    OSError: I2C bus error
    9 Posts 4 Posters 5.3k Views 5 Watching
    • B Offline
      Baruch1966
      i2c bus: doesn't work for me.
      This is what I did:
      from machine import I2C
      i2c = I2C(0, I2C.MASTER, baudrate=100000)
      i2c.scan()
      [72] <- REPL reply
      So the system recognize the slave at address 0x72 (temp. sensor TC74)
      normally on I would request 1 bytes from slave device by writing to the slave to initiate the read sequence.
      i2c.writeto(0x72, b'1')
      On the scope with i2c protocol analyser it puts the address byte on the bus but no ACK follows (weird). Because the scan works okay it seems to be wrong with the write functions. Or do I mis something?!?
      Same slave (working) on a arduino, the code would be:
      Wire.requestFrom(72, 1);
      while(Wire.available()) temperatuur = Wire.read();
      Please help! Any suggestions?
      R G 2 Replies Last reply Reply Quote 0
        littlebat
        Have you tried just I2C.readfrom(addr, nbytes)
        • B Offline
          Baruch1966 @littlebat
          @littlebat said in OSError: I2C bus error:
          i2c.readform(0x72, b'1')
          AttributeError: 'I2C' object has no attribute 'readform'
          i2c.readform(0x72, 0x01)
          i2c.readform(0x72, 1)
            littlebat
            You spelled it wrong
            • B Offline
              Your right but also no result.
              • R Offline
                rskoniec @Baruch1966
                @Baruch1966 I think this @daniel's post should help (from thread https://forum.pycom.io/topic/265/wipy-2-0-and-bme280-sensor):
                This error occurs because the function expects a bytes object and you are trying to send an integer. Could you try with:
                i2c.writeto_mem(0x76, 0xF4, bytes([0x3F]))
                Cheers,
                Daniel
                • B Offline
                  Baruch1966 @rskoniec
                  @rskoniec said in OSError: I2C bus error:
                  Cheers,
                  Daniel
                  Solved
                  i2c.readfrom_mem(72, 0, 1)
                  b'\x19'
                  Did the trick. Manual sucks! Cost me hours of my life!!!
                    gertjanvanhethof Pybytes Beta @Baruch1966
                    @Baruch1966 The i2c.scan() is returning a integer. You need a hex value for write.
                    I tried this:
                    i2c = I2C(0)
                    i2c = I2C(0, I2C.MASTER)
                    i2c.init(I2C.MASTER, baudrate=10000)
                    i2c.scan()
                    [68] <- REPLY
                    i2c.writeto(0x44 , '1')
                    1 <- REPLY
                    • B Offline
                      Baruch1966 @gertjanvanhethof
                      @gertjanvanhethof
                      All are integers.
                      #working code for TC74 i2c temp. sensor
                      i2c = I2C(0, I2C.MASTER, baudrate=400000)
                      t = i2c.readfrom_mem(72, 0, 1)
                      print('temperature room: ', t[0])
