    Serial to UART POST JSON
    uart1jsonpost
    5 Posts 2 Posters 1.3k Views 2 Watching
      jimpower
      Hi All,
      I have a weigh station transmitting weight data via RS232, I have connected this to UART1 pins 3 & 4 pins via TTL and I can receive ASCII string and print this using the
      print("Weight POST Successful - " + str(uart1.readall()) + " g")
      however when i use the same to print into a JSON payload it prints none.
      Here is the code
      res = urequests.post('https://My_URL', json={'Weight': str(uart1.readall())})
      res.close()
      if (res.status_code - 200) < 100: # check that response code is in the 200 range
          print('there was some error')
      gc.collect()
        livius @jimpower
        @jimpower
        Do you mean that
        does not print anything
        or
        does not send anything? or both?
        You must know that uart1.readall() clear buffer and second uart1.readall() read nothing (or new incomming data)
        you must store data into var to use it in second print
        e.g.
        tmp = uart1.readall()
          jimpower @livius
          @livius
          sends none
          prints as expected
          the second print is only to see what is coming through in terminal I can remove it as its not required.
          If I were to use it as you suggest would it look like this?
          res = urequests.post('https://My_URL', json={'Weight': str(tmp())})
          res.close()
          print("Weight POST Successful - " + str(tmp()) + " g")
          gc.collect()
            livius @jimpower
            @jimpower said in Serial to UART POST JSON:
            tmp()
            without parenthesis
              jimpower
              @livius
              I added tmp = uart1.readall() and it works thanks again I managed to do this before your reply thanks again you are always very helpful
