    PyTrack GPS - MemoryError
    pytracklopymemoryerrorgps
    1 Posts 1 Posters 822 Views 1 Watching
    • B Offline
      bogd
      I'm trying to test the Pytrack GPS by using the sample code provided by Pycom. The problem is that the code keeps crashing after several reads (sometimes even after a single one!), with "memory allocation failed":
      RTC Set from NTP to UTC: (1970, 1, 1, 0, 3, 19, 594962, None)
      Adjusted from UTC to EST timezone (1970, 1, 1, 2, 3, 19, 3, 1)
      (None, None) - (1970, 1, 1, 0, 3, 49, 703270, None) - 37728
      File "<stdin>", line 36, in <module>
      File "/flash/lib/L76GNSS.py", line 56, in coordinates
      MemoryError: memory allocation failed, allocating 4064 bytes
      Unfortunately, I have no idea what to do in order to solve this issue. Can anyone help point me in the right direction?
      As far as I can tell, I'm not the only one experiencing the issue - see https://github.com/pycom/pycom-libraries/issues/35 . But that issue has been open for more than a month, and Pycom seems to be ignoring it...
      [ Edit: Looks like I should have searched better before posting - I just found a very similar post in the SiPy topic.
      https://forum.pycom.io/topic/2200/solved-sipy-pytrack-gps-example-simplified-to-basic-gps-only-fails-with-memoryerror
      I will try the fix recommended there, and see what happens... ]
