TypeError: 'module' object is not callable
Hi everybody
I am new here to use the deep sleep shield. I add the deepsleep.py in the library and sync the project. I don't know if it's right and I am very confused this process:
You can see the deepsleep.py file is in the left side of my screenshots.
The problem is always: TypeError: 'module' object is not callable!
import pycom import time from machine import Pin, Timer from deepsleep import DeepSleep echo = Pin(Pin.exp_board.G7, mode=Pin.IN) trigger = Pin(Pin.exp_board.G8, mode=Pin.OUT) # Colors different color stand for different state off = 0x000000 red = 0xff0000 green = 0x00ff00 blue = 0x0000ff # Turn off hearbeat LED pycom.heartbeat(False) #enable the deepsleep ds = DeepSleep() trigger(0) chrono = Timer.Chrono() while True: ds.go_to_sleep(60) # go to sleep for 60 seconds print("Wake up") chrono.reset() trigger(1) time.sleep_us(10) trigger(0) while echo() == 0: pass chrono.start() while echo() == 1: pass chrono.stop() distance = chrono.read_us() / 58.0 if distance > 400: print("Out of range") else: print("Distance {:.0f} cm".format(distance)) time.sleep(1)
This error statement TypeError: 'module' object is not callable is raised as you are being confused about the Class name and Module name. The problem is in the import line . You are importing a module, not a class. This happend because the module name and class name have the same name .
If you have a class "MyClass" in a file called "MyClass.py" , then you should import :
from MyClass import MyClass
In Python , a script is a module, whose name is determined by the filename . So when you start out your file MyClass.py with import MyClass you are creating a loop in the module structure.
In Python, everything (including functions, methods, modules, classes etc.) is an object , and methods are just attributes like every others. So,there's no separate namespaces for methods. So when you set an instance attribute, it shadows the class attribute by the same name. The obvious solution is to give attributes different names.
@jcaron Thank you. I tried but still like this, I don't know why it's so complicated.
I run the deepsleep.py and there is no action in the console, if the deepsleep code is right. I downloaded from there.
https://github.com/pycom/pycom-libraries/tree/master/deepsleep
@nathanh Thaks. I tried. It still the same problem.
Would it be because you have the directory as /Lib instead of /lib (i.e. try using lowercase).
The errors do not seem to be very consistent. Note that Pymakr uploads files it knows about but it can leave odd stuff on the module's filesystem.
I recommend you either use FTP to check that you only have the files required, or clear the flash and then re-upload with Pymakr, it should help.
Also, don't add all those other files in lib, you'll end up with issues.
@rachelsimida if you type in the REPL prompt:
from deepsleep import DeepSleep dir (DeepSleep)
What do you get as output?
@jcaron I tried but still fail.
I believe you should have deepsleep.py directly in the lib folder, not a subfolder.
This is my device.
