Pysense pressure/Altitude odd readings
  • Hello,
    As I tried to read both the altitude and the pressure from the Pysense, I notice these are not correct.
    Just the pressure reads:
    which is plausable at the moment.
    Just the height: 0_1508186074559_Image 2.PNG
    which is totally wrong (I know I'm in the Netherlands, but it is not the underworld)
    Reading both ( altitude instantiated first) pressure plausible, hight just 25km off
    code: 0_1508186363126_Image 3a.PNG
    and last the other way around:
    Pressure is more then double the correct value, Altitude is back far below sealevel.
    My questions:
    Is it not possible to read both values this way?
    Do I have to correct the hight in some way (for that is wrong in all cases)?
    Kind regards,
    Peter
  • I found out that like below, the results are plausible.
    No clue why the above mentioned way does not work, but at least this is a workaround.
