    LoRaWan and MatchX
    lopymatchx
    4 Posts 2 Posters 1.1k Views 2 Watching
    • M Offline
      misterlisty
      i have my lopy working with multitec hbut having issue with MatchX gateway. Any help would be great.
      from network import LoRa
      import binascii
      import struct
      app_eui = binascii.unhexlify('00 XX 00 00 00 00 B7 E2'.replace(' ',''))
      app_key = binascii.unhexlify('2B 7E 15 16 28 AE D2 A6 AB F7 15 88 09 CF 4F 3C'.replace(' ',''))
      for channel in range(0, 8):
              lora.remove_channel(channel)
      for channel in range(16, 64):
      # wait until the module has joined the network
      i = 0
      while not lora.has_joined():
          time.sleep(5)
          i = i+1
          print('joining LoRa'+ str(i*5) +' second has passed...')
      print('LoRaWan connect.')
      # create a LoRa socket
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
      i = 0
          print("Lora send::1")
          # set the LoRaWAN data rate
          s.setblocking(True)
          print("Lora send::3")
          # send some data
          count = s.send("Hello lora" + str(i))
          print('Sent %s bytes' % count)
          print("Lora send::4")
          i += 1
        chumelnicu
        Hi .. remove from your code below lines and try again...
        Also try to update lopy with last firmware and use OTAA example from
        https://docs.pycom.io/chapter/tutorials/lopy/lorawan-otaa.html
        I've try it yesterday Lopy OTAA with MatchX gateway and working
        • M Offline
          misterlisty
          I have this same code working with my multi-tech by not matchx. I can see in logs that its connecting but the lopy thinks its not connected.
            chumelnicu @misterlisty
            @misterlisty I just told you what is work for me .....
            BTW why did u remove channels? On this firmware u can set Region Eu, US AS from code without remove channels and add others ...
            Also you can try to set from your MatchX lbt_cfg": {
            "enable": false,
