Packet loss in Lorawan
I have two lopys :
- nano gateway
- node that just sends an unconfirmed packets with a 4s period
I get lot of packet losses as you can see here in TTN console :
Here is packet detail with RSSI :
Lopys are in an indoor environment, either quite close < 5m or < 20m separated by a wall. I've tested in two buildings and got in both cases lot of losses > 50%.
Have you experienced same results?
How can I reduce packet loss?As a workaround I could send confirmed packets and retransmit it when it is lost. But for class A device, that means a retransmission will be done after 2s, meaning a very high latency.
@rpct Have you correctly configured the sending node to only use the single frequency the nano-gateway is listening on?
Here is node code :
""" Node example compatible with the LoPy Nano Gateway """ from network import LoRa import socket import binascii import struct import time import config import pycom print("Single channel node") # initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN) dev_eui = binascii.hexlify(lora.mac()).decode('utf-8').upper() if dev_eui in config.NODES_AUTH : print('Got auth parameters for {} TTN node'.format(config.NODES_AUTH[dev_eui].ttn_name)) else : raise Exception('Cannot get OTA auth parameters for node with DEV_EUI {}'.format(dev_eui)) # set the 3 default channels to the same frequency (must be before sending the OTAA join request) lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5) lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5) lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5) # remove all the non-default channels for i in range(3, 16): lora.remove_channel(i) # join a network using OTAA if(config.NODES_AUTH[dev_eui].auth_type == LoRa.ABP) : print('doing ABP activation') if(config.NODES_AUTH[dev_eui].abp_auth == None) : raise Exception('No abp params for node {}'.format(config.NODES_AUTH[dev_eui].ttn_name)) else : lora.join(activation=LoRa.ABP, auth=(struct.unpack(">l", binascii.unhexlify(config.NODES_AUTH[dev_eui].abp_auth.dev_add))[0], binascii.unhexlify(config.NODES_AUTH[dev_eui].abp_auth.nw_sess_key), binascii.unhexlify(config.NODES_AUTH[dev_eui].abp_auth.app_sess_key)), timeout=0, dr=config.LORA_NODE_DR) elif(config.NODES_AUTH[dev_eui].auth_type == LoRa.OTAA) : print('doing OTAA activation') if(config.NODES_AUTH[dev_eui].otaa_auth == None) : raise Exception('No otaa params for node {}'.format(config.NODES_AUTH[dev_eui].ttn_name)) else : lora.join(activation=LoRa.OTAA, auth=(binascii.unhexlify(config.NODES_AUTH[dev_eui].otaa_auth.app_eui), binascii.unhexlify(config.NODES_AUTH[dev_eui].otaa_auth.app_key)), timeout=0, dr=config.LORA_NODE_DR) # wait until the module has joined the network while not lora.has_joined(): time.sleep(2.5) print('Not joined yet...') print('Joined') else : raise Exception("Authentification type : {} not handled".format(config.NODES_AUTH[dev_eui].auth_type)) pycom.heartbeat(False) pycom.rgbled(0x00ff00) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR) # make the socket blocking s.setblocking(False) time.sleep(1.0) i = 0 while True : pkt = b'PKT #' + bytes([i]) print('Sending:', pkt) s.send(pkt) i += 1 #time.sleep(4) rx, port = s.recvfrom(256) if rx: print('Received: {}, on port: {}'.format(rx, port)) time.sleep(4) time.sleep(6)I observed that moving code that removes all default channel
# remove all the non-default channels for i in range(3, 16): lora.remove_channel(i)AFTER join gives better results. I cannot explain it. In my case, I'm only using 1 channel, Join request / Accept will be done using 3 first channels all configured as same channels. Deleting other channels before or after join success should be the same? In all cases, when node sends a packet it only sends it on 3 first channels.
@rpct In the general case, changing the frequencies after the join (and a few packet exchanges) could be different as the gateway can give instructions to the node about which channels to use.
Not sure if the nano-gateway code does anything like that...
@jcaron said in Packet loss in Lorawan:
Gateways never give instructions (more precisely MAC commands) to devices, it is up to the Network Server. Gateways do not have encryption keys nor any knowledge on devices.
@jcaron The node is to close to gateway ...
@rpct how did you import the network module please? I'm new to pycom and I'm having problems with that . Can you help?
@chumelnicu could you be more precise about mechanisms causing packet loss when gw is too close from node? How can we calculate minimum distance? How can we check a node is too close?
@rpct try to delete all channels but one after joining. That solved it for me
@rpct To much power could bring lora module in supra-saturation ...For that is important to have a minimum distance between node and gateway .... Just try to put the gateway in other room
That’s only true for single channel gateways (using a Lopy as a nano-gateway). When using a real, full, LoRaWAN gateway you should keep all the channels.
Real gateways also have more sensitivity it’s recommended that nodes are least 2 meters away to avoid overloading the RX amplifiers.
@jmarcelino as far as OI read it, that's the case here.
Yes thanks @robert-hh,
Just wanted to make it clear to anyone looking this answer up for the more generic node - gateway separation concern that was being discussed
