    LoRaWAN join spreading factor
    lopylorawanjoinadr
    3 Posts 2 Posters 1.6k Views 2 Watching
      Aris
      Does anyone know what changes should be made to the source code of the firmware in order to hardcode SF12 during LoRaWAN join?
      Maybe the AlternateDatarate() in the MLME_JOIN should be replaced with DR_0?
      https://github.com/pycom/pycom-micropython-sigfox/blob/master/lib/lora/mac/LoRaMac.c#L4172
      Or maybe the define of MAX_JOIN_DATARATE should be 0 at https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/mods/modlora.c#L59
      Or something from line 1466 to 1479 https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/mods/modlora.c
        jmarcelino @Aris
        @aris
        Why are you trying to hardcode SF12 from the C side of things?
        You could just pass the dr option to LoRa.join()
        lora.join(activation, auth, * ,timeout=None, dr=None)
        just set dr to be your desired datarate. Check the docs page for more help:
        https://docs.pycom.io/chapter/firmwareapi/pycom/network/lora.html
          Aris
          I think you are right. I don't know how it was stuck in my mind that I could not change the join DR. Maybe by older topics of the forum.
          Thank you!
