    Advice on waking up the LoPy4
    lopy4low powerinterrupt
    3 Posts 2 Posters 910 Views 3 Watching
    • dwsD Offline
      dws
      I'm building a device that will have a button that activates the LoPy to send a short LoRa transmission. The device must run on non-rechargeable, inexpensive battery for at least a couple of years. The button will only be pushed under unusual emergency circumstances, which means probably never. The device will have to wake up every hour to send a transmission signifying it is still working. So the battery will be expended by these hourly transmissions, not by the pushbutton. I want the system to go into ultra-low-power mode when it's not transmitting. What's the best approach to this? I've heard that maybe a real time clock can do the hourly wakeup, and that the pushbutton could apply Vcc to an interrupt to wakeup the device as well. Is this the case? Thanks.
        jcaron
        On the LoPy 4, you can just use machine.pin_deepsleep_wakeup() and machine.deepsleep() to achieve exactly that.
        Not sure you can really last a couple of years like that though. Also you need a battery capable of delivering the current spike required during boot, and need to take into account battery self-discharge. Settings of the LoRaWAN network can also adversely affect how long the battery will last.
        dwsD 1 Reply Last reply Reply Quote 0
        • dwsD Offline
          dws @jcaron
          @jcaron Ok thanks, appreciate the response and will keep all this in mind. Might reduce the frequency of the call-in's to once a day which of course would decrease power consumption appreciably.
