    Pytrack shows up with alternative USB ID so dfu-util fails
    pytrack usb
    5 Posts 2 Posters 1.5k Views 2 Watching
    • N Offline
      nicbkw
      Note that USB ID shows as 04D8:F013 and the firmware image update is for 04D8:F014
      So, even if I supply the detected USB ID, dfu-util fails
      dfu-util-static.exe -device 04D8:F013 -D pytrack_0.0.8.dfu
      dfu-util 0.9
      Match product ID from file: f014
      No DFU capable USB device available
      Windows 10 Pro, build 1709 on a Toshiba Portege laptop...
        jmarcelino
        If it's says F013 it's not in DFU mode. Make sure you are pressing the button on the Pytrak as you plug into USB. Then you only have 6 seconds while the board is in DFU mode.
        • N Offline
          nicbkw @jmarcelino
          @jmarcelino - thanks for the quick reply. Using Zadig, I have managed to see the Pytrack as an unknown device with USB ID 04D8:F014. However, when I follow the inistructions and press button, connect USB, wait 1 second, release button wait one second, run dfu-util, I see this:
          dfu-util-0.9-win64>dfu-util-static.exe -D pytrack_0.0.8.dfu
          dfu-util 0.9
          Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
          Copyright 2010-2016 Tormod Volden and Stefan Schmidt
          This program is Free Software and has ABSOLUTELY NO WARRANTY
          Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
          Match vendor ID from file: 04d8
          Cannot open DFU device 04d8:f014
          If I wait until I hear the USB disconnect as the Pytrack leaves dfu mode then I see
          dfu-util 0.9
          So, what might be causing dfu-util to report "...Cannot open DFU device 04d8:f014..."? - thanks!
            jmarcelino @nicbkw
            @nicbkw
            You need to use Zadig to set the 04D8:F014 device as libusbK driver, if it's unknown it won't work. You need to follow the steps from https://docs.pycom.io/chapter/pytrackpysense/installation/firmware.htm
            Alternatively an easier solution might be to install the Pytrack DFU Windows driver I made a while ago for the PyTrack: http://metavurt.net/software/drivers/PyTrack_DFU.zip
            Most people have had success with this.
            Once the driver issue is solved dfu-util should work.
            • N Offline
              nicbkw
              I could not get this to work on Windows whatever I tried. Switched to Mac and dfu-util worked first time...
              Thanks - for anyone else reading this trail, forget Windows, try Mac :-)
