    Open source Licence
    27 Posts 9 Posters 17.2k Views 9 Watching
    • F Offline
      Fred administrators
      Dear All,
      I am pleased to confirm that the firmware of Pycom modules is now Open source and can be found here https://github.com/pycom/pycom-micropython
      Essentially, we’re releasing the source code under GPLv3 which will ensure our developer community is able to support the development of the code unhindered. It also enables 3rd party ‘board manufacturers’ or people to distribute/license the code as long as they adhere to the license, attribution and disclaimer notices. This is also an obligation placed on Pycom by some of our technology partners.
      We have also placed on the repo a CLA (Contributor License Agreement) based on the Apache license with a few tweaks (which makes it more relevant for our hardware community).
      As I have previously offered, happy to address any questions you may have. Simply post on Forum or email me (fred@pycom.io) and I will collate all the information over a period of a week. We will then compile and submit back an FAQ document to address the main pertinent questions.
      Best wishes
      Fred
      B 1 Reply Last reply Reply Quote 6
      • B Offline
        brotherdust
        @Fred : Thank you very much! Having the code answers many of the questions I have been thinking about asking. Great work to all. I know it's been a long haul. Keep up the good work!
          thibault
          Nice news!
            LoneTech
            Great news! I've cloned a copy and managed to build what appears to be a LoPy firmware.
            Rough steps performed:
            Get ESP32 compiler toolchain per instructions at https://github.com/pycom/pycom-esp-idf/blob/master/docs/linux-setup.rst (there exist instructions for other platforms too), adding commands xtensa-esp32-elf-gcc etc to PATH
            Cloned Pycom's IDF and micropython repositories, setting export IDF_PATH=~/LoPy/pycom-esp-idf (adjust path to where you placed it)
            Enter micropython repo directory for ESP32: cd pycom-micropython/esp32/
            Workaround for unexpected Makefile behaviour: ln -s ../lib bootloader/lib (this shouldn't be needed, probably should change -Lbootloader/lib to -Llib in Makefile, alternatively make sure it builds bootloader variants of libraries)
            Build firmware: make BOARD=LOPY LORA_BAND=USE_BAND_868
            New firmware is saved in build/LOPY/release/appimg.bin
            A warning produced by the build suggests that it did newline conversion on a PDF. That's going to end badly as it's a binary format, though it's a packaging issue and doesn't affect building the firmware itself.
            Looking good so far, though it'll take a little while to find where I can touch it up. Expect a pull request or two in the future. :)
            P.S. After curl --disable-epsv --ftp-pasv -T build/LOPY/release/appimg.bin ftp://micro:python@ESP_00C2C6//flash/sys/appimg.bin my LoPy said MicroPython e2cc46a-dirty on 2016-11-15; LoPy with ESP32 :)
            F L B N 4 Replies Last reply Reply Quote 3
            • F Offline
              Fred administrators @LoneTech
              @LoneTech Great stuff! Have fun!
              • X Offline
                Xykon administrators
                In case anyone finds it helpful I mirrored the html docs from esp-idf on my webserver at https://www.tiny-dev.com/esp32/
                Christian Ehlers
                  livius @LoneTech
                  @LoneTech
                  If you or someone have same guide for Windows :)
                  • X Offline
                    Xykon administrators @livius
                    @livius said in Open source Licence:
                    @LoneTech
                    https://www.tiny-dev.com/esp32/windows-setup.html
                    Christian Ehlers
                      livius
                      It is incompleat
                      i do not see something like this in documentation
                      as was posted by @LoneTech
                      and something like
                      • X Offline
                        It's identical under all OS. Read Makefile and application.mk in the pycom-micropython/esp32 folder.
                        curl with these specific options is used as a command line ftp client. You can just as well use FileZilla following the instructions at https://docs.pycom.io/lopy/lopy/general.html#upgrading-the-firmware-over-the-air
                        Christian Ehlers
                          livius
                          this should be in documentation. Reading script file is bad way for starters ;-)
                          but now it is clear
                          ah i see, he only copy image file throught ftp
                          i did not read whole line carefully - but it was so simple
                          when i saw curl i have stoped reading ;-)
                            livius
                            thank you for help
                            i now have make WIPI bin file
                            and i am ready to make some pull requests :)
                            • B Offline
                              brotherdust @LoneTech
                              @LoneTech Thanks for the instructions. I was able to successfully build on my Windows 10 box using Bash on Ubuntu on Windows. =) heh.
                              • B Offline
                                brotherdust @brotherdust
                                @brotherdust said in Open source Licence:
                                So, yeah. It might have built successfully, but I can't get the LoPy to take it. Argh. Here's the CLI output:
                                $ curl --disable-epsv --ftp-pasv -T "build/LOPY/release/appimg.bin" ftp://micro:python@10.192.5.64//flash/sys/appimg.bin
                                  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                 31  819k    0     0   31  256k      0   530k  0:00:01 --:--:--  0:00:01  534k
                                curl: (55) Send failure: Broken pipe
                                I think it's because the firmware file is too big. The one I compiled is ~820KB, but the official releases are weighing in around ~631KB. Is it possible this is the cause?
                                  LoneTech @brotherdust
                                  @brotherdust Unlikely; the firmware partitions are 1M large, and your transfer stopped at 256k. OTA updating isn't quite 100% for me; not sure if that readonly flash bug is reoccurring or what, but doing a serial download tends to clear it. Also, on the firmware versions with the watchdog bug OTA almost always triggers that.
                                  • N Offline
                                    nickparrin @LoneTech
                                    Keep getting an error like this:
                                    developer@developer:~/esp32/pycom-micropython/esp32$ make BOARD=LOPY LORA_BAND=USE_BAND_868
                                    LINK build/LOPY/release/bootloader/bootloader.elf
                                    xtensa-esp32-elf-gcc -nostdlib -Wl,-Map=build/LOPY/release/bootloader/bootloader.map -Wl,--no-check-sections -u call_user_start_cpu0 -Wl,-static -Wl,--undefined=uxTopUsedPriority -Wl,--gc-sections -T esp32.bootloader.ld -T esp32.rom.ld -T esp32.peripherals.ld -Wl,--start-group -Llib -L/home/developer/esp32/pycom-esp-idf/components/esp32/ld -Lbuild/LOPY/release/bootloader -L/home/developer/esp32/pycom-esp-idf/components/esp32/lib -Lbootloader -llog -lcore -lspi_flash build/LOPY/release/bootloader/bootloader.a -Wl,--end-group -Wl,-EL -o build/LOPY/release/bootloader/bootloader.elf
                                    /home/developer/esp32/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/4.8.5/../../../../xtensa-esp32-elf/bin/ld: cannot find -lcore
                                    collect2: error: ld returned 1 exit status
                                    application.mk:274: recipe for target 'build/LOPY/release/bootloader/bootloader.elf' failed
                                    make: *** [build/LOPY/release/bootloader/bootloader.elf] Error 1
                                    I set the IDF_PATH and added gcc to PATH. Tried with the ln command, and without by editing the Makefile directly
                                    EDiT: fixed it thanks to daniel. I missed to import (inside pycom idf) the needed compontents:
                                    • git submodule update --init
                                      livius
                                      Will be good to see port of this
                                      https://github.com/micropython/micropython/pull/2091/files
                                      and also enable time_us() which is currently commented out in the code
                                      but i suppose it is limited by some esp32 IDF? and because of this is commented out?
                                      https://github.com/pycom/pycom-micropython/blob/master/esp32/mods/modutime.c
                                        daniel
                                        @livius yes, machine.time_pulse_us() is very useful and we will implement it for the ESP32. A number of function in the time module are incomplete due to previous limitations of the IDF. The plan is to get back to that and implement them in early January.
                                        Cheers,
                                        Daniel
                                          livius @daniel
                                          @daniel
                                          thank you for the info - especially about time frame
                                            livius
                                            @daniel
                                            Can i ask what is IRAM_ATTR in functions declaration?
                                            • 1
                                            • 2
                                            • 2 / 2
