    Connecting to Eduroam
    eduroamnano gatewaypython
    10 Posts 5 Posters 3.4k Views 5 Watching
      Dylan
      I have been trying to figure out how to connect to Eduroam on my nano-gateway and still having some trouble. I have used all the examples in the WLAN docs but I believe I need to change stuff in the main.py as well as the config.py. Was hoping there was something as straight forward as:
      WIFI_SSID = 'eduroam'
      WIFI_AUTH = 'username'
      WIFI_PASS = 'pass'
      But it doesn't seem to be the case.
      I've been searching for python examples but only found how to connect a Linux system. Eduroam is basically everywhere so I'm sure this answer will be well used.
      Cheers,
      Dylan
        jmarcelino @Dylan
        @dylan
        Eduroam is a WPA2 Enterprise network. You need to change the WLAN initialisation to it, see the Connecting with EAP-PEAP or EAP-TTLS example:
        https://docs.pycom.io/chapter/tutorials/all/wlan.html
        I think for Eduroam your username and the identity are your e-mail address. You shouldn't need to have the ca_certs option.
        As a quick test change line 207 in nanogateway.py (under _connect_to_wifi function) from
        self.wlan.connect(self.ssid, auth=(None, self.password))
        to:
        self.wlan.connect(ssid='eduoram', auth=(WLAN.WPA2_ENT, 'youremail', 'password'), identity='youremail')
        Of course in this replacing the placeholder fields your e-mail and password respectively.
        I not sure this will work as I've not used eduroam in a few years so any feedback would be appreciated.
        D franmanF 2 Replies Last reply Reply Quote 0
          Dylan @jmarcelino
          @jmarcelino thanks for the reply, I suspected it had something to do with the WPA2 Enterprise network just no idea how to implement it, cheers for the help. I am still having trouble with what placeholders to put in? I put the WPA2 Enterprise stuff (wlan.connect etc) into the config file, but I believe I need to change stuff in the main too, sorry for lack of explanation, gotta go out for a bit and wanted to get this post out.
            jmarcelino @Dylan
            @dylan
            You need to change nanogateway.py, changing config.py won’t do anything.
            For a quick test just put the values directly on the self.wlan.connect(...) call , if it works we’ll change it to pick them up from config.py
              Dylan @jmarcelino
              @jmarcelino I found where I made my mistake earlier, the password is case sensitive haha. Its connected and working well.
              Thanks for the help
              • franmanF Offline
                franman @jmarcelino
                @jmarcelino
                I have followed the section "Connecting with EAP-PEAP or EAP-TTLS" of https://docs.pycom.io/chapter/tutorials/all/wlan.html, and your comments @jmarcelino , but I can't connect my LoPy to Eduroam. Is it possible that the authentication method will be important? In my university the authentication method is EAP-MSCHAP-V2, and my question is: Is this method supported by LoPy?
                  livius @franman
                  @franman
                  How your connection looks like?
                  I suppose you do not provide any cert as it is not needed on client side for EAP-MSCHAP-V2
                  and are you sure that it is not PEAP-EAP-MSCHAPv2?
                  franmanF 1 Reply Last reply Reply Quote 0
                  • franmanF Offline
                    franman @livius
                    @livius I try connect with the following command:
                    wlan.connect(ssid="eduroam",auth=WLAN.WPA2_ENT,EDUROAM_USER,EDUROAM_PWD),identity=EDUROAM_IDENTITY,timeout=5000)
                    Where:
                    • EDUROAM_USER = my email address
                    • EDUROAM_PWD = my eduroam passwd
                    • and EDUROAM_IDENTITY = my email address too.
                    And yes, as the document to configure eduroam in my university says, the authentication mechanism is EAP-MSCHAP-V2.(an screenshot of the web, unfortunally in spanish, is attached)0_1513786973715_screenshot-eduroam.png
                      thomand1000
                      It seems as some of you got it to work. Can you please provide a short guide with some code that worked?
                        Dylan @thomand1000
                        @thomand1000 Unfortunately I didn't get it entirely fixed, the best theory is that the Eduroam has a UDP timeout feature, I did find a work around that has been working consistently, it gives a maximum of about 30 seconds downtime every 31minutes.
                        The few things I changed are in the nanogateway.py file for the gateway example:
                        After 1900 seconds the message "Failed to pull downlink packets from server" would occur so I put a machin.reset() in:
                        def _pull_data(self):
                            token = uos.urandom(2)
                            packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_DATA]) + ubinascii.unhexlify(self.id)
                            with self.udp_lock:
                                try:
                                    self.sock.sendto(packet, self.server_ip)
                                except Exception as ex:
                                    machine.reset()
                                    self._log('Failed to pull downlink packets from server: {}', ex)
                        And every 4-5th restart it would just not connect so I did a simple timer reset in the wifi connection:
                        def _connect_to_wifi(self):
                            count = 0
                            self.wlan.connect(ssid='eduroam', auth=(WLAN.WPA2_ENT, 'Username', 'Password'), identity='Username', timeout = 30)
                            while not self.wlan.isconnected():
                                utime.sleep(1)
                                count = count + 1
                                print(count)
                                if count >= 30:
                                    machine.reset()
                            self._log('WiFi connected to: {}', self.ssid)
                        Hopefully one day I'll be able to get the UDP timeout thing properly fixed, but they don't change things like this in a hurry for a student haha.
