    Pymark plugin for VS Code
    pymakr
    3 Posts 2 Posters 1.4k Views 2 Watching
      pchirouze
      I try to install Pymakr plugin for VS Code, but I have a trouble. The install seems good but I have a repeated error : execvp(3) failed : No such file or directory and Terminal process closed with error 1. I work on Ubuntu 16.04.3 LTS
      Please someone can help me thanks
      Patrice.
      • R Offline
        reader-uk
        I had the same issue. Make sure you also have node.js installed. Node.js framework is required for the pymkr plugin to successfully work.
        https://nodejs.org/en/download/
          pchirouze @reader-uk
          @reader-uk
          Thanks for your help, nodejs was not installed, but vs code don't say it !
