    Lopy SPI SLAVE
    spi slave lopy
    4 Posts 2 Posters 1.2k Views 2 Watching
      Christian
      I would like to know if it's possible to use the lopy as #SPI slave simply to communicate Lora data to a master. I seams like using a rocket to kill a mousquito ! I ordered a couple of SX1272 lora modules but it's taking time. in the demo code I saw this part:
      "spi = SPI(0, mode=SPI.MASTER, baudrate=250000, polarity=0, phase=0, bits=8, firstbit=SPI.MSB)
      Is it design to always work as MASTER?
      If possible In the pinout I saw again #SPI connected to Lora how can I connect to it?
      thank in advance for your responses
      (I'm a french-speaker sorry if something is not well explained)
        jmarcelino @Christian
        Hi @christian
        We don't support support SPI slave mode at the moment but can you explain where you want to connect the LoPy to? Maybe there is an alternative.
          Christian
            Christian @jmarcelino
            Hi @jmarcelino
            I wanted to connect the Lopy as slave to a SAMD21G18 MCU. Normally my main goal is to make a board SAMD21G18+SX1272+NRF52832.
            But while waiting to recieve all the components, I wanted to test Lopy with the SPI slave!!
            But another option is the RX and TX.
            I'm I wrong somewhere?
