    LoPy Nano-Gateway
    62 Posts 27 Posters 50.6k Views 31 Watching
      Colateral @Roberto
      @Roberto HI Roberto. Thanks. I ran the last script and is running fine. Regarding the memory leak, I believe is related with socket blocking approach. If we change the script and move to non blocking (as your script does) everything works fine.
      • R Offline
        Roberto @Colateral
        @Colateral
        Thanks for the quick response, i'll try a blocking approach to see if i can reproduce the error and check whats the root of it.
          assia
          @Colateral said in LoPy Nano-Gateway:
          Hi @Roberto i am bbegginer in LoRa and i don't understand the use of rx_iq and tx_iq.!
          thanks
          • B Offline
            borjam @assia
            @assia said in LoPy Nano-Gateway:
            It's easy. A LoRaWAN network is not a peer to peer network. There is a master (the gateway) that communicates with the nodes, but there is no node to node communication.
            Imagine that one of your nodes has the receiver active and another one transmits. The transmission is intended to be received by the gateway, of course (we said that there is no node-to-node communication) but the receiving node will get the packet anyway, if only to discard it.
            That reception and discarding has an energy cost. How do you avoid it? By having the nodes transmit in a mode that a node can't understand, only the gateway.
            Now, imagine this scenario: you make the nodes use tx_iq inversion (which is a sort of signal inversion) and the gateway use rx_iq inversion.
            In this case, a signal transmitted by a node will be inverted, and the gateway will successfully decode it. But other nodes, expecting a non inverted signal, won't detect the inverted signal. So you have just avoided the unintended packet reception problem.
            A C 2 Replies Last reply Reply Quote 1
              assia @borjam
              @borjam
              Thanks for the quick response, It's much clearer now.
                Colateral @borjam
                @borjam So how you can implement a mesh network using Lora? You put the GW in both tx and rx ?
                  assia
                  Hi @Roberto I tried to modify your code because I need to send a payload that contains the current time with a header containing mac address of the node and the length of the payload. Everything went well on the node side but rated nano gateway I have an Index Error: bytes index out of rang. it is because the adresse mac ? knowing that lora.mac() give : b'p\xb3\xd5I\x95kA\xf3' with length=8 but i don't understand what does mean the : b'p......' and how the length is 8 !!
                  thanks
                  node
                  # LoRa node
                  SRC_ADR_MAC=lora.mac()
                  #compteur packets
                  PACKETs_Cnt=5
                  while(PACKETs_Cnt>0):
                      # Package send containing a simple string
                      msg=time.time()
                      msg_len=len(str(msg))
                      pkg = struct.pack('!%dsBi' % len(SRC_ADR_MAC), SRC_ADR_MAC, msg_len, msg)
                      lora_sock.send(pkg)
                      PACKETs_Cnt=PACKETs_Cnt-1
                      time.sleep(5)
                  nano GW
                  # LoRa GW
                  while (True):
                      recv_pkg = lora_sock.recv(255)
                      if (len(recv_pkg) > 2):
                          device_adr_mac, msg_len, msg = struct.unpack('!%dsBi' %8 ,   recv_pkg)
                  # %8 because len(lora.mac())=8
                          print('Device: %s - Pkg:  %s' % (device_adr_mac, msg))
                      time.sleep(5)
                  • M Offline
                    MJ
                    Hi there, i am still new to lopy. I have try the example of the Lora.nanogateway code (https://docs.pycom.io/chapter/tutorials/lopy/lora-mac-nano-gateway.html) with only 1 lopy as gateway and 1 lopy as node. There is no response between both of them after i have coded it. What happen to this? Thank you.
                      Colateral @MJ
                      @mj Are you using 2 instances of pymaker ? If not, describe what you did.
                      • M Offline
                        MJ @Colateral
                        @colateral Hi, i am using 1 gateway that only with pymaker opened while the node i using the power bank to power up. I have try both in vice versa yet no result showing out.
                        • 1
                        • 2
                        • 3
                        • 4
                        • 2 / 4
