GPIO Pins free on Gpy and Pytrack
What pins are free on a GPY/Pytrack combo. I want to use the GPS, SD Card and Battery reading only.
Is pin P4 SC_CMD and P8 SD_DAT useable when using the SD card on a Pytrack?
It would be good to have a list of "free ports" for us with GPIO.
For example with the GPY and Pytrack it seems that only the following pins are free; P9-P11and P15-P20.
Whilst on the Fipy and Pytrack combo it would be; P9-P11 and P16 only.
Also is Pin P2 free to use for input (ie monitoring a switch? It looks like it is connected to the RGB_LED
@seb it looks like the pytrack button wakes the board only if you enable the accel wake up. Since I disabled the accel wake up the button does not wake up anymore.
Can anyone can confirm this ?
The interrupt wake is on
p13. -
The pytrack button
P14is also connected toMCLRof the PIC, when the pic resets by pressing of this button it will give thePUSH_BUTTONwake reason. -
You can absolutely connect another button. you just need a button between
P14and 'GND'
@seb thanks.
Still confused on what pins I can use for a switch (interrupt/and pycom sleep wake) or power a DS18B20 only when awake.
For example;
pytrack wake reasons
WAKE_REASON_PUSH_BUTTON = 2
WAKE_REASON_INT_PIN = 8
What pins are they connected to?
Also, is the Pytrack Button pin (P14) on a PIC interrupt? Could I connect an exterior button/switch to that and have two switches do the same thing?
Many thanks.
The soon to be published improved datasheets will have a detailed explanation of the pins on each module and what they are used for but for now let me list what things are connected to in your case:
p0 - Programming
p1 - Programming
p2 - On-board LED, this might be usable in some situations but its not recommended
p3 - PWR_EN, when pulled LOW, the pytrack will disconnect the GPy's power
p4 - SD card CMD
p5 - cellular modem
p6 - cellular modem
p7 - cellular modem
p8 - SD card DAT0
p9 - free
p10 - free
p11 - free
p12 - external/on-board wifi/bt antenna switch. If you dont use either of these and disable them you can use this pin. When held high during boot it will also cause a safe boot so its use is limited.
p13 - input only, interrupt pin from Pytrack
p14 - input only, Pytrack on-board button
p15 - input only
p16 - input only
p17 - input only
p18 - input only
p19 - free
p20 - free
p21 - Pytrack SCL
p22 - Pytrack SDA
p23 - SD card clk
