    hmac on on lopy
    other
    5 Posts 2 Posters 1.5k Views 2 Watching
      this.wiederkehr
      Just came upon an issue with the micropython hmac library on pycom modules:
      https://github.com/micropython/micropython-lib/blob/master/hmac/hmac.py
      OSError: only one active hash operation is permitted at a time
      The problem is, that hmac lib does instantiate two hash objects at the same time (last two lines):
              if callable(digestmod):
                  self.digest_cons = digestmod
              elif isinstance(digestmod, str):
                  self.digest_cons = lambda d=b'': _hashlib.new(digestmod, d)
                  self.digest_cons = lambda d=b'': digestmod.new(d)
              self.outer = self.digest_cons()
              self.inner = self.digest_cons()
      Anyone already solved that? Otherwise I'll do ... :-)
      • M Offline
        martijns
        Running into the same problem here. Did you solve it yet? Would appreciate if you could share your solution.
          this.wiederkehr
          """HMAC (Keyed-Hashing for Message Authentication) Python module.
          Implements the HMAC algorithm as described by RFC 2104.
          import hashlib as _hashlib
          trans_5C = bytes((x ^ 0x5C) for x in range(256))
          trans_36 = bytes((x ^ 0x36) for x in range(256))
          def translate(d, t):
              return bytes(t[x] for x in d)
          # The size of the digests returned by HMAC depends on the underlying
          # hashing module used.  Use digest_size from the instance of HMAC instead.
          digest_size = None
          class HMAC:
              """RFC 2104 HMAC class.  Also complies with RFC 4231.
              This supports the API for Cryptographic Hash Functions (PEP 247).
              blocksize = 64  # 512-bit HMAC; can be changed in subclasses.
              def __init__(self, key, msg = None, digestmod = None):
                  """Create a new HMAC object.
                  key:       key for the keyed hash object.
                  msg:       Initial input for the hash, if provided.
                  digestmod: A module supporting PEP 247.  *OR*
                             A hashlib constructor returning a new hash object. *OR*
                             A hash name suitable for hashlib.new().
                             Defaults to hashlib.md5.
                             Implicit default to hashlib.md5 is deprecated and will be
                             removed in Python 3.6.
                  Note: key and msg must be a bytes or bytearray objects.
                  if not isinstance(key, (bytes, bytearray)):
                      raise TypeError("key: expected bytes or bytearray, but got %r" % type(key).__name__)
                  if digestmod is None:
                      raise Exception("HMAC() without an explicit digestmod argument "
                                     "is deprecated.")
                  self.digest_size = 32
                  self.block_size = 64
                  if len(key) > self.block_size:
                      raise Exception('key too long')
                  key = key + bytes(self.block_size - len(key))
                  self.inner.update(translate(key, trans_36))
                  self.outer_key_translated = translate(key, trans_5C)
                  if msg is not None:
                      self.update(msg)
              @property
              def name(self):
                  return "hmac-" + self.inner.name
              def update(self, msg):
                  """Update this hashing object with the string msg.
                  self.inner.update(msg)
              def digest(self):
                  """Return the hash value of this hashing object.
                  This returns a string containing 8-bit data.  The object is
                  not altered in any way by this function; you can continue
                  updating the object after calling this function.
                  inner_digest = self.inner.digest()
                  self.outer.update(self.outer_key_translated)
                  self.outer.update(inner_digest)
                  return self.outer.digest()
          def new(key, msg = None, digestmod = None):
              """Create a new hashing object and return it.
              key: The starting key for the hash.
              msg: if available, will immediately be hashed into the object's starting
              state.
              You can now feed arbitrary strings into the object using its update()
              method, and can ask for the hash value at any time by calling its digest()
              method.
              return HMAC(key, msg, digestmod)
            this.wiederkehr
            This code is 'works for me' not sure about the limitations anymore...
            Update: i think the limitation is that you can call digest only once.
            M 1 Reply Last reply Reply Quote 1
            • M Offline
              martijns @this.wiederkehr
              @this-wiederkehr
              Seems to work perfectly fine. Even calling it multiple times (from REPL at least) works. Thanks alot! Also for the quick response.
