    [SOLVED]No downlink
    ttn gatewaygatewayttndownlink
    1 Posts 1 Posters 947 Views 2 Watching
    • R Offline
      rpct
      I'm working with several Lopy. Some are configured as nodes, one is configured as single channel gateway. I'm on TTN.
      Firmware info is :
      nodename='LoPy', release='1.14.0.b1', version='v1.8.6-849-86da809 on 2018-01-17', machine='LoPy with ESP32', lorawan='1.0.0'
      I cannot join TTN : I can see in TTN console join request is received by my gateway, join accept is sent to node. But nodes does not join.
      So I tried ABP activation in order to check if it was a donwlink or a join problem. In ABP uplinks packets are received but downlink packets are never received. I can see from TTN console it is sent.
      Here is node code :
      # set the LoRaWAN data rate
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
      # make the socket blocking
      s.setblocking(False)
      time.sleep(1.0)
      i = 0
      while True :
          pkt = b'PKT #' + bytes([i])
          print('Sending:', pkt)
          s.send(pkt)
          i += 1
          #time.sleep(4)
          rx, port = s.recvfrom(256)
          if rx:
              print('Received: {}, on port: {}'.format(rx, port))
          time.sleep(4)
      time.sleep(6)
      SOLUTION :
      TTN gateway <-> TTN server communication is done using TCP with TTN server port 1700 for nanogateway using Semtech packet forwarder. On my network incoming UDP traffic is blocked. I have to add a rule to allow UDP traffic from TTN server.
      More info about this issue here
