    How to set a specific IP Address in boot.py
    lopystatic ip
    1 Posts 1 Posters 586 Views 1 Watching
      simonjcarr
      I have added the following code to my boot.py file and it works fine, however my board gets a dynamic IP address from my router DHCP server.
      How can I change the code to set a static IP Address.
      # boop.py
      known_nets = [('***********', '***********')] # change this line to match your WiFi settings
      import os
      uart = machine.UART(0, 115200) # disable these two lines if you don't want serial access
      os.dupterm(uart)
      if machine.reset_cause() != machine.SOFT_RESET: # needed to avoid losing connection after a soft reboot
          from network import WLAN
          wl = WLAN()
          # save the default ssid and auth
          original_ssid = wl.ssid()
          original_auth = wl.auth()
          wl.mode(WLAN.STA)
          available_nets = wl.scan()
          nets = frozenset([e.ssid for e in available_nets])
          known_nets_names = frozenset([e[0] for e in known_nets])
          net_to_use = list(nets & known_nets_names)
          try:
              net_to_use = net_to_use[0]
              pwd = dict(known_nets)[net_to_use]
              sec = [e.sec for e in available_nets if e.ssid == net_to_use][0]
              wl.connect(net_to_use, (sec, pwd), timeout=10000)
          except:
              wl.init(mode=WLAN.AP, ssid=original_ssid, auth=original_auth, channel=6, antenna=WLAN.INT_ANT)
