    ImportError: no module named 'MySQLdb'
    mysqlpymakrlopydatabase
    6 Posts 3 Posters 1.6k Views 3 Watching
    • F Offline
      Fajriansyah
      I use pymakr to connect my LoPy with MySQLdb but there is error ( ImportError: no module named 'MySQLdb' ) what am I suppose to do?
      my code is:
      import MySQLdb
      db = MySQLdb.connect(host="localhost", # your host, usually localhost
      user="root", # your username
      passwd="", # your password
      db="solarchargermonitoring") # name of the data base
      you must create a Cursor object. It will let
      you execute all the queries you need
      cur = db.cursor()
      Use all the SQL you like
      cur.execute("SELECT * from regisperangkat")
      print all the first cell of all the rows
      for row in cur.fetchall():
      print(row)
      db.close()
      J L 2 Replies Last reply Reply Quote 0
        jcaron @Fajriansyah
        @fajriansyah you most certainly won’t be running a MySQL server on a LoPy, and I’m not sure there are any scenarios where it would make sense to connect directly to one from a LoPy either. Calling a webservice or sending data over LoRa to a server which would in turn connect to a MySQL database would probably make more sense.
        What exactly are you trying to achieve?
          livius @Fajriansyah
          @fajriansyah
          You probably mismatch things
          on Lopy you have micropython not full python because hardware resources are too limited.
          F 1 Reply Last reply Reply Quote 0
          • F Offline
            Fajriansyah @livius
            @livius @jcaron sorry, I mean lopy will connect with my database (local host). Can it?
            • F Offline
              Fajriansyah
                livius @Fajriansyah
                @fajriansyah
                I do not know if some "minimal" client exists for micropython. But is it required?
                Better run some listen socket on your server. And then your Lopy will send messages to this socket and it connect to jour database and store there data. It can be e.g. windows service apllication, webserver application e.g. on IIS, Apache + php ....
