    Lopy and Matchx usage
    matchxgatewaylorawan server
    37 Posts 2 Posters 12.1k Views 2 Watching
    • M Offline
      misterlisty
      I have setup a Matchx Gateway and activated it. Now i want to use the example at https://docs.pycom.io/chapter/tutorials/lopy/lorawan-otaa.html but where do i get the app_eui and app_key from? Do i have to use TTN?
      from network import LoRa
      import binascii
      # Initialize LoRa in LORAWAN mode.
      # create an OTAA authentication parameters
      dev_eui = binascii.unhexlify('10 00 00 00 00 00 00 01'.replace(' ',''))
      app_eui = binascii.unhexlify('70 B3 D5 7E D0 00 81 BD'.replace(' ',''))
      app_key = binascii.unhexlify('77 E7 AE FA 56 67 78 3D 5C 2F 4A E0 B9 F2     E3 FC'.replace(' ',''))
      # join a network using OTAA (Over the Air Activation)
      # wait until the module has joined the network
      while not lora.has_joined():
              time.sleep(2.5)
              print('Not yet joined...')
      # create a LoRa socket
      # set the LoRaWAN data rate
      # make the socket blocking
      # (waits for the data to be sent and for the 2 receive windows to expire)
      s.setblocking(True)
      # send some data
      s.send(bytes([0x01, 0x02, 0x03]))
      # (because if there's no data received it will block forever...)
      s.setblocking(False)
      # get any data received (if any...)
      data = s.recv(64)
      print(data)
        jmarcelino @misterlisty
        @misterlisty
        Are you using MatchX’s own backend server? If so you to need to register a new device and get those values from there.
        • M Offline
          misterlisty
          Here is my matchx setup...
          J 2 Replies Last reply Reply Quote 0
            @misterlisty
            App is just short for Application, so use Application EUI and Application Key for app_eui and app_key respectively.
              @misterlisty
              Also to use the dev_eui you set you need to add it to the auth parameter like this:
              lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0)
              • M Offline
                misterlisty @jmarcelino
                @jmarcelino thank you, what about frequency? Do i have to set this? I'm in Austrlia.
                  @misterlisty
                  Yes for Australia you need to set it, what’s your channel plan on the MatchX?
                  • M Offline
                    ok..getting some activity now...but the code says it hasn't joined yet?
                      @misterlisty
                      At first sight that screenshot looks fine, you have an uplink (likely the join request) from the LoPy and then a downlink on 923.3Mhz which is the RX2 window so it should be the join accept reply.
                      Do you have any option to use the RX1 window instead? That would be preferrable. I haven't used MatchX backend in months.
                      The MatchX is also transmitting with some crazy power (30), try to have the nodes well apart otherwise the receiver on the LoPy will be overloaded.
                      If that doesn't help pos the exact macPayload for both uplink and downlinks - you need to expand fields so I can understand exactly what's being sent.
                      M 2 Replies Last reply Reply Quote 0
                      • M Offline
                        @jmarcelino Hope this helps :)
                        • M Offline
                          @jmarcelino I'm now trying to use BDP instead but i get no indication of connection from MtachX anymore..any suggestion?
                          Here is my code
                          import binascii
                          import struct
                          # lora = LoRa(mode=LoRa.LORAWAN, rx_iq=True, tx_power=14, power_mode=LoRa.ALWAYS_ON, public=True, tx_retries=1)
                          print("Lora send::-3")
                          print("DevEUI[",binascii.hexlify(lora.mac()).upper().decode('utf-8'),"]")
                          # dev_eui = binascii.unhexlify('70 B3 D5 49 97 E4 4C 6E'.replace(' ',''))
                          # app_eui = binascii.unhexlify('70 B3 D5 7E D0 00 81 BD'.replace(' ',''))
                          # app_key = binascii.unhexlify('77 E7 AE FA 56 67 78 3D 5C 2F 4A E0 B9 F2 E3 FC'.replace(' ',''))
                          # create an ABP authentication parameters
                          dev_eui = struct.unpack(">l", binascii.unhexlify('AE A7 4C 1B'.replace(' ','')))[0]
                          # dev_eui = binascii.unhexlify('AE A7 4C 1B'.replace(' ',''))
                          app_eui = binascii.unhexlify('39 7E 7F A3 AB 51 CB 3B 60 18 3C 85 E6 B5 56 D6'.replace(' ',''))
                          app_key = binascii.unhexlify('9A 92 D8 3B 94 D2 6C DF 03 84 EF D3 59 47 14 85'.replace(' ',''))
                          print("Lora send::-2")
                          # set the 3 default channels to the same frequency
                          lora.add_channel(0, frequency=915200000, dr_min=0, dr_max=4)
                          lora.add_channel(1, frequency=915200000, dr_min=0, dr_max=5)
                          lora.add_channel(2, frequency=915200000, dr_min=0, dr_max=5)
                          # lora.add_channel(4, frequency=915800000, dr_min=0, dr_max=5)
                          # lora.add_channel(5, frequency=916000000, dr_min=0, dr_max=5)
                          # lora.add_channel(6, frequency=916200000, dr_min=0, dr_max=5)
                          # lora.add_channel(7, frequency=916400000, dr_min=0, dr_max=5)
                          # lora.add_channel(8, frequency=915600000, dr_min=0, dr_max=5)
                          # lora.add_channel(9, frequency=916600000, dr_min=0, dr_max=5)
                          print("Lora send::-1")
                          def lora_cb(lora):
                              events = lora.events()
                              if events & LoRa.RX_PACKET_EVENT:
                                  print('Lora packet received')
                              if events & LoRa.TX_PACKET_EVENT:
                                  print('Lora packet sent')
                          # lora.callback(trigger=(LoRa.RX_PACKET_EVENT | LoRa.TX_PACKET_EVENT), handler=lora_cb)
                          # lora.join(activation=LoRa.OTAA, auth=(dev_eui,app_eui, app_key), timeout=0)
                          lora.join(activation=LoRa.ABP, auth=(dev_eui,app_eui, app_key), timeout=0)
                          print("Lora send::0")
                          # remove all the non-default channels
                          ##for i in range(0, 16):
                          ##    lora.remove_channel(i)
                              time.sleep(5)
                          for i in range(3, 16):
                          print("Lora send::1")
                          i = 0
                              print("Lora send::2")
                              s.setblocking(True)
                              print("Lora send::3")
                              # send some data
                              count = s.send(bytes([i % 256]))
                              print('Sent %s bytes' % count)
                              print("Lora send::4")
                              print("Lora send::5")
                              data = s.recv(64)
                              print("Lora send::",data)
                              i += 1
                            @misterlisty said in Lopy and Matchx usage:
                            Data Rate 5 isn't valid for your region, that's for EU868. Aren't you receiving an error trying to set it?
                            Try data rate 3:
                            s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
                            also your remove channel loop needs to remove up to channel 72, not just 16
                            for i in range(3, 72):
                            Ideally you shouldn't set them all to the same frequency and should set channels 0 - 7 to match you frequency plan - the 8 frequencies your gateway is listen on. Can you post your frequency plan again from your gateway configuration? I think you posted it before but then removed it.
                            • M Offline
                              @jmarcelino
                              	"SX1301_conf": {
                              		"lorawan_public": true,
                              		"clksrc": 1, /* radio_1 provides clock to concentrator */
                              		"lbt_cfg": {
                              			"enable": true,
                              			"rssi_target": -81, /* dBm */
                              			"chan_cfg":[ /* 8 channels maximum */
                              				{ "freq_hz": 915200000, "scan_time_us": 5000 },
                              				{ "freq_hz": 915400000, "scan_time_us": 5000 },
                              				{ "freq_hz": 915600000, "scan_time_us": 5000 },
                              				{ "freq_hz": 915800000, "scan_time_us": 5000 },
                              				{ "freq_hz": 916000000, "scan_time_us": 5000 },
                              				{ "freq_hz": 916200000, "scan_time_us": 5000 },
                              				{ "freq_hz": 916400000, "scan_time_us": 5000 },
                              				{ "freq_hz": 916600000, "scan_time_us": 5000 }
                              			"sx127x_rssi_offset": -7 /* dB */
                              		"antenna_gain": 2, /* antenna gain, in dBi */
                              		"radio_0": {
                              			"enable": true,
                              			"type": "SX1257",
                              			"freq": 915600000,
                              			"rssi_offset": -166.0,
                              			"tx_enable": true,
                              			"tx_freq_min": 915000000,
                              			"tx_freq_max": 928000000
                              		"radio_1": {
                              			"enable": true,
                              			"type": "SX1257",
                              			"freq": 916300000,
                              			"tx_enable": false
                              		"chan_multiSF_0": {
                              			"desc": "Lora MAC, 125kHz, all SF, 915.2 MHz",
                              			"enable": true,
                              			"radio": 0,
                              			"if": -400000
                              		"chan_multiSF_1": {
                              			"desc": "Lora MAC, 125kHz, all SF, 915.4 MHz",
                              			"enable": true,
                              			"radio": 0,
                              			"if": -200000
                              		"chan_multiSF_2": {
                              			"desc": "Lora MAC, 125kHz, all SF, 915.6 MHz",
                              			"enable": true,
                              			"radio": 0,
                              			"if": 0
                              		"chan_multiSF_3": {
                              			"desc": "Lora MAC, 125kHz, all SF, 915.8 MHz",
                              			"enable": true,
                              			"radio": 0,
                              			"if": 200000
                              		"chan_multiSF_4": {
                              			"desc": "Lora MAC, 125kHz, all SF, 916.0 MHz",
                              			"enable": true,
                              			"radio": 1,
                              			"if": -300000
                              		"chan_multiSF_5": {
                              			"desc": "Lora MAC, 125kHz, all SF, 916.2 MHz",
                              			"enable": true,
                              			"radio": 1,
                              			"if": -100000
                              		"chan_multiSF_6": {
                              			"desc": "Lora MAC, 125kHz, all SF, 916.4 MHz",
                              			"enable": true,
                              			"radio": 1,
                              			"if": 100000
                              		"chan_multiSF_7": {
                              			"desc": "Lora MAC, 125kHz, all SF, 916.6 MHz",
                              			"enable": true,
                              			"radio": 1,
                              			"if": 300000
                              		"chan_Lora_std": {
                              			"desc": "Lora MAC, 500kHz, SF8, 915.825 MHz",
                              			"enable": true,
                              			"radio": 0,
                              			"if": 250000,
                              			"bandwidth": 500000,
                              			"spread_factor": 8
                              		"chan_FSK": {
                              			"desc": "FSK disabled",
                              			"enable": false
                              		"tx_lut_0": {
                              			/* TX gain table, index 0 */
                              			"pa_gain": 0,
                              			"mix_gain": 8,
                              			"rf_power": -6,
                              			"dig_gain": 3
                              		"tx_lut_1": {
                              			/* TX gain table, index 1 */
                              			"pa_gain": 0,
                              			"mix_gain": 10,
                              			"rf_power": -3,
                              			"dig_gain": 3
                              		"tx_lut_2": {
                              			/* TX gain table, index 2 */
                              			"pa_gain": 0,
                              			"mix_gain": 9,
                              			"rf_power": 0,
                              			"dig_gain": 0
                              		"tx_lut_3": {
                              			/* TX gain table, index 3 */
                              			"pa_gain": 0,
                              			"mix_gain": 12,
                              			"rf_power": 3,
                              			"dig_gain": 0
                              		"tx_lut_4": {
                              			/* TX gain table, index 4 */
                              			"pa_gain": 1,
                              			"mix_gain": 8,
                              			"rf_power": 6,
                              			"dig_gain": 2
                              		"tx_lut_5": {
                              			/* TX gain table, index 5 */
                              			"pa_gain": 1,
                              			"mix_gain": 9,
                              			"rf_power": 10,
                              			"dig_gain": 0
                              		"tx_lut_6": {
                              			/* TX gain table, index 6 */
                              			"pa_gain": 1,
                              			"mix_gain": 11,
                              			"rf_power": 11,
                              			"dig_gain": 2
                              		"tx_lut_7": {
                              			/* TX gain table, index 7 */
                              			"pa_gain": 1,
                              			"mix_gain": 11,
                              			"rf_power": 12,
                              			"dig_gain": 1
                              		"tx_lut_8": {
                              			/* TX gain table, index 8 */
                              			"pa_gain": 1,
                              			"mix_gain": 11,
                              			"rf_power": 13,
                              			"dig_gain": 0
                              		"tx_lut_9": {
                              			/* TX gain table, index 9 */
                              			"pa_gain": 1,
                              			"mix_gain": 12,
                              			"rf_power": 14,
                              			"dig_gain": 1
                              		"tx_lut_10": {
                              			/* TX gain table, index 10 */
                              			"pa_gain": 2,
                              			"mix_gain": 8,
                              			"rf_power": 16,
                              			"dig_gain": 0
                              		"tx_lut_11": {
                              			/* TX gain table, index 11 */
                              			"pa_gain": 2,
                              			"mix_gain": 12,
                              			"rf_power": 20,
                              			"dig_gain": 2
                              		"tx_lut_12": {
                              			/* TX gain table, index 12 */
                              			"pa_gain": 2,
                              			"mix_gain": 14,
                              			"rf_power": 23,
                              			"dig_gain": 2
                              		"tx_lut_13": {
                              			/* TX gain table, index 13 */
                              			"pa_gain": 2,
                              			"mix_gain": 15,
                              			"rf_power": 25,
                              			"dig_gain": 0
                              		"tx_lut_14": {
                              			/* TX gain table, index 14 */
                              			"pa_gain": 3,
                              			"mix_gain": 11,
                              			"rf_power": 26,
                              			"dig_gain": 3
                              		"tx_lut_15": {
                              			/* TX gain table, index 15 */
                              			"pa_gain": 3,
                              			"mix_gain": 13,
                              			"rf_power": 28,
                              			"dig_gain": 0
                              	"gateway_conf": {
                              		/* change with default server address/ports, or overwrite in local_conf.json */
                              		"server_address": "aux.matchx.io",
                              		"serv_port_up": 1700,
                              		"serv_port_down": 1700,
                              		/* adjust the following parameters for your network */
                              		"keepalive_interval": 10,
                              		"stat_interval": 30,
                              		"push_timeout_ms": 100,
                              		/* forward only valid packets */
                              		"forward_crc_valid": true,
                              		"forward_crc_error": false,
                              		"forward_crc_disabled": false,
                              		/* GPS configuration */
                              		"gps_tty_path": "/dev/ttyS1",
                              		/* GPS reference coordinates */
                              		"ref_latitude": 0.0,
                              		"ref_longitude": 0.0,
                              		"ref_altitude": 0
                                Thanks @misterlisty
                                Please remove your all add_channel and remove_channel code and replace it with the following (yes remove_channel should be first). It should then match your gateway configuration. Also change the SO_DR to 3 as mentioned in my previous post. Do try OTAA and ABP if you can.
                                for i in range(0, 72):
                                # set the 8 channels for MatchX configuration
                                for channel in range(0,8):
                                    lora.add_channel(channel, frequency=915200000+channel*200000, dr_min=0, dr_max=3)
                                • M Offline
                                  @jmarcelino I get an error if i try to remove channels upto 72
                                    @misterlisty
                                    Is your LoPy configured configured for the EU868 region by any chance?
                                    It should have selected 915Mhz if you chose Australia during firmware upgrade.
                                    Please check with
                                    lora = LoRa()
                                    lora.frequency()
                                    also are you running the latest firmware?
                                    • M Offline
                                      @jmarcelino
                                      lora = LoRa()
                                      lora.frequency()
                                      doesn't return anything...
                                      My firmware is MicroPython v1.8.6-834-g5677703c on 2017-11-13; FiPy with ESP32
                                        @misterlisty
                                        Did you try it on the REPL?
                                        Try print(lora.frequency())
                                        • M Offline
                                          @jmarcelino The result is 868000000
                                          Appears like it isn't Australia..i assume i have to reapply firmware?
                                            @misterlisty
                                            Yes that’s set to EU868. We need to reset the device in Pycom’s database before you do a firmware upgrade to change the location. Please send me the MAC address of the WLAN via chat or email a request to support@pycom.io.
                                            import binascii
                                            binascii.hexlify(network.WLAN().mac(),':').decode()
                                            • 1
                                            • 2
                                            • 2 / 2
