can't load pysense library
i updated pysense firmware and uploaded the libraries to the lib folder.
When importing the pysense library i get the error:>>> from pysense import Pysense Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/flash/lib/pysense.py", line 5, in <module> TypeError: cannot create 'module' instances
placing
pycoproc.py
at the same level aspysense.py
does not help (i then getno module named 'pycoproc.Pycoproc'
)Any idea what i'm doing wrong?
I'm glad it works, the documentation is off in a lot of places.
I read the docs here: https://docs.pycom.io/chapter/pytrackpysense/installation/libraries.html and created a lib folder inside my project - so in the end the stuff was placed in /flash/lib where the documentation says /lib so reading carefully helps.
I now have everything in /flash as you suggested and that works.Thanks
Jan
Place pycoproc.py at the same level as your main.py
1 out of 4
