    Connecting to gateway
    getting startedlopylorawan otaa
    4 Posts 2 Posters 1.1k Views 3 Watching
    • N Offline
      niekvanruler
      I use the example of connecting to a gateway from
      https://docs.pycom.io/chapter/tutorials/lopy/lorawan-otaa.html
      with my lopy, wth the newest firmware.
      I takes about 3 minutes before my lopy joines the gateway.
      Is this normal?
      Greetings,
      Niek
        jmarcelino
        Can you give us some more details on your setup? Most importantly which country are you based and how far away are you from the gateway?
        • N Offline
          niekvanruler
          I live in the Netherlands.
          I am about 1.6 km away from a gateway.
          The response after joining is:
          "time": "2018-01-17T10:17:07.155968027Z",
          "frequency": 867.3,
          "modulation": "LORA",
          "data_rate": "SF7BW125",
          "coding_rate": "4/5",
          "gateways": [
          "gtw_id": "eui-008000000000aa8a",
          "timestamp": 2268423667,
          "time": "2018-01-17T19:09:11.459706Z",
          "channel": 4,
          "rssi": -117,
          "snr": -3,
          "latitude": 53.20986,
          "longitude": 6.54523,
          "altitude": 15
          • N Offline
            niekvanruler @jmarcelino
