MQTT: OSError: -1 from line 160, in wait_msg
  • I've searched the forums and this is the closest post to what I'm experiencing:
    This is on a new WiPy 3.0 with default MQTT library. This also happens using the other version from micropython-lib (https://github.com/micropython/micropython-lib/blob/master/umqtt.simple/umqtt/simple.py).
    I've tried setting timeout to different values, no luck. This code was working fine on an ESP8266. Thoughts?
    (sysname='WiPy', nodename='WiPy', release='1.11.0.b1', version='3032601 on 2017-12-30', machine='WiPy with ESP32')
    Here's the relevant code:
        # Wait for a single incoming MQTT message and process it.
        # Subscribed messages are delivered to a callback previously
        # set by .set_callback() method. Other (internal) MQTT
        # messages processed internally.
        def wait_msg(self):
            res = self.sock.read(1)
            self.sock.setblocking(True)
            if res is None:
                return None
            if res == b"":
                raise OSError(-1) # <-- LINE 160
            if res == b"\xd0":  # PINGRESP
                sz = self.sock.read(1)[0]
                assert sz == 0
                return None
    My guess is the socket implementation has a bug - it should return None instead of a zero length bytes object. If that's the case, a quick fix would be to make the check less strict:
     if res is None or res == b"":
                return None
    This seems to work OK... What are the implications for relaxing this check?
  • @semireg We'll have a look to see if there's a bug in the socket implementation.
