    Updating firmware took a long time
    lopy
    6 Posts 2 Posters 1.0k Views 3 Watching
    • M Offline
      MJ
      Hi there, i am trying to update my lopy to the latest version and i follow the step in the documentation but the process of firmware download takes me around 15 min and it still not yet finish downloading. What is the problem ? Thank you
      X 1 Reply Last reply Reply Quote 1
      • X Offline
        Xykon administrators @MJ
        @mj I am assuming you are using the firmware updater? Which type and version of Operating System are you using?
        You could also try to follow these steps: https://docs.pycom.io/chapter/advance/downgrade.html even though it mentions downgrade it also works with the latest firmware version.
        Christian Ehlers
        • M Offline
          MJ @Xykon
          @xykon i am using the version of 1.1.2.b1 pycom firmware update
          • X Offline
            @mj Could you please indicate the type and version of your Operating System on the computer you are using to run the firmware updater?
            The current version of the Firmware updater is 1.12.0.b0 which you can download here: https://pycom.io/downloads/
            Christian Ehlers
            M 2 Replies Last reply Reply Quote 0
            • M Offline
              MJ @Xykon
              @xykon i am using windows 8.1, 64-bit operating system
              • M Offline
                MJ @Xykon
                @xykon Problem solved after installed the latest version of the firmware update tools
