Random Syntax Error While Booting
Running a LoPy4 with various versions of firmware, I have seen random failures where I get a syntax error upon waking from deepsleep. I've seen it fail in different files and I know all of the files are good cause the code will run until it with core dumps or gets this syntax error and the location is always different. Anyone seeing something like this? This log is from 1.17.3 FW.
configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:1728 load:0x4009fa00,len:0 load:0x4009fa00,len:14584 entry 0x400a059c Debug print statements TRUE mem_free: 2549648 creating ody_globals SN: a45052e8 boot_monitor interval: 10 starting main: tank_main.py Tank_MAIN.PY version: 0.0.174 LORA setup: tx_power=20, spread_factor=10 Serial Number:a45052e8 SEQ 53 Sending Pkt, vals: dir_addr=-0x5bafa3bc, last_addr=0, group=0, control=0, payload_len=15, payload_type=1, seq=53, src_addr=0xa45052e8, rcv_first=0, rssi_rcv=0, checksum=-7, payload=b'\x00\x00' (rx_timestamp=0, rssi=0, snr=0.0, sfrx=0, sftx=10, tx_trials=0, tx_power=20, tx_time_on_air=206, tx_counter=1, tx_frequency=918900000) RCVD b'a45052e8a4505c4400000892003ea4505c4400000000' From GW, vals: dir_addr=0xa45052e8, last_addr=0xa4505c44, group=0, ctrl=0, payload_len=8, payload_type=146, seq=62, src_addr=0xa4505c44, directive=0, dir_value=0, rssi=-11, payload=b'' PKT RECEIVED src: b'a45052e8', dir: b'a45052e8' Response: {'success': True, 'dir_response': None} boot_monitor interval: 10 Deep sleeping: 10000 ets Jun 8 2016 00:22:57 rst:0x5 (DEEPSLEEP_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:1728 load:0x4009fa00,len:0 load:0x4009fa00,len:14584 entry 0x400a059c Debug print statements TRUE mem_free: 2549648 creating ody_globals SN: a45052e8 boot_monitor interval: 10 starting main: tank_main.py Tank_MAIN.PY version: 0.0.174 LORA setup: tx_power=20, spread_factor=10 Serial Number:a45052e8 SEQ 54 Sending Pkt, vals: dir_addr=-0x5bafa3bc, last_addr=0, group=0, control=0, payload_len=15, payload_type=1, seq=54, src_addr=0xa45052e8, rcv_first=0, rssi_rcv=0, checksum=-8, payload=b'\x00\x00' (rx_timestamp=0, rssi=0, snr=0.0, sfrx=0, sftx=10, tx_trials=0, tx_power=20, tx_time_on_air=206, tx_counter=1, tx_frequency=918900000) RCVD b'a45052e8a4505c44000008920036a4585c4400000000' From GW, vals: dir_addr=0xa45052e8, last_addr=0xa4505c44, group=0, ctrl=0, payload_len=8, payload_type=146, seq=54, src_addr=0xa4585c44, directive=0, dir_value=0, rssi=-13, payload=b'' PKT RECEIVED src: b'a45052e8', dir: b'a45052e8' Response: {'success': True, 'dir_response': None} boot_monitor interval: 10 Deep sleeping: 10000 ets Jun 8 2016 00:22:57 rst:0x5 (DEEPSLEEP_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:1728 load:0x4009fa00,len:0 load:0x4009fa00,len:14584 entry 0x400a059c Debug print statements TRUE mem_free: 2549648 creating ody_globals SN: a45052e8 boot_monitor interval: 10 starting main: tank_main.py Traceback (most recent call last): File "main.py", line 9, in <module> File "tank_main.py", line 17, in <module> File "/flash/lib/pack_data.py", line 85 SyntaxError: invalid syntax MicroPython v1.8.6-849-83e2f7f on 2018-03-19; LoPy with ESP32 Type "help()" for more information. >>> -
Could you share you code?
@ssmith What do you power your LoPy with? There's a spike in current draw during boot, and not all batteries / power supplies are able to cope with that, this may result in random behaviour.
@jcaron It's powered off of my desktop Windows 10 PC. It's most likely a timing issue in the FW. My guess would be that during the import a read value is getting corrupted. I know there is no syntax error in the code. the same code can run for a week with a deepsleep reboot every 30 seconds.
