    Telstra LTE Cat-M Working on FiPy .... Just..
    fipyltecat-m1lte-mtelstra
    26 Posts 8 Posters 9.9k Views 8 Watching
    • N Offline
      nathanh
      So after many, many, maaannnyy hours I have successfully got my FiPy working on Cat-M on Telstra. I have confirmed this multiple times with an end-to-end test with sending JSON data successfully back to my server.
      The downside is, it is very flaky and often requires hard resets of the FiPy unit. The solution is a combination of using AT commands and the LTE library commands provided by the latest Pycom firmware. I am no means an expert on talking with modems via AT commands and most of it was by trial and error using ideas from several threads here, but if anyone with a better idea can see what is going on / has suggestions that would be awesome.
      Firstly, my process for getting the FiPy connecting to Telstra (note this is very rough and error prone but hopefully clear enough to explain my process).
      from network import LTE
      lte = LTE()
      #set the apn
      lte.send_at_cmd('AT+CGDCONT=1,"IP","telstra.m2m"')
      #set modem to full function mode
      lte.send_at_cmd('AT+CFUN=1')
      #does not seem to do anything at this stage but is required as it seems it is setting some internals in the pycom comms chain that is needed
      lte.attach()
      #register onto the network - will take a few moments after running this command for it to be on the network
      lte.send_at_cmd('AT+COPS=?')
      # wait for the attach flag to set and use the connect call
      # the modem will auto connect from the previous call regardless but still need to call this otherwise the unit does not know it's connected
      if (lte.isattached()) # obviously in reality this is a while/sleep loop, just using an if as an example
              lte.connect()
      send_data_to_server() # whatever you want to do here - personally I use the urequests library
      So now for the gotchas... This does not always work and seems to be a timing issue between the AT+COPS command and the connect call. It seems after calling AT+COPS=? the modem generally will connect fine but calling lte.connect() can reset the state and put the modem into a (crashed?) state that it will no longer accept AT commands and throws OS errors.
      You can see the status of what the modem is doing by using:
      lte.send_at_cmd('AT!="showphy"')
      lte.send_at_cmd('AT!="fsm"')
      showphy is good to see when we have gone from searching to connected to a cell and fsm is handy to see the state of the modem after COPS and the effect calling lte.connect() has. But again I am no expect and do not fully comprehend all the information that is available.
      From playing around, I have had the most success from calling lte.connect() as soon as the lte.isattached() comes true and sending data to my server immediately. The longer the delay, the more I see the connect call actually break/reset the connection.
      Another unfortunate side effect is that the connect seems to only stay open for a minute or so after I send the last data packet (although I have only sent payloads for a max of 2 minutes). It appears the modem again gets in a state where it stops accepting commands and trying to call any AT commands results in an exception with an OSError. I have yet to also find a reliable way to reset/reconnect without performing a complete power cycle. Combinations of disconnect, reset or deinit have not produced a reliable way of re-establishing a connection.
      So there you have it, my discovery process of a working (but flaky) LTE Cat-M connection of a FiPy to Telstra, Australia. If anyone can work on the above and see how to make it more stable or have any further ideas I would be immensely grateful.
      Also just for info, I ended up using an Aldi sim card on the basic $15 plan that I purchased at the cash register the other night. Surprising this works given I was told by numerous IoT suppliers you needed specific Telstra IoT SIM cards, of which I have and tested as well, but found I had more success using Aldi.
        daniel
        @nathanh thanks for this post! Would you be willing to get on a TeamViewer session with me so that I can see what is causing the modem to hang after connecting? Thanks again!
        Cheers,
        Daniel
        • N Offline
          nathanh @daniel
          @daniel Hi Daniel, happy to help anyway I can, I sent you a private message.
          • I Offline
            IOAg
            Thank @nathanh for your detailed explanation, so glad somebody got it working. I had been struggling for 2 days because I was using Wifi to connect to device, when I switched to COM it made it work by magic.
            @daniel Is it expected pycom/Wifi use causes LTE-M to stop working?
            Been using:
            (sysname='FiPy', nodename='FiPy', release='1.17.0.b1', version='v1.8.6-849-d0dc708 on 2018-02-27', machine='FiPy with ESP32', lorawan='1.0.2', sigfox='1.0.1')
            Last point, connection drops for me as well after a short while; if i call disconnect(), I can reconnect readily.
            • N Offline
              nick_aus
              @nathanh did you get any further with your issues? Were you able to hold the connection open?
              • M Offline
                MarcoBenini
                @nathanh COPS comamnds are used for operator selection. Usually the mode is set to 0, so the selection is done automatically.
                The command AT+COPS=? that You use does a scan of the network to get a list of available network operators. If You parse the response You'll see the network operators found by the modem.
                It takes several time and also, if the modem was registered or started to registration process, that is stopped.
                It would be interesting to look at which LTE Cat M1 module is used.
                With commands AT+CGMI , AT+CGMM , AT+CGMR You could get manufacturer, model and firmware version. Than one can search the manual with full list of supported commands.
                • N Offline
                  nathanh @MarcoBenini
                  @marcobenini said in Telstra LTE Cat-M Working on FiPy .... Just..:
                  Yea, so that is what I thought and I have no idea why it "helps". Trying to connect without calling it fails everytime, but for some reason when I do call it (noting it is not doing anything but reporting and COPS is set as 0 (automatic) by default, it seems to help with the process. Maybe it is forcing the modem to scan more thoroughly than setting CFUN to 1 ? Again this is all pure guess work.
                  Well it is documented by Pycom to be a Sequans modem with a link to the reference manual. I have been trying to go through it along with the firmware to try and understand what is happening but still struggling to take it all in. For what it is worth, here is the feedback from those commands you mentioned.
                  >>> send_atcmd('AT+CGMI')
                  SEQUANS Communications
                  OK
                  >>> send_atcmd('AT+CGMM')
                  VZM20Q
                  OK
                  >>> send_atcmd('AT+CGMR')
                  UEUnknown
                  OK
                  @nick_aus said in Telstra LTE Cat-M Working on FiPy .... Just..:
                  I am still finding it very unreliable, even trying to get the connection up in the first place. @IOAg found that if you call disconnect after sending a payload it does keep the modem from crashing for a time, which I have confirmed. But even using disconnect after every payload send I find after a while the modem completely crashes and even a reset does not help.
                  After looking at the Pycom firmware, the only difference I see between what I am doing and the attach/connect commands alone is first I set the APN and second I use the AT+COPS command to show the networks, yet for some reason it seems to help.
                  I also am starting to suspect that the antenna I purchased (which is labeled as the FiPy/Gpy antenna) is not tuned for Band 28. I cannot seem to find any real documentation or details on it. I was going to try and put it onto a wave generator and specan next week to make sure it is tuned to the correct frequencies. For reference here are some pictures of it.
                  • N Offline
                    nathanh
                    Does anyone know if there are any AT commands that report any network/cell tower information that the modem is seeing before it attaches to a network? All the commands I see only show info after you have attached.
                    Also, I can't see to find any reference or documentation in the Sequans manual on the following commands which are in the Pycom firmware (also tried general google searching but nothing came up).
                    AT!="clearscanconfig"
                    AT!="RRC::addscanfreq band=28 dl-earfcn=9435"
                    AT!="fsm"
                    AT!="showphy"
                    I can guess what they do and piece some of the information out of them, but knowing exactly what all the values means, especially with showphy and fsm would be really helpful.
                    Cheers,
                    Nathan
                      timh
                      Hi
                      Has any one made any further progress with this?
                      I find I can only occasionally see the Telstra Network.
                      '\r\n+COPS: (1,"Telstra Mobile","Telstra","50501",7),,(0,1,2,3,4),(0,1,2)\r\n\r\nOK\r\n\r\n+CEREG: 4\r\n'
                      Most of the time I get nothing - empty string,+COPS: ,,(0,1,2,3,4),(0,1,2)
                      >>> print(lte.send_at_cmd('AT+COPS=?'))
                      OK
                      And even once AT+COPS=? has listed the Telstra network, I have never been able to successfully attach.
                      Tim
                      N I 2 Replies Last reply Reply Quote 0
                      • N Offline
                        nathanh @timh
                        @timh said in Telstra LTE Cat-M Working on FiPy .... Just..:
                        Hi
                        I have the exact same, it only connects occasionally. I am starting to suspect the antenna is the issue. I notice that when I did finally achieve a connection the signal strength was between -109 to -97 which is pretty poor given I am under full cover. Also listing all the viewable cell towers only had signal ranges between -115 to -95.
                        But interestingly, when I changed the polarisation of the antenna to be vertical instead of horizontal (e.g. instead of lying the antenna flat I put it standing up using a ceramic cup), I got almost a 40db increase and when connected to a tower was getting -59db. Now this sounds good but in reality antennas made for modems should not be so sensitive to correct polarisation, this is something more for equipment running in the 400mhz band. Also, polarisation should never have such a dramatic change, especially when a 3db gain is effectively doubling the power/gain.
                        This observation tells me the antenna is not tuned correctly and while having it in a different orientation (standing up like the the letter E with an extra line haha) will give a better receive signal, it is so extreme that I expect that the transmit is still not getting out and I imagine more signal is leaking out through the connector than the actual antenna, at least on band 28. The further seems to be the case as even when I see every tower between -65db to -57db I still only occasionally connect.
                        Saying all that, happy to be told I am wrong and there is more magic button/switch/setting that will fix anything because I am dying to get this LTE working as described.
                          timh @nathanh
                          @nathanh
                          I am trying a few different antenna (which support 700-960) range to see if they make any difference, but so far no improvements. Will try and get something specific to Band 28.
                          I N 2 Replies Last reply Reply Quote 0
                          • I Offline
                            IOAg @timh
                            @timh according to Adafruit that Antenna is purpose built for LTE Band28, cf below spec.
                            Connecting my fipy to Telstra is also a hit and miss for me and I am running out of idea as to why, Telstra or Pycom firmware???
                            Specifications from Adafruit site: https://www.adafruit.com/product/3623
                            LTE band 28/38*2
                            Frequency: 703~803/2520~2620(MHz)
                            Antenna size: 75 x 21 (mm)
                            PCB 0.6 mm
                            Low bands
                            (5, 8, 12, 13, 18, 19, 20, 28)
                            Tx frequencies 699 to 915 MHz
                            Rx frequencies 729 to 960 MHz
                            Mid bands
                            (1, 2, 3, 4)
                            Tx frequencies 1710 to 1980MHz
                            Rx frequencies 1805 to 2170 MHz
                            • I Offline
                              IOAg @timh
                              @timh I have been able to attach usually few times a day, don't seem to be any reason why most of times it does not success.
                              In your implementation make sure:
                              • you call attach before you send 'AT+COPS=?' command; that command takes <10 seconds to return
                              • wait at 60 seconds for attachment by calling isattached() in a loop (don't forget sleep .5 second in there)
                              good luck.
                              T 2 Replies Last reply Reply Quote 0
                                timh @IOAg
                                @ioag
                                Yes I am sending AT+COPS?
                                But I never see True returned from isattached.
                                Often the send_at times out when sending AT+COPS?
                                Following up with something like ATI returns the output of the COPS? plus the ATI response.
                                  timh @IOAg
                                  @ioag
                                  After more testing, I am finding the following.
                                  1. Only the first call to AT+COPS=? works, though often returns with no value, and a subsequent call say ATI will return the scan results + ATI
                                    lte.send_at_cmd('ATI')
                                  This suggests we should be able to set a timeout on send_at_cmd
                                  After checking isattached for a while (loop with sleep)
                                  I check a AT+COPS again. However from then on I get errors.
                                  >>> lte.isattached()
                                  False
                                  '\r\n+COPS: ,,(0,1,2,3,4),(0,1,2)\r\n\r\nOK\r\n\r\n+CEREG: 4\r\n\r\nSEQUANS
                                  Communications\r\nVZM20Q\r\nUEUnknown\r\n\r\nOK\r\n'
                                   '\r\nSEQUANS Communications\r\nVZM20Q\r\nUEUnknown\r\n\r\nOK\r\n'
                                   '\r\n+COPS: ,,(0,1,2,3,4),(0,1,2)\r\n\r\nOK\r\n'
                                  • N Offline
                                    nathanh @timh
                                    @nathanh
                                    That's disappointing I was really hoping that might be the cause. I am still waiting for my new antenna to arrive to test here.
                                    @ioag said in Telstra LTE Cat-M Working on FiPy .... Just..:
                                    If you look around at places that sell that antenna (core, e14, rs etc), they regurgitate the exact same details however have no link to the supplier, documentation or any specsheet, radiation patterns or testing, in fact same sites even show a different picture but deliver that antenna (for example I ordered this part specifically https://au.rs-online.com/web/p/semiconductor-development-kit-accessories/1466433/?searchTerm=146-6433 and got the antenna above) and finally if you look at the Wieson site, you can't even find that antenna listed.
                                    Also when it comes to antennas, companies that don't list any documentation, specifically no spec sheet or gain reports at different frequencies is an indicator of dodgy equipment. Not saying this is the case here but the warning signs I have come to learn are definitely flagging here. Just compare any info you can find on that antenna vs a more well known company: https://www.telcoantennas.com.au/site/rfi-cd7194-3g4g4gx-mobile-antenna
                                    Looking through the firmware on github, it looks as if there is a timeout value being used (https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/mods/modlte.c) and any result is posted to a global response value. So if you requested two AT commands in succession with the first one timing out, the response may come back in a subsequent command. Which is what you (and I also) see when calling COPS. If you look around on the net you will see calling COPS does take a while and most raw AT command examples put a wait command as it can take a while. Ideally, Pycom should pass through to us the ability to set the timeout and, personally, I would remove the use of a "global" response variable and ensure the correct response is returned for the correct command, which I find odd how it is being done since they are usingf a queue mechanism with a shared variables which kinda defeats the purpose of the queue. Seems like IPC/threading 101...
                                    Trying to solve what is going on here, I try and put on my House MD hat and look at the symptoms which are:
                                    a. Can connect but appears to be random with no sure way to repeat. There appears to be no real reason why this sometimes works and sometimes doesn't. Time of day, location and signal strength to towers all seem to have no visible change on this behaviour.
                                    b. When we do connect, is it crashes the modem after some time. Leaving the modem connected after lte.connect() and doing nothing will have the modem disconnect and/or crash in a relative short time. Sending data over a socket while connected or setting lte.disconnect() after connecting/sending a payload will keep the modem alive longer but eventually will still lose cellular connection/crash.
                                    c. Trying to reset the modem and connect is hit and miss as well. lte.reset lte.deinit do not always work or if the modem is crashed has no effect. Reset often requires a full power on/off.
                                    To me this points at a few potentials:
                                    a. Bad firmware on the Sequans modem itself that is having issues talking on the LTE CAT-M network on Band 28.
                                    b. Antenna issues that are not allowing consistent/proper radiation for the signal to work
                                    c. Heat/circuitry issues with the Pycom or chips involved.
                                    d. Bad Pycom firmware. (I add this here but looking through it, there does not seem to be anything obvious wrong or unusual so I don't think it is Pycom's use of the lte library, however, more access to some of the functions and their parameters would be useful).
                                    And some of the things we can tick off are:
                                    a. The Pycom unit is clearly able (to some extent) connect to Telstra regardless of certification
                                    b. The Telstra LTE CAT-M network is actually functioning in the first place
                                    c. The SIM cards are working
                                    d. Testing in multiple locations and getting similar results would seem to indicate it is not an LTE/Band28 coverage issue
                                    My question to @daniel @seb @jmarcelino would be, have you had any success attaching the Pycom units to a real-world LTE CAT-M network on Band 28 anywhere in the world? And is there any leverage you can put on Sequans and/or Telstra to look into this issue.
                                    T 1 Reply Last reply Reply Quote 1
                                      timh @nathanh
                                      @nathanh
                                      Having read through the code an intersting observation is that
                                      lte_attach sets up explicit scanning frequencies
                                          lte_push_at_command("AT!=\"clearscanconfig\"", LTE_RX_TIMEOUT_MIN_MS);
                                          lte_push_at_command("AT!=\"RRC::addscanfreq band=3 dl-earfcn=1575\"", LTE_RX_TIMEOUT_MIN_MS);
                                          lte_push_at_command("AT!=\"RRC::addscanfreq band=4 dl-earfcn=2175\"", LTE_RX_TIMEOUT_MIN_MS);
                                          lte_push_at_command("AT!=\"RRC::addscanfreq band=12 dl-earfcn=5095\"", LTE_RX_TIMEOUT_MIN_MS);
                                          lte_push_at_command("AT!=\"RRC::addscanfreq band=13 dl-earfcn=5230\"", LTE_RX_TIMEOUT_MIN_MS);
                                          lte_push_at_command("AT!=\"RRC::addscanfreq band=20 dl-earfcn=6300\"", LTE_RX_TIMEOUT_MIN_MS);
                                          lte_push_at_command("AT!=\"RRC::addscanfreq band=28 dl-earfcn=9435\"", LTE_RX_TIMEOUT_MIN_MS);
                                      Then performs
                                        "AT+CFUN=1"
                                      Given a known country with only a single band it would seem that scanning all those frequencies is redundant.
                                      However a showphys after clearing and only setting band 28 seems to never see a different state than OFF maybe it's scanning faster.
                                      • N Offline
                                        nathanh @timh
                                        Haha, I saw the same thing last week and had the exact same thought and did the same test with the same results. Great minds? :). I also tried playing with the dl-earfcn value but did not have any luck either.
                                          timh @nathanh
                                          @nathanh Just tried the new firmware.
                                          Some observations. The only way I can get AT+COPS=? to show Telstra network is
                                           >>> lte = LTE()
                                           >>> import time
                                           '\r\nOK\r\n'
                                           '\r\nOK\r\n'
                                           >>> lte.attach()
                                           '\r\n+COPS: (1,"Telstra Mobile","Telstra","50501",7),,(0,1,2,3,4),(0,1,2)\r\n\r\nOK\r\n\r\nSEQUANS Communications\r\nVZM20Q\r\n'
                                          I have tried various other combinations but I cannot see Telstra without sending the following commands between instantiating the lte entity and calling attach
                                          Examples (each session has a power cycle resetting everything).
                                          	>>> import time
                                          	>>> lte = LTE()
                                          	'\r\nOK\r\n'
                                          	'\r\nOK\r\n'
                                          	>>> lte.attach(band=28)
                                          	>>> lte.isattached()
                                          	False
                                          	>>> Disconnected. Press any key to reconnect.
                                          	> Failed to connect (Error: Port is not open). Press any key to try again.
                                          	Connecting on COM5...
                                          	>>> lte = LTE()
                                          	>>> lte.attach(band=28)
                                          	'\r\n+COPS: ,,(0,1,2,3,4),(0,1,2)\r\n\r\nOK\r\n\r\n+CEREG: 4\r\n'
                                          	>>> lte = LTE()
                                          	'\r\nOK\r\n'
                                          	>>> lte.attach(band=28)
                                          	>>> lte = LTE()
                                          	'\r\nOK\r\n'
                                          	>>> lte.attach(band=28)
                                          	>>> lte = LTE()
                                          	'\r\nOK\r\n'
                                          	'\r\nOK\r\n'
                                          	>>> lte.attach(band=28)
                                          	>>> lte.isattached()
                                          	False
                                          N robert-hhR 2 Replies Last reply Reply Quote 0
                                          • N Offline
                                            nathanh @timh
                                            @timh that is disappointing...
                                            I am currently with clients overseas at the moment but have purchased some proper LTE antennas that have been delivered and also purchasing a separate LTE cat-m modem to compare. These will be the last things I try.
                                            Like you I am building for commercial devices and given @administrators seem to respond to every forum thread except this one and I even had a server with a device ready for them to test/play with since my first post and they still have not gotten back to me does not instill me with confidence. If I get no luck next week I will most likely go with another micro controller or the esp32 on it's own.
                                            • 1
                                            • 2
                                            • 2 / 2
