Unpack and Pack
Hi there, i want to pack a float in the node and send it over to the gateway. May i know is the format valid?
_LORA_PKG_FORMAT = "BBf" #1byte for device_id, 1 byte for package size, 1 for float
Here is the information that i want it to be pack as a float at Node
D = 10**((Measured_power-rssi)/(10*n)
pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), DEVICE_ID, len(msg), D) lora_sock.send(pkg)
Here is the information that unpack at Gatewaydevice_id, pkg_len, D = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
I tried this format but i have no received anythings from the node and i tried the example of the Lora Nano-gateway in documentation and it work so i guess is not the firmware problem since i have all lopy updated to the same version.
Any help would be appreciate. Thank you.
@mj SInce the for string for pack contains only two fields, it must be written as:
_LORA_PKG_FORMAT = "Bf" pkg = struct.pack(_LORA_PKG_FORMAT, DEVICE_ID, D)But besides that, the receiver must contains a lora_sock.recv(64) call, in order to get something. Please have a look at the simple examples in the documentation on how the code structure has to be set up.
@robert-hh
I have tried but still showing no response once i uploaded the code.On my Node :
_LORA_PKG_FORMAT = "Bf" DEVICE_ID = 0x01 lora = LoRa(mode=LoRa.LORA, tx_iq=True, frequency = 915000000) lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW) lora_sock.setblocking(False) Measured_power = -37 n = 3 d = (10**((Measured_power-rssi)/(10*n)))/1000 pkg = struct.pack(_LORA_PKG_FORMAT, DEVICE_ID, 6, D) lora_sock.send(pkg)For Gateway :
_LORA_PKG_FORMAT = "Bf" lora = LoRa(mode=LoRa.LORA, rx_iq=True, frequency = 915000000) lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW) device_id, D = struct.unpack(_LORA_PKG_FORMAT, recv_pkg)Is there any mistake? Thank you.
@mj said in Unpack and Pack:
Since you have a fixed message length, you can simply use:
struct.pack(FORMAT, DEVICE_ID, 6, D)
and unpack with:
device_id, pkg_len, D = struct.unpack(_LORA_PKG_FORMAT, recv_pkg)
You can even omit sending the pkg_len and pack with:_LORA_PKG_FORMAT = "Bf" #1byte for device_id, 4 for float D = 10**((Measured_power-rssi)/(10*n) pkg = struct.pack(_LORA_PKG_FORMAT, DEVICE_ID, D) lora_sock.send(pkg)and unpack with:
