    Multitech conduit and Lopy "Not joined yet"
    lopymultitechconduitfailureconnect
    22 Posts 5 Posters 6.8k Views 5 Watching
    • M Offline
      MOnsteroz
      Hi guys,
      I am new here and am looking for some help with connection of my Lopy. I have done a trial connection with a Multitech Mdot and it works fine but when i configure a Lopy OTAA I can see it listed on the conduit as a node but the Lopy continues to print "Not joined yet". any ideas??
      import binascii
      from network import LoRa
      # Colors
      off = 0x000000
      red = 0xff0000
      green = 0x00ff00
      blue = 0x0000ff
      # Turn off hearbeat LED
      # Initialize LoRaWAN radio
      # lora = LoRa(mode=LoRa.LORAWAN)
      # Initialize LoRa in LORAWAN mode.
      # Asia = LoRa.AS923
      # Australia = LoRa.AU915
      # Europe = LoRa.EU868
      # United States = LoRa.US915
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
      # dev_addr = struct.unpack(">l", binascii.unhexlify('00 00 00 05'.replace(' ','')))[0]
      # Set network keys
      app_eui = binascii.unhexlify('1122334455667788')
      app_key = binascii.unhexlify('11112222333344445555666677778888')
      # Join the network
      #lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=600)
      pycom.rgbled(green) # green
      # Loop until joined
      while not lora.has_joined():
          print('Not joined yet...')
          pycom.rgbled(off)
          time.sleep(0.1)
          pycom.rgbled(red)
          time.sleep(2)
      print('Joined')
      pycom.rgbled(blue)
      s.setblocking(True)
      i = 0
          count = s.send(bytes([i % 256]))
          print('Sent %s bytes' % count)
          pycom.rgbled(green)
          time.sleep(0.1)
          pycom.rgbled(blue)
          time.sleep(9.9)
          i += 1
      J J 2 Replies Last reply Reply Quote 0
        jcaron @MOnsteroz
        @monsteroz please edit your post and add ``` on a line before and after your code so it’s properly formatted.
          robert-hh
          @monsteroz May I assume that you registered your application and device beforehand and inserted the proper app_eui and app_key in the script?
          I have a FiPy here that joins properly. The join statement is:
          lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=config.LORA_NODE_DR)
          But the difference are default values.
          M 2 Replies Last reply Reply Quote 0
          • M Offline
            MOnsteroz @robert-hh
            @robert-hh The values in the script are correct as this is just a testbed to get things working. I did not use the Dev_eui as I read it will use a default address. What does the " dr=config.LORA_NODE_DR) " do?
            Cheers
            Sean
            • M Offline
              MOnsteroz @jcaron
              @jcaron someone fixed it for me ????
              • M Offline
                @robert-hh
                Hi this is the config and the history
                  robert-hh @MOnsteroz
                  @monsteroz said in Multitech conduit and Lopy "Not joined yet":
                  It sets the data rate, and in my example it is set to 5.
                  • M Offline
                    @robert-hh Thanks Robert. I am still getting my head around Lora :)
                      @monsteroz I do not understand all the settings, but some comments.
                      • The xxPy software has problems with the RX2 window, so always the RX1 should be used.
                      • The OTAA join delay is 5 seconds.
                        I'm still at the beginning too, starting with LoRa a few weeks ago.
                          jcaron @robert-hh
                          @robert-hh Never had an issue with RX2 on the receiving side. What kind of issue are you seeing?
                          robert-hhR M 2 Replies Last reply Reply Quote 0
                            robert-hh @jcaron
                            @jcaron There were complaint about the in another thread.
                              jmarcelino @MOnsteroz
                              @monsteroz
                              Ok some problems...
                              In the AU915 region need to restrict the LoPy to what your gateway is set to:
                              Frequency Sub-Band 4
                              Because as configured the LoPy expects to use all valid 72 channels. However most real world gateways are limited to only 8 channels, hence the full channel map is partitioned into subbands.
                              So add a function like this
                              def select_subband_au915(lora, subband):
                                  if (type(subband) is int):
                                      if ((subband<1) or (subband>8)):
                                          raise ValueError("subband out of range (1-8)")
                                      raise TypeError("subband must be 1-8")
                                  for channel in range(0, 64):
                                      lora.remove_channel(channel)
                                  for channel in range((subband-1)*8, ((subband-1)*8)+8):
                                      lora.add_channel(channel, frequency=915200000+channel*200000, dr_min=0, dr_max=5)
                              the call select_subband_au915(lora, 4) to remove all channels which don't belong to sub-band 4 after initialising your LoRa object (and before joining)
                              • M Offline
                                MOnsteroz @jcaron
                                @jcaron
                                The Lopy and Lopy4 just does not exit the loop and says "not joined yet."
                                • M Offline
                                  MOnsteroz @jmarcelino
                                  @jmarcelino Hi,
                                  If I lock it to sub band 4 it seems to just hang
                                  If I add the below I get the same 'Not joined yet" message
                                  # Join the network
                                    Thanks @monsteroz
                                    I'm not an expert on Multitech but I think your "Join Delay" isn't according to the specification.
                                    That should be 5 (seconds) as Robert already pointed out. Did you change it already?
                                    Do keep the sub channel selection code. That's also necessary, but not sufficient.
                                    • M Offline
                                      @jmarcelino
                                      I did not change the Join Delay but I have now changed it to 5 seconds with no change
                                      thanks
                                      Sean
                                      • M Offline
                                        MOnsteroz
                                        Hi guys,
                                        I reset to factory setting on the conduit and just added ID nd Key .. still no luck with the lopy..
                                        Sean
                                          @monsteroz
                                          Can you post what are you current gateway settings please?
                                          • M Offline
                                            @jmarcelino
                                            Hi I have been changing settings to try and make it work but here is what it is at the moment. I have changed to FSB 2 in case I want to use the TTN in the future.
                                            Cheers
                                            • 1
                                            • 2
                                            • 1 / 2
