    Trouble with FiPy code not working
    fipycode
    33 Posts 8 Posters 9.8k Views 8 Watching
      Dylan
      I have a some new FiPys that I am trying to use the same way as I used the LoPy, therefore I am using the exact same code to run the FiPy as I did the LoPy node. For some reason the FiPy executes the code once and never repeats it like the lopy node does.
      I feel like there is something obvious that I am missing but I am yet to find it, any tips would be much appreciated.
      Cheers
        livius @Dylan
        @dylan
        without the sample i suppose no one can predict the reason
          Dylan @livius
          @livius I am using the sample code from the LoRaWAN nano-gateway docs for the node with ABP.
            Dylan @Dylan
            @dylan Looks like it isn't waking up from time.sleep or machine.deepsleep, I'll give that a google and see how it goes.
              Dylan
              Downgrading the firmware has solved the problem
                Dylan
                Not sure if coincidence or not, but straight after downgrading the firmware I get the following error in atom:
                Failed to load the Pymakr package
                Cannot find module 'serialport'
                I've tried re-installing many times to no success, I'm just going to Filezilla what I need to test over the weekend and let it be a Monday problem, but if you have any ideas whats going on there, any help would be appreciated,
                • sebS Offline
                  seb @Dylan
                  @dylan
                  Can you share the code that didnt work until you upgraded? If you dont want to share publicly you can email it to me: sebastian@pycom.io
                  As for the pymakr issue, I will pass this along to that team, they will be in touch soon.
                  • R Offline
                    Ralph
                    @Dylan Sorry about this, but Pymakr has some issues with Atom 1.25. If you are on OSX, update to todays v1.2.10 of Pymakr. For windows and linux we are still working on a fix.
                      Dylan @Ralph
                      @ralph Ok Cool, it all worked on the home computer so I managed to get a bit of work done over the weekend anyway.
                      @seb No problem, I'll put both here next post.
                        Dylan @seb
                        @seb
                        The code that worked on LoPy but not on FiPy. Worth noting that the LoPy was 1.11.0.b1 which is the version I downgraded the FiPy too.
                        Also how do I make the code look all neat in posts like I've seen elsewhere?
                        from network import LoRa
                        from pytrack import Pytrack
                        from coords import Coords
                        from CayenneLPP import CayenneLPP
                        from L76GNSS import L76GNSS
                        from LIS2HH12 import LIS2HH12
                        from machine import Pin
                        from machine import I2C
                        import binascii
                        import struct
                        import array
                        # Initialize LoRa in LORAWAN mode.
                        lora = LoRa(mode=LoRa.LORAWAN, public=1,  adr=0, tx_retries=0)
                        # Remove default channels
                        dev_addr = struct.unpack(">l", binascii.unhexlify('269928E2'.replace(' ','')))[0]
                        nwk_swkey = binascii.unhexlify('7A7E7000000F93BD1BB4693127C374FE'.replace(' ',''))
                        app_swkey = binascii.unhexlify('F93BD1BBBA53BBF3B4096A72115E9F5D'.replace(' ',''))
                        for index in range(0, 72):
                            lora.remove_channel(index)
                            lora.add_channel(index, frequency=918000000, dr_min=0, dr_max=3)
                        lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey), timeout=0)
                        # wait until the module has joined the network
                        while not lora.has_joined():
                            time.sleep(5)
                        # remove all the non-default channels
                        for i in range(8, 15):
                            lora.remove_channel(i)
                        # create a LoRa socket
                        # set the LoRaWAN data rate
                        s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
                        # make the socket blocking
                        s.setblocking(False)
                        time.sleep(2.5)
                        while lora.has_joined():
                            acc = LIS2HH12()
                            pitch = acc.pitch()
                            roll = acc.roll()
                            py = Pytrack()
                            battery = py.read_battery_voltage()
                            battery = battery * 10
                            cayenne = CayenneLPP()
                            l76 = L76GNSS(py, timeout=10)
                            lat1 = str(l76.lattitude())
                            lon1 = l76.longitude()
                            if len(lat1) > 5:
                                lona = lat1
                                lata = lon1
                                meta = 9500
                                lat = float(lona)
                                lon = float(lata)
                                met = float(meta)
                                cayenne.add_gps(4, lat, lon, met)
                                cayenne.add_temperature(3, battery)
                                s.send(cayenne.get_buffer())
                            if len(lat1) < 5:
                                print('No fix')
                            rx = s.recv(256)
                            if rx:
                                print(rx)
                            machine.deepsleep(890000)
                        • M Offline
                          MJ
                          @ralph Is the Pymakr version 1.2.10 compatible for the Atom 1.25.0 already? As until now i am unable to install the Pymakr 1.2.10 and show me failed to search for the Pymakr package " connect ETIMEDOUT 50.16.223.157.443". May i know how can i solve this? Thank you.
                            Dylan @MJ
                            @mj
                            Not sure if this will help but I just downloaded the VScode and got it running so I can do all I need to do in that.
                            https://docs.pycom.io/chapter/pymakr/installation/vscode.html
                            • M Offline
                              MJ @Dylan
                              @dylan Thanks for sharing but i am using the Atom not the Visual Studio. But until now the Pymakr still cannot installed.
                                Dylan @MJ
                                @mj I've tried lots of different things to get Atom working again with no luck, I just didn't even realize Visual studio was an option, I'm liking it so far.
                                • M Offline
                                  MJ @Dylan
                                  @dylan Is it Visual Studio code work as the same as the Atom? The language using also the same?
                                    Dylan @MJ
                                    @mj Very similar, the biggest difference I found is the Run/Upload/Download buttons are down the bottom left and I guess it all looks slightly different ofcourse.
                                    • sebS Offline
                                      seb
                                      @Dylan
                                      I would recommend adding some print statements into the code you shared to see where it gets stuck on your fipy
                                        Dylan @seb
                                        @seb Yeah I've been putting print("Line #") to catch the errors, excellent way of debugging. However in this case it makes it all the way to the end, it just never wakes back up from either the deepsleep I have above or the time.sleep(10) I use for quick testing (a print is always on the last line of code to check it makes it there).
                                        • sebS Offline
                                          seb @Dylan
                                          @dylan
                                          two things
                                          1. Code after a deepsleep will never run, once the device goes to deepsleep and wakes up it will be just like the reset button was pressed, it does not continue execution from where it went to sleep
                                          2. I see no reason why your module should lock up and not wake from deep sleep with the code sample above, Have you tried the latest firmware?
                                            Dylan @seb
                                            @seb 1. This is true, I had many prints throughout and I'm reasonably sure I thought of that haha
                                            2. This was tried on the latest firmware and pytrack updates as these were new FiPys just arrived. I've had a few things go right for me so I have a some spare time, I might update a FiPy and try to recreate the error and work from there.
                                            • 1
                                            • 2
                                            • 2 / 2
