    Class-C sample
    lopylora classclass-cclass c
    14 Posts 7 Posters 3.7k Views 7 Watching
      derchris
      Dear all,
      we've got our RG1xx Gateway up and running - pretty awesome and easy experience
      We can already do the basic Class-A communication where the node creates an uplink msg to received a possible downlink msg.
      For our use case we want to be in "always listen mode", and I guess this is Class-C. Therefore I changed the example source accordingly to Class-C initialization:
      lora = LoRa(mode=LoRa.LORAWAN, public=True, tx_retries=3, device_class=LoRa.CLASS_C)
      s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, False)
      s.setblocking(False)
      But... how do I proceed with receiving the messages? Eg for receiving only one test byte my infinite loop simply looks like this:
          rx, port = s.recvfrom(1)
      But nothing is received
      Is there any sample for the Class-C mode?
        jmarcelino @derchris
        Hi @derchris
        You still need to join the network with lora.join(activation=... , auth=(...)) as you do in Class A even for Class C.
        Perhaps that's the problem?
        If not please tell me more about your setup, which network server are you using etc.
        Thanks.
          derchris
          @jmarcelino yes, that was the problem :) thx
          • N Offline
            Neuromystix
            Hello all,
            Forget it, it's working fine here. Received downlink data in 869,525 and with any DR. Bad server configuration was the problem.
            I have the same problem here. I'm running locally a Lorawan Server and i can send up or downlink messages in Class-A mode without any problem. When trying to use Class-C i never receive nothing. I know that the server send the message, because i use a SDR to confirm it.
            My test code is:
            #Class C test code
            lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868, public=True, device_class=LoRa.CLASS_C)
            lora_channel_init()
            lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=config.JOIN_TIMEOUT, dr=config.JOIN_DR)
            print('Not joined yet...')
            while not lora.has_joined():
                blink(red, 0.5, 1)
            print('  ---  Joined Sucessfully  ---  ')
            s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
            s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, config.LORA_NODE_CONFIRMED)
                rx, port = s.recvfrom(12)
                if rx:
                    print('Received: {}, on port: {}'.format(rx, port))
                    #blink(yellow, 0.1, 2)
            The code configure three channels in 868,1 and then join the network. When inside the loop, it never receive nothing.
            Channel 0 in frequency 868100000
            Channel 1 in frequency 868100000
            Channel 2 in frequency 868100000
            Not joined yet...
            If i change the code and insert a send inside the loop, when trying to downlink a message to Lopy, it receives it inside the RX1 window normally but never outside of it.
            pkt_send = 0
                s.setblocking(True)
                s.send(bytes([0x00,0x01]))
                if rx:
                time.sleep(5)
            Next image shows a downlink message sended in normal class A style, using RX1 windows.
            Here i tried to send multiple downlinks outside RX window time but Lopy never received none.
            Any idea how to solve it or what could be wrong? Did Lopy use the default LoraWAN RX2 frequency and DR??
            Researcher @ UALG, Portugal
            • Charly86C Offline
              Charly86
              Hi guys
              have you got an example of class C device working?
              I've done several tests and got only downlink when I send an uplink.
              Is class C is working (I got last firmware at this day)
                jmarcelino @Charly86
                Hi @charly86
                It should be. What's your network server? Is it sending the downlink on RX2 correctly, do you know which frequency/sf it is using?
                Charly86C 1 Reply Last reply Reply Quote 0
                • Charly86C Offline
                  Charly86 @jmarcelino
                  @jmarcelino
                  Thanks, I'm using this one https://github.com/gotthardp/lorawan-server with this configuration
                    @charly86
                    Thanks, for the Gotthard server how are you triggering the Class C downlink? Are you specifying the correct port and time?
                    • Charly86C Offline
                      @jmarcelino I'm using websocket for that, and with json, for class A I'm sending this and got downlink just after uplink (it works also with class C)
                      24/05/2018 16:16:11 Downlink: {"devaddr":"03128BC8","data":"0100"}
                      but for class C, when I send this nothing happens, even sending uplink just after to try to get downlink
                      24/05/2018 16:15:32 Downlink: {"devaddr":"03128BC8","data":"0100","time":"immediately"}
                      Anyway I'll try A timed one, may be I'm not doing things correctly
                      • N Offline
                        Neuromystix @Charly86
                        @charly86 You'll need to specify also a port number for class C to work:
                        {"devaddr":"03128BC8","data":"0100", "port":2, "time":"immediately"}
                        • Charly86C Offline
                          Charly86 @Neuromystix
                          yeah I tried @jmarcelino port option while you were writing @Neuromystix , setting port and works ;-)
                          24/05/2018 16:59:16 Downlink: {"devaddr":"03128BC8","data":"0164","port":2, "time":"immediately"}
                          Lopy Side
                          Downlink received
                          Cmd=0x01
                          Value=100% Dac1=0.8
                          thanks all :-)
                          • F Offline
                            Fulch36
                            Can any of those who have now successfully got class C downlinks working please share some example code? I've been at this all week and like many others here: I can get downlinks in class A or C in the RX window after sending but never outside of it.
                            I'm also interested in some comments on how best to handle downlink messages, I can see some info on defining event driven callbacks but the docs don't make it clear whether this is supposed to be used for both LoRa and LoRaWAN. Otherwise I guess you'd just stop the socket from blocking and try to receive on that socket as part of a main loop, this seems a little messy but I'd just be happy to have it working.
                            • F Offline
                              Francisco Oliveira
                              What about class B devices? Is it necessary to make some code for Lopy (end node)?
                              Thank you.
                                Class B is currently not supported in the pycom firmware for the Lopy.
                                You might be able to write some addition to the firmware to build it yourself, though I suspect it will be some work
