from machine import Pin not working in WiPy 2.0
  • hi there,
    I am trying to execute following code in WiPy 2, and it is throwing and exception.
    >>> p0 = Pin(0, Pin.OUT)
    ValueError: invalid argument(s) value
    trying different ways, always same outcome.
    >>> g = machine.Pin('GP9', mode=Pin.OUT, pull=None, drive=Pin.MED_POWER, alt=-1)
    NameError: name 'machine' is not defined
    another way...
    >>> p0 = Pin(0,mode=Pin.OUT)
    I am using Atom, though I did use telnet just in case Atom is playing, still same issue.
    Current version is.
    import os
    os.uname().release
    '1.17.0.b1'
    any advise is apprecaite.
    Cheers
    ColombianBootloader
  • @seb Thanks for pointing that out.
  • @colombianaus You can use both numbering variants. The P numbers are those of the development modules, while the GP numbers are those on the expansion board, carried over from the WiPy1 model.
  • If you would prefer to use the GXX numbering you can do so like this:
    led = Pin(Pin.exp_board.G16, mode=Pin.OUT)
    From: https://docs.pycom.io/chapter/firmwareapi/pycom/machine/Pin.html#class-pinexpboard
  • @robert-hh
    hey mate,
    thank you for your advise, it worked!!. so, I am using the pycom extension board, I was wondering if you know what is the pin to pin between WiPy and the extension board. i.e G23 in the extension board is P2 for WyPy 2.0 board.
    Another question, is why on the doco uses GPXX while you use PXX to use Pin class? , XX = a number. Can I use GPXX?
    Cheers
    Colombian
  • @colombianaus You tried not all variants. How about that one:
    p0 = Pin("P10", Pin.OUT)
Hello World?
Back Us On Kickstarter >
