Socket having to close and reopen
I have a Raspberry pie connected to 4 Lopy's over wifi, and a java tcp server program running on the rpi with sockets (with different port) for each lopy.
My problem is that I have to close the connection after sending a bytearray, and the repon it again when I need to send the next bytearray. The time it takes for it to reconnect to the socket is not really feasible for the system.
Is it supposed to work like this with sockets, or am I doing something wrong?The server code is here: https://github.com/ITU-PerCom-2017/10.-Coop-Predictive-Equipment-Maintenance/blob/master/java/src/TCPServer.java
And the lopy code is here:
from network import Bluetooth from network import WLAN import socket #from network import socket import pycom import time import machine import binascii from machine import Timer pycom.heartbeat(False) pycom.rgbled(0x000000) # turn off led lopyID = 4 # set this unique to each lopy print('started! lopy id: ', lopyID) #for breaking out of while(True) loops. Removed when program is finished chrono = Timer.Chrono() # chrono.start() wlan = WLAN(mode=WLAN.STA) nets = wlan.scan() pycom.rgbled(0x7f0770) time.sleep(0.5) pycom.rgbled(0x000000) # turn off led time.sleep(1) pycom.rgbled(0x7f0770) time.sleep(0.5) pycom.rgbled(0x000000) # turn off led time.sleep(1) pycom.rgbled(0x7f0770) time.sleep(0.5) pycom.rgbled(0x000000) # turn off led time.sleep(1) pycom.rgbled(0x7f0770) time.sleep(0.5) pycom.rgbled(0x000000) # turn off led time.sleep(1) pycom.rgbled(0x7f0000) # red #time.sleep(0.5) #pycom.rgbled(0x000000) # turn off led #time.sleep(1) pycom.rgbled(0x7f0000) for net in nets: # connect to rpi wifi if net.ssid == 'cooppifi': print('rpi found!') wlan.connect(net.ssid, auth=(net.sec, 'cooppifi2017'), timeout=4000) for _ in range(20): time.sleep(1) if wlan.isconnected(): print("connected to rpi") break print('.', end='') else: print("could not connect to wifi, resetting lopy...") machine.reset() bluetooth = Bluetooth() bluetooth.start_scan(-1) adv = None # bluetooth advertisementa time.sleep(2) def sendToSocket(beaconID, rssi): RSSIpositive = rssi * -1 #newData = beaconID + lopyID + RSSIpositive #newData = 255 s = socket.socket(socket.AF_INET, socket.SOCK_STREAM) s.connect(socket.getaddrinfo('10.42.0.1', 6792)[0][-1]) pycom.rgbled(0x007f00) time.sleep(0.5) pycom.rgbled(0x000000) # turn off led time.sleep(0.5) print('.') data = bytearray() #data.append(newData) data.append(lopyID) data.append(beaconID) data.append(RSSIpositive) print("sending to socket, binary: ", data, data[0]) #conv = binascii.hexlify(data) #print(conv, encoding='utf8') s.send(data) s.close() # b'f3bc0b6feb4c' # raw: b'\xf3\xbc\x0bo\xebL' # b'edbed48d0b87' # raw: b'\xed\xbe\xd4\x8d\x0b\x87 # b'c7c383eeaaa4' # raw? # b'cd87e6a38dc2' # raw? pycom.rgbled(0x007f00) # green while True: adv = bluetooth.get_adv() if adv != None: #print('!') #print('!!') macRaw = adv[0] # binary mac address macReal = binascii.hexlify(macRaw) # convert to hexadecimal if macReal == b'f3bc0b6feb4c': print('beacon A rssi: ', adv[3]) # adv[3] is rssi sendToSocket(beaconID = 1, rssi = adv[3]) elif macReal == b'edbed48d0b87': print('beacon B rssi: ', adv[3]) sendToSocket(beaconID = 2, rssi = adv[3]) elif macReal == b'c7c383eeaaa4': print('beacon C rssi: ', adv[3]) sendToSocket(beaconID = 3, rssi = adv[3]) elif macReal == b'cd87e6a38dc2': print('beacon D rssi: ', adv[3]) sendToSocket(beaconID = 4, rssi = adv[3]) # adv[3] #time.sleep(1) #lap = chrono.read() # for breaking out of loop (remove this part when program is finished) #if lap > 30: # print("breaking") # bluetooth.stop_scan() # break ```
@soren said in Socket having to close and reopen:
You close socket on server side then you must close it also on client side(it is closed already but..)
Question is what problem do you have with the code?
Is it working, if yes, do you ask if there is some better way?
