    MQTT with 2 subscribes
    mqtt
    16 Posts 3 Posters 3.5k Views 3 Watching
      luc hanneuse
      I'm new to micropython. I've taken several examples on this forum, assemble them and succeed to subscribe to 2 differents mqtt topics. But how can I put the differnts message in 2 variables like sensor21 and sensor31 ?
      from mqtt import MQTTClient
      def sub_cb(topic, msg):
         print(msg)
      wlan = WLAN(mode=WLAN.STA)
      wlan.connect("wifi", auth=(WLAN.WPA2, "pass"), timeout=5000)
      while not wlan.isconnected():
          machine.idle()
      print("Connected to Wifi\n")
      client = MQTTClient("device_id", "192.168.0.20",user="pi", password="raspberry", port=1883)
      client.set_callback(sub_cb)
      client.connect()
      wifiaddress = ((str(wlan.ifconfig()[:1]))[2:])[:-3]
      client.publish(topic="lopy/ip", msg=wifiaddress)
      client.subscribe(topic="pi/sensor21/temperature")
      client.subscribe(topic="pi/sensor31/temperature")
      def t3_publication(topic, msg):
          print (topic, ':', msg)
          #pycom.rgbled(0xff00)
      client.set_callback(t3_publication)
          client.check_msg()
        luc hanneuse @luc hanneuse
        @luc-hanneuse
        anyone ?
        L C 2 Replies Last reply Reply Quote 0
          livius @luc hanneuse
          @luc-hanneuse
          what is your output from
          print (topic, ':', msg)?
            luc hanneuse @livius
            @livius
            So it subscribes correctly to the 2 topics. But I can't succeed in putting each message in a different variable.
            Here is my output :
            b'pi/sensor21/temperature' : b'21.00'
            b'pi/sensor31/temperature' : b'25'
              @luc-hanneuse
              I've tried this, but I got an error message.
              one="pi/sensor21/temperature"
              two="pi/sensor31/temperature"
              client.subscribe(topic=one)
              client.subscribe(topic=two)
              def mytopic(topic, msg):
                  if topic == one:
                      b = (msg[0]-48)*10+(msg[1]-48)
                  if topic == two:
                      c = (msg[0]-48)*10+(msg[1]-48)
                  s.send(bytes([b,c]))
                  #print("Sigfox sent\n")
                @luc-hanneuse
                what is the error message?
                and to convert from text to number simply do
                v2=float(v)
                or if you need only integer part
                v2=int(float(v))
                  @livius
                  For the conversion, It doesn't work :
                  v2=float(v)
                  I've got an error
                  can't convert bytes to float
                  v2=int(v)
                  I've got an error
                  ValueError: invalid syntax for integer with base 10
                  For the previous code, the error is
                  NameError: local variable referenced before assignment
                    chumelnicu @luc hanneuse
                    @luc-hanneuse Try to pack that two data (temperatures ) in to json format and publising after to MQTT broker
                      luc hanneuse @chumelnicu
                      @chumelnicu
                      It comes from different devices publishing each one their temperatures.
                        @luc-hanneuse said in MQTT with 2 subscribes:
                        You got this error because you do this
                        but in the code you have if variants and one of two "b" or "c" is unassigned
                        because you got 2 events - look how your code work by changing it to:
                            print("---start---")
                        is your output now like this?
                        "---start---"
                        "---start---"
                        you must put b and c outside of procedure
                        and inside test if both "b" and "c" have values and only then send it
                        but this can also cause minssing values if you got only "b" and once again "b" and next "c"
                        PS> about simple conversion i am writing about string, if it is a bytes then
                        you must catch it e.g. v2=float(str(v))
                        but your way should work also byte-48{0ascii} *10...
                        L 1 Reply Last reply Reply Quote 1
                          @livius said in MQTT with 2 subscribes:
                          How can I get those variable out of "def"?
                            msg_b= None
                            msg_c= None
                              global msg_b
                              global msg_c
                              luc hanneuse
                              Finally some improvements, thanks for your help.
                              I succeed to subscribe to several topics and get some results.
                              topic_sub=["pi/sensor21/temperature","pi/sensor40/temperature","pi/sensor02/temperature","pi/sensor12/in_01","pi/sensor12/out_01"]
                              topic_length=len(topic_sub)
                              val= [0,0,0,0,0] #should be a better way to create this array from topic_length
                              update = None # used if you want to send a signal without waiting the 800s cycle
                              for i in range(0, topic_length):
                                  client.subscribe(topic=topic_sub[i])
                                  global update
                                  global topic_length
                                  global topic_sub
                                  global val
                                  if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[0]):
                                      val[0] = (msg[0]-48)*10+(msg[1]-48) #ascii-to-int, to be improved
                                      val[0] = val[0] % 255 #sure to be a byte
                                  if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[1]):
                                      val[1] = (msg[0]-48)*10+(msg[1]-48) #ascii-to-int, to be improved
                                      val[1] = val[1] % 255 #sure to be a byte
                                  if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[2]):
                                      val[2] = (msg[0]-48)*10+(msg[1]-48) #ascii-to-int, to be improved
                                      val[2] = val[2] % 255 #sure to be a byte
                                  if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[3]):
                                      val[3] = (msg[0]-48) #ascii-to-int, to be improved
                                      update = 1
                                  if ubinascii.hexlify(topic) == ubinascii.hexlify(topic_sub[4]):
                                      val[4] = (msg[0]-48) #ascii-to-int, to be improved
                                      update = 1
                              client.set_callback(mytopic)
                              chrono = Timer.Chrono()
                              chrono.start()
                                  client.check_msg()
                                  if chrono.read()%60 < 5 and blink == 0:#just a blinking
                                      pycom.rgbled(0x0064)
                                      blink = 1
                                      print(".")
                                  if chrono.read()%60 > 5 and blink == 1:#just a blinking
                                      pycom.rgbled(0x0000)
                                      blink = 0
                                      print("-")
                                  if chrono.read() > 800:#wait 800s to avoid the sigfox message limit per day
                                      pycom.rgbled(0x007f00)
                                      s.send(bytes(val))
                                      chrono.reset()
                                  if update == 1:#send immediately if update is triger
                                      s.send(bytes(val))
                                      chrono.reset()
                                      update = 0
                              But the exact nature of the result of topic and message are unknown. Is it a string, a byte,... ?
                              Most conversions don't works. I've tried float() or int() and get errors
                              I still have errors, certainly related to that problem :
                              And I've got the following message error when
                              s.send(bytes(val))
                              #val is filled with the several message of the topics
                              The packet is correctly sent, but the program quit with the following error message OSError: [Errno 100] ENETDOWN
                              When I send the following code, I've no error
                              val = [1,2,3,4,5]
                              s.send(bytes(val))
                                unknown = None?
                                if yes than it mean no value at all.
                                And before send put print command to see what you tried to send
                                print(str(val))
                                s.send(bytes(val))
                                and if you still have problem show what was printed
                                  @livius
                                  The "topic" and "message" variables are created by the mqtt library.
                                  And yes, those variables don't react like string, byte,... most of the variables conversion don't work. That's why I called them "unknown".
                                  I've already print them, but that doesn't help to clarify the type of variable.
                                    @luc-hanneuse
                                    first you can try to test if it is None
                                    if v==None:
                                    and also you can test for type by:
                                    type(v)
