LTE-M
I was using a 2G connection with our SIM cards for the other project but I fear it won't be able to work with the FiPy. Do you know how we could achieve to get internet through LTE-M (or NB-IoT) just to send some payload via MQTT?
Application countries would be first in Germany but also in Brazil.
Even if our SIM cards would not work I guess there would be a possibility for Germany since their network is expanding, but I'm quite unsure of Brazil...I thought at the beginning that the FiPy would be able to do a simple internet connection via LTE, but I guess I've been wrong there :s
I guess we will need to go for SigFox until everything is settled.
I forgot to mention one question: I saw that AT commands are coming in near time on other posts.
I didn't see a method in the documentation about how to connect to an APN of the SIM card. So I don't know if this method comes with those AT commands or if there is another solution to it.Thanks for your response so far =)
@toppert
We’ll support NB-IoT in Germany soon, but NB-IoT in general - due to its nature - won’t support TCP connections needed for MQTTSome carriers do give (better said - you
must use it) access to NB-IoT data through their IoT cloud server which you can then connect to via MQTTOn LTE-M (Cat M1) I’m not aware of any specific plans for Germany but really all carriers are considering it at some point
