Configuration class
  • class Status(object):
         def __init__(self):
             self.__x = 2
        def getx(self):
            print("getx is read only")
            return self.__x
        def setx(self, val):
            print("setx is read only")
       x = property(getx, setx)
    print(Status.x)    #returns <PROPERTY>  what do i do with this
    Status.x=True
    print(Status.x)
    Status.x=False
    print(Status.x)
    Want to create a configution class that i can use to store config info but also have a setter/getter to add logic? Is the above correct?
  • @misterlisty Besides that setx() should store the value, the other way of doing that is with decorators:
        def __init__(self):
            self.__x = 2
        @property
        def x(self):
            return self.__x
        @x.setter
        def x(self, val):
            self.__x=val
    a=Status()
    print(a.x)
    a.x=1001
    print(a.x)
  • @misterlisty said in Configuration class:
    def init(self):
    self.__x = 2
    def getx(self):
        return self.__x
    Status.x=True
    print(Status.x)
    You are trying to access the CLASS property X, your code should be something like:
        def __init__(self):
            self.__x = 2
        def getx(self):
            return self.__x
    a = Status()
    print(a.x)
    a.x=True
    print(a.x)
