo What do you get when you remove the node-modules folder from the Pymakr package and then edit package.json to use install-win for the install procedure. Then edit install-win.js with your own path prefix (line 21) and run apm install again in the Pymakr folder?
                              My plugin is located here: C:\Users\robbr\.atom\packages\Pymakr
                              Hackster | About me
                                jojo @RobTuDelft
                                I am not quite sure how to do that, can you tell me what I should modify in that file?
                                • B Offline
                                  balibo
                                    ssmith
                                    It seems everyone is not addressing the message that things were compiled with the wrong version.
                                      politick @urblau
                                      @urblau Yes "Downgrading from Atom v1.19 to Atom v1.18" did fix my problem.
                                      but @ssmith is also right that the core issue is not resolved and Pymakr should be updated to be compatible with 1.19, but that is beyond what I need at the moment. I just need a IDE/platform that works.
                                      Thx! Martin Politick August 2017.
                                        RobTuDelft @ssmith
                                        @ssmith In install-win.js there is this command electron-rebuild -f -w serialport -v 1.3.13 which should recompile the serialport library. However it did not work for me at least. If you find something that works you can post it here https://github.com/pycom/pymakr-atom/issues/1
                                        Hackster | About me
                                          jojo @balibo
                                          @balibo
                                          Interesting article for those wanting to code using JavaScript, but I fail to see how this can help solving this problem.
                                            jojo @politick
                                            @politick
                                            I guess I will do the same and wait until a new version of the plugin is released before upgrading to Atom 1.19.
                                            Thanks everyone for your help and suggestions.
                                            • 1
                                            • 2
                                            • 1 / 2
