    Measure Pulse width of PWM waveform
    lopypulsepulse counterpwmfrequency
    3 Posts 2 Posters 1.5k Views 2 Watching
    • shridattdudhatS Offline
      shridattdudhat
      We are trying to use nova dust sensor which gives a reading as pulse width with lopy.
      We wrote a simple code which is listed below to measure pulse width using pulses_get('P9', time).
      from machine import Pin
      from pycom import pulses_get
      from time import sleep_ms
      pin = Pin("G12", mode=Pin.IN)
      data = pulses_get(pin, 100)
      print(data)
      sleep_ms(100)
      in output.
      Does anybody try to measure pulse width with any pycom devices?
      Please provide sample code to measure the pulse width of PWM signal.
      Shridatt Dudhat
      Power Electronics Imagineer, INDIA
        robert-hh @shridattdudhat
        @shridattdudhat The data sheets I found tells about a pulse perion of 1004 ms. The timeout given in pulses get is µs, so it should be set to a value like 1200000. But since pulses_get uses the RMT unit of the ESP32, and AFAIK this uses 15 bit registers for a pulse width, the maximum pulse length it can detect is about 32 ms.
        Therefore you shoud use a simple count loop ad detect the pulse with yourself by reading the GPIO input level. Alternativly you could use the serial ourput of the Dust sensor and connect it to UART2 or UART3. That seems far more reliable.
          shridattdudhat
          @robert-hh said in Measure Pulse width of PWM waveform:
          UART2 or UART3
          hey, robert
          Thank you for reply,
          We will try UART for the same.
          Shridatt Dudhat
