    Atom terminal disappear
    atom
    9 Posts 4 Posters 2.2k Views 4 Watching
    • M Offline
      MJ
      Hi there, my atom terminal console suddenly disappear when i open the atom software. How to make the terminal console to re-appear?!
      Those "run", "upload", "download", "Connect" is disappear. How can i make it reappear again? Thanks
      • sebS Offline
        seb
        you should see it at the bottom of the window like so:
        If it has not appeared can you please check in the settings menu of atom that Pymakr is still installed and enabled?
        • M Offline
          MJ @seb
          @seb yes i checked and it is enabled and installed. Is it the Pymakr problem? I have uninstall the Atom and install the latest version 1.25.0 and install back the Pymakr Plugin version 1.0.3 which stated compatible for the Atom version. But it failed to install the Pymakr.
          • sebS Offline
            seb
            Yes we are aware of this issue. The atom team managed to beat our pymakr team with going from beta to full release. We will update pymakr shortly to support 1.25
            • M Offline
              MJ @seb
              @seb Hope it will fix for the Atom 1.25 version sooner. Thank you.
              • H Offline
                han
                @seb I reinstalled the Pymakr plugin but it didn`t worked. I keep hlding the error messages. And I am still missing the bottom bar with More, Connect & Settings bar.
                Do you have any other tips to resolve it?
                I have Atom 1.24.0 and Pymakr 1.2.10, 17.939.
                • sebS Offline
                  seb
                  @han
                  Can you try uninstalling pymakr, upgrading atom to 1.25.0 and then re-installing pymakr? This process worked for me to fix the recent compatibility issues. Also could you share what error messages you are getting?
                  • H Offline
                    han @seb
                    Thanks @seb the bottom bar back again!
                      stefan85e @MJ
                      @mj I had some problem with atom to and the plugin pymakr...
                      I did uninstall atom and remove all packed from c:\user\atom then I install atom again 1.24 then I remove the auto update and after that I run
                      cmd: and apm install pymakr@1.2.7 so it did install that version and it works perfect now :) Im happy... I would say that works perfect right now... No error or so! :)
