    Communication between a LoPy and several LoPys via LORA
    lopyloralopy to lopysrelaydata origin
    2 Posts 2 Posters 960 Views 2 Watching
      JeromeMaquoi
      I have two lopys that communicates via Lora and one of my lopy must act as a relay mast so it has to handle communication via Lora with several lopys, possibly at the same time. In fact, the relay LoPy has to be able to receive data from different LoPys and to know from which LoPy the data come. Can I do that if I start from the code below? How can I distinguish the origins of the data?
      from network import LoRa
      lora = LoRa(mode=LoRa.LORA, frequency=863000000)
      s.setblocking(False)
      rec = s.recv(1024) #reception of the data in bytes
      time.sleep(2)
      Thank you for your answers,
      Jérôme Maquoi
      rcolisteteR 1 Reply Last reply Reply Quote 0
      • rcolisteteR Offline
        rcolistete @JeromeMaquoi
        I suggest to use this Pycom LoRa-Mac nano-gateway to start with :
        LoPy Nano-Gateway Extended (Timeout and Retry)
        It was a development from the earlier version :
        LoPy Nano-Gateway
