    Deepsleep wake reason crashes board when on battery power
    deepsleeplopycrashlatest firmware
    1 Posts 1 Posters 759 Views 2 Watching
    • EndoMonkeyE Offline
      EndoMonkey
      When I place code in the main.py to check the reason for wake from deepsleep (deepsleep shield) the program crashes with the error message below when on battery power:
      ets Jun 8 2016 00:22:57
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff9028,len:8
      load:0x3fff9030,len:1060
      load:0x4009fa00,len:0
      ho 12 tail 0 room 4
      load:0x4009fa00,len:14084
      entry 0x400a05d4
      File "main.py", line 50, in <module>
      File "/flash/lib/deepsleep.py", line 157, in get_wake_status
      File "/flash/lib/deepsleep.py", line 81, in peek
      IndexError: bytes index out of range
      MicroPython v1.8.6-849-baa8c33 on 2018-01-29; LoPy with ESP32
      The program works fine when powered via the USB port and only crashes on battery power!
      Firmware v. 1.15.0.b1 and deepsleep.py v. 1.0.5.
      Is this a known issue or could I be doing something odd in my code?
      Any thoughts much appreciated!
