    ValueError: invalid join data rate 3 Lopy LORAWAN
    lopydata rateerrorloralora lopy
    29 Posts 12 Posters 7.3k Views 13 Watching
    • rubencg195R Offline
      rubencg195
      I have a problem configuring a Lopy with Lora. I update the firmware to both of my Lopys and Fipy with the country set as US to use 915 MHz. I program the Fipy as a gateway and it connected to TTN successfully, then the first Lopy and the same.
      But when uploading the same example Node program to the second Lopy it gives me this error. I took care of changing the TTN authentications keys for the second Lopy and I am sure the firmware is set for 915 MHz. I tried with both cases RTS/CTS pins connected and disconnected and didn't work niether. I also tried to change the data rate to the following 0-3(same error), 4(I hanged, had to upload firmware again), 5-6(same error).
      • sebS Offline
        seb
        Would it be possible to share all your code? or at least a link to which example you have used.
        rubencg195R 2 Replies Last reply Reply Quote 0
        • sebS Offline
          seb
          I have managed to replicate your error, I am now investigating the cause and will get back to you when I know more.
            rubencg195 @seb
            Hi @seb ,
            Sure I am going to send them to your email. Thank you very much.
              rubencg195 @seb
              @seb the link is https://docs.pycom.io/chapter/tutorials/lora/lorawan-nano-gateway.html
              • sebS Offline
                seb
                I located the cause for your issue, when we updated our LoRa stack to allow users to change regions we added this: https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/mods/modlora.c#L1664
                This was based on a recommendation in the LoRaWAN spec and I believe it will be relaxed in a future firmware update. For now just make sure when you run lora.join, you set the dr to either 0 or 4.
                  rubencg195
                  Hi @seb, the only problem is that when I put 0 gives the same error and with 4 it hangs out.
                  • sebS Offline
                    seb
                    which line of code are you changing?
                    rubencg195R 1 Reply Last reply Reply Quote 0
                      rubencg195 @seb
                      @seb line 32 where it says lora.add_channel
                      • sebS Offline
                        seb @rubencg195
                        @rubencg195
                        You need to adjust the lora.join function not the add_channel. The join has to be DR 0 or 4
                        • B Offline
                          Barillaro
                          I am having similar issue with same example published on https://github.com/pycom/pycom-libraries/blob/master/examples/lorawan-nano-gateway/otaa_node_US915.py
                          I have modified line 32 at the end like these:
                          dr=0 (hang)
                          dr=1 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 1
                          dr=2 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 2
                          dr=3 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 3
                          dr=4 (hang)
                          dr=5 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 5
                          dr=6 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 6
                          dr=7 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 7
                          dr=8 File "<stdin>", line 32, in <module> ValueError: invalid join data rate 8
                            jclo13
                            Hello @seb,
                            I have the same problem, I change the DR to 4 or 0 and the Lopy4 hangs out. Do you have a solution?
                            thank you
                              jmarcelino @jclo13
                              @jclo13
                              This is a bug expected to be fixed in the next firmware release. Sorry for the inconvenience.
                              If you are able to compile a custom firmware there is a fix already on master (compile instructions are there too)
                                Tombee @jmarcelino
                                @jmarcelino When do you anticipate the next f/w release?
                                  jmarcelino @Tombee
                                  @tombee
                                  I'm not sure sorry, maybe next week
                                    jclo13 @jmarcelino
                                    @jmarcelino do you have news about the new firmware release?
                                    thank you in advance.
                                    Jose
                                      jclo13 @jclo13
                                      I tried whit the last Pybytes firmware and it works, but the memory space is less. And it needs internet to function, right?
                                      • B Offline
                                        Burgeh
                                        Any update on how this works with the stable firmware release? (1.17.3.b1?)
                                          jclo13
                                          @Burgeh, the firmware 1.18 is already published,
                                          @jmarcelino, I updated the firmware of my lopy4, the problem mentioned before disappeared, but I have another problem, the lopy4 connect successfully whit TTN but it lost connection after the deepsleep, in other words, the lopy4 goes to deep sleep, it wakes up and it think that is connected, it send the data, the gateway receive the data, the TTN Gateway Traffic window shows the packet arrived, but the APPLICATION DATA window doesn´t show anything, if I made the connection procedure again, it shows the data again. Can you help me?, please
                                          thank you
                                          Jose.
                                          X robert-hhR F 3 Replies Last reply Reply Quote 0
                                          • X Offline
                                            Xykon administrators @jclo13
                                            @jclo13 Are you running lora.nvram_save() before going to deepsleep and lora.nvram_restore() after waking up?
                                            Christian Ehlers
                                            • 1
                                            • 2
                                            • 2 / 2
