boot.py iterpreted or precompiled?
  • Hi,
    i must know how boot,py work.
    I see that it is not interpreted line by line but as whole?
    e.g. boot.py
    # boot.py -- run on boot-up
    import os
    from machine import UART
    uart = UART(0, 115200)
    os.dupterm(uart)
    uart.write('start\n')
    some_not_existed()
    uart.write('end\n')
    i do not get output start if after it i got error
    why?
    The rgb led light up blue for few seconds.
    I supposed that python is interpreted line by line but here i see something different.
  • administrators
    @livius said in boot.py iterpreted or precompiled?:
    but with whole code you got nothing ont the uart
    I ran your code on my LoPy and I don't get any output after the two dhcp start lines.
    I guess this is a bug in the firmware that PyCom should look at though I'd argue they have bigger things to do right now. :)
  • i have fixed errors in my boot.py
    but i'm interested about your results on lopy with output by uart
    if it is like "interpreted" or like "precompiled" behavior
    put here result when you got time to test it :)
    PS> do you know if RTC(real time clock) work now in current firmware?
  • administrators
    P.S. did you test that my code?
    Sorry I'm busy with something else right now.
  • good point :)
  • administrators
    You could use a boot.py that just contains the code for the serial REPL and copy the rest of the code into a new file 'boot2.py'.
    Then after your WiPy has booted you can run execfile('boot2.py'). That should give you the proper error message for your code. Once you have tested your code and have confirmed it is working you can append the command execfile('boot2.py') to your boot.py file to have the code in boot2.py run automatically on boot.
    It would also be more convenient as you don't have to reset your board every time you make a small change to your code.
  • i tested today and for simple sample like above it work now
    but for my whole code it not work. Here is my boot.py
    import os
    os.dupterm(uart)
    print('przed dioda proc')
    def Dioda(kolor1, kolor2, czas1, czas2):
    	for i in range(10):
    		pycom.rgbled(kolor1)
    		time.sleep_ms(czas1)
    		pycom.rgbled(kolor2)
    		time.sleep_ms(czas2)
    print('przed lpad proc')
    def LPad(s, dl, znak):
    	for i in range(len(s), dl):
    		s = znak + s
    	return s
    print('przed lpad0 proc')
    def LPad0(s, dl):
    		s = '0' + s
    	return s
    print('za proc')
    fname='/flash/log_boot.txt'
    last_dt=time.ticks_ms()
    print('przed dioda')
    Dioda(0xff0000, 0x000000, 100, 50)
    print('przed open')
    jest = len([item for item in os.listdir() if 'log_boot.txt'==item])>0
    if jest:
    	f_log = open(fname, 'r+')
    	jest = not (os.stat(fname)[6]==0)
    	f_log = open(fname, 'w')
    try:
    	Dioda(0x00ff00, 0x000000, 100, 50)
    	f_log.seek(0,0)
    	if jest>0:
    		print('jest wiekszy')
    		Dioda(0x0000ff, 0x000000, 100, 50)
    		f_log.seek(0,0)
    		ile = int(f_log.readln())+1
    		f_log.seek(0,0)
    		f_log.write(LPad0(str(ile), 10)+''))
    		print('jest wiekszy zapis 2')
    		#467892
    		f_log.seek(20,2) #os.SEEK_SET os.SEEK_END
    		last_dt = int(f_log.readln())+time.ticks_ms()
    		f_log.write(LPad0(str(last_dt), 20) + '')
    		print('jest wiekszy zapis 3')
    		Dioda(0xff00ff, 0x000000, 100, 50)
    		print('brak lub pusty')
    		Dioda(0x666666, 0x000000, 100, 50)
    		f_log.write(LPad0('1', 10) + '')
    		last_dt = time.ticks_ms()
    		print('brak lub koniec')
    	f_log.close()
    except:
    	f_log.close()
    	raise
    print('--koniec--')
    if you remove all in "if" after line
    if jest>0:
    but before "else"
    then you got outputs on uart
    if you got something especially error in your lopy then i'am very interested
  • Thank you Xykon
    i must test this more to find what cuse problems
    i will try tommorow with fresh mind ;-)
  • administrators
    @livius Sorry only have a LoPy but this is what I get:
    ets Jun  8 2016 00:22:57
    configsip: 0, SPIWP:0x00
    mode:QIO, clock div:2
    load:0x3fff9010,len:8
    load:0x3fff9018,len:312
    load:0x40078000,len:2348
    ho 0 tail 12 room 4
    load:0x4009f000,len:1364
    entry 0x4009f2f8
    rtc v112 Sep 26 2016 22:32:10
    XTAL 40M
    frc2_timer_task_hdl:3ffda4a8, prio:22, stack:2048
    tcpip_task_hdlxxx : 3ffdec74, prio:18,stack:2048
    phy_version: 123, Sep 13 2016, 20:01:58, 0
    pp_task_hdl : 3ffdfe24, prio:23, stack:8192
    mode : softAP(24:0a:xx:xx:xx:xx)
    dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
    start
      File "boot.py", line 9, in <module>
    NameError: name 'some_not_existed' is not defined
    MicroPython d78a5a3 on 2016-11-05; LoPy with ESP32
  • have someone WiPy2 and can test this?
    import os
    os.dupterm(uart)
    print('start')
    some_not_existed()
    print('end')
  • i have changed all uart.write to print
    and the behavior is the same
    i do not see any output if error occure in some line
  • administrators
    print('test') would write test to the REPL
  • But print have parameter to which uart to write
    or it write only to 0?
  • administrators
    I did the same test on my LoPy and I can see the following:
    The rgb led lights up steady blue (which is to signal an error in boot.py).
    I can see the first uart.write succeed.
    It then throws an error message on the serial REPL:
      File "boot.py", line 31, in <module>
    It might be that in your case the write to the serial port collides with the REPL throwing the error message and that's why you don't see the output.
    I'll stand by my earlier comment not to write to the uart directly after you assigned the REPL to it.
  • why?
    if all work ok it write all to output
    but only if in any place in boot.py i have error it write nothing
    above code without "some_not_existed() " write to com output both start and end
  • administrators
    You shouldn't write to the uart directly once it's assigned to os.dupterm. Instead use print().
1 out of 16
