LoPy stuck in Station(STA) Mode!
  • Hello All,
    I have connected my LoPy in Station mode and now it does not expose it's own Wi-Fi SSID(AP) anymore. The issue is much worse because the UART is not working as I cannot sync my programs using it. However, it is getting connected to COM port. REPL also not working. I was syncing my project using LoPy's WiFi which is now stuck in STA mode.
    I've tried resetting LoPy as well as Upgrading Firmware(1.10.0.b1) but didn't solve the issue. How can I get my LoPy back to AP mode?
    Also, how can I solve the COM port issue? I've also faced one error on my other LoPy which was "Guru Meditation Error"! Is that can be solved?
    Thank You,
    Devang
  • @livius Thanks a lot. Now both of my LoPy works in AP mode.
    com port issue is adressed and fix will be released in next firmware @daniel can say when.
    I hope it is very soon.
  • @devang-sharma
    start in safe boot mode (it disable processing your boot.py and main.py)
    https://docs.pycom.io/chapter/toolsandfeatures/bootmodes.html
Hello World?
Back Us On Kickstarter >
