    Touch pin functionality
    lopytouch
    9 Posts 5 Posters 3.0k Views 7 Watching
    • M Offline
      mahe
      What is the status and plan for the touch functionality? On the pin out it says to attach a 10 nF cap to enable the touch pin function, but I can't find any documentation on this anywhere. The only thing I can find in the Forum is someone saying that this is NOT possible (if so; why is it on the pin out?)
      Anyone with any experience?
      1 Reply Last reply Reply Quote 4
      • M Offline
        mahe
        No one from Pycom with a comment on this?
        • sebS Offline
          seb
          @mahe Apologies about the delayed response. I'm afraid this functionality of the ESP32 has not yet been exposed in micropython. It's on our to-do list but I can't promise a date when it will be available. You can access the capacitive touch functionality if you program the modules directly in C though.
          I hope this answers your query,
          Seb
          M 1 Reply Last reply Reply Quote 1
          • M Offline
            mahe @seb
            @seb Thanks! Sorry if I missed it, but is there any documentation on how to program the modules in C? As I understand it, I can use both my MicroPython modules and C in combination right ?
            As you can probably sense I am not a hardcore coder, so I need to start a bit from scratch. :)
            Thanks!
              jmarcelino @mahe
              @mahe
              There isn’t an easy guide yet but essentialy you can grab the C source code from https://github.com/pycom/pycom-micropython-sigfox and change it to suit you needs.
              Look into https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/README.md to find out how to build the firmware with your changes.
              If you look in the esp32/mods folder you can see how modules you use are implemented.
              • M Offline
                mahe @jmarcelino
                @jmarcelino Thanks, I'll try to look in to it.. Your 2nd links is not working though. :)
                  jmarcelino @mahe
                  @mahe
                  Fixed :)
                  • M Offline
                    Miika
                    Hi pycom people,
                    What is the current status with the touch sensing?
                    Would it be a big job to bring in the changes from here:
                    https://github.com/micropython/micropython-esp32/compare/master...nickzoic:esp32-touchpad
                    -Miika
                      throwaway
                      Bump.
                      Second vote for importing what's already in the mainline tree: https://github.com/micropython/micropython/blob/v1.9.4/ports/esp32/machine_touchpad.c
                      (it must be quite a lot of work for Pycom to maintain their own fork of MicroPython.. not to mention how the MicroPython world is starting to get a bit fragmented with all the forks now)
