    LoPy with 3.3V direct powering fails to start.
    lopypowerfault3v3issues
    24 Posts 5 Posters 10.3k Views 6 Watching
      jmarcelino @robert-hh
      @robert-hh
      Yes I noticed that when I pasted the text here, already let them know :-) Thanks.
      • cocoaC Offline
        cocoa @jmarcelino
        @jmarcelino @robert-hh @ssmith
        Thanks for help to solve this issue.
          jcaron @jmarcelino
          Isn't this the opposite of what what stated here:
          https://forum.pycom.io/topic/1022/root-causes-of-high-deep-sleep-current
          Workaround:
          Power the board via the 3V3 pin using a stable 3V3 supply that is able to deliver at least 400mA. This lowers the deep-sleep current to around 2.5mA.
          Also, it's unclear to me what the setup on the Pysense/Pytrack actually is? Is the Pysense/Pytrack sending power to the module via 5V, and then receiving 3V3 back from it (which I suppose only goes to the 3V3_Pymodule pin)? Someone I had thought the module was powered by the Pysense/Pytrack via the 3V3 pin, but that's probably incorrect.
            jmarcelino @jcaron
            @jcaron
            Not completely the opposite, it's still more efficient to use a regulated 3.3V supply (low voltage forces the onboard regulator into bypass ECO mode)
            But it needs to be updated to reflect that 3.3V should be applied to the 5V/VIN pin.
            Yes, all the various shields implementing deep sleep control the *py board's 5V rail
            • 1
            • 2
            • 2 / 2
