    Unresponsive fipy
    deadunresponsive
    4 Posts 2 Posters 1.1k Views 2 Watching
      definiteslacking
      It had been working with pysense & pytrack, now pify in completely unresponsive.
      On connect, no LED
      Double checked firmware update (dfutils) of pysense, that still worked.
      Seated pify, connected, lsusb shows the device.
      Linux# screen /dev/ttyACM0 115200 does nothing.
      Windows Putty COM5> Serial 115200 does nothing.
      Linux# iwlist scan (look for wifi to telnet), nothing but my normal APs.
      Tried different USB cables, but no luck whatsoever.
      Any suggestions? Is it bricked?
        definiteslacking @definiteslacking
        @definiteslacking WOW
        Call this lack of sleep
        From another post, I found the solution:
        The LED on Fipy should be on the same side/direction as micro-USB.
        That would do it :/
          robert-hh @definiteslacking
          @definiteslacking Does the module still work?
            definiteslacking @robert-hh
            @robert-hh yes, after inserting it the correct way, everything was as normal!
            Now I just need to beef up my micro python skills!
