Configuration settings library
 Is there a library or method to store settings(preferably in json) that survives reboots.
 Haven't tried yet, but assume the file has to have an initial json string first?
 @misterlisty I'm not sure what you want me to say, other than the fact that you probably have a syntax error in your JSON file
 i get an error... syntax error in JSON
 @misterlisty You need to make an object instead of using it like a method, and not use keyed params. Example: from config import Config
 c = Config()
 c.get("existing_key")
 c.set("existing_key","whatever_value")
 c.save()
 from config import Config try:
 Config.set(key="here",value="there") #failes with function missing required positional argument #0
 Config.save()
 devname = Config.get("here")
 print("devname",devname)
 except Exception as e:
 print("config testfailed",e)
 Just use the json lib and open/write it manually. Something like this import json class Config: def __init__(self,filename="config.json"): self.filename = filename self.data = self.__read_file() def __read_file(self): with open(self.filename) as data: return json.load(data) def set(self,key,value): self.data[key] = value def get(self,key): return self.data[key] def save(self): with open(self.filename,'w') as f: f.write(json.dumps(self.data))
