Guru meditation error
At random intervals I notice that my wipy/pytrack board reboots. I finally managed to get the core dump (this is another core dump than the one I posted yesterday when doing FTP)
The error I get is below.
How do I interpret this to find where the problem is in my code?Guru Meditation Error: Core 1 panic'ed (Unhandled debug exception) Debug exception reason: BREAK instr Register dump: PC : 0x400803c0 PS : 0x00060036 A0 : 0x00000000 A1 : 0x3ffe94d0 A2 : 0x3ffe972c A3 : 0x3ffdd82c A4 : 0x00000000 A5 : 0x0000ff00 A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00060023 A9 : 0x00000000 A10 : 0x00000004 A11 : 0x7fffffff A12 : 0x80089c57 A13 : 0x3ffd93d0 A14 : 0x00000003 A15 : 0x00060023 SAR : 0x0000001e EXCCAUSE: 0x00000001 EXCVADDR: 0xffffffd0 LBEG : 0x40099934 LEND : 0x40099962 LCOUNT : 0x00000000 Backtrace: 0x400803c0:0x3ffe94d0 0x7ffffffd:0x00000000Also, after rebooting: the main.py seems not to work anymore
Unhandled exception in callback handler Traceback (most recent call last): File "main.py", line 370, in launchWriters NameError: name 'dispatcher' is not definedIf I reset the board (via the button), It starts up again and runs normally until the next random crash (sometime a few minutes later, sometimes hours later).
I can provide the entire core dump
system: (sysname='WiPy', nodename='WiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='WiPy with ESP32')
Im sorry if I accidentally ignored your coredump post. You notice that this post is from 2018 and that there is no added value in solving this issue anymore right?Now, let me start by mentioning it is never okay for the controller to present a coredump and they should be avoided at all costs.
The issue with these coredumps is that they can have a variety of reasons, and that debugging them takes a lot of effort, as I need to know the exact firmware version used (incl development board version), the coredump parameters (top section) and it is very useful to see the python code and learn about its workings and when it breaks (if it breaks at the same location every time). Even then, it is still a wild goose chase. There can be many reasons for a coredump (including inadequate power supply, incorrect use of threading, firmware errors etc.)
What we can do, is provide you with better tools to research the coredump and I will be working on that. Note that I have already started a documentation page here: https://docs.pycom.io/advance/coredump/, but I want to do better. Please let me know how we can improve the situation!
Best,
Why is it that admins and official tech support @ pycom never really answer these questions? Do they not understand that many people get these same problems and then leave in disgust and eventually abandon their projects or find another chip? Or do they just not care?
I'm getting a very similar issue, at least for me it appears to be an issue with multi-threaded code. I've tried writing my code both with and without threading and I only have this issue on the threaded version.
I'll try to put together an MCVE if I have time so that hopefully this can get fixed.
@seb
Found anything interesting?
Is there a good resource that explains how I can decode it myself. This is something I haven't done before.
Guru Meditation Error: Core 1 panic'ed (Unhandled debug exception) Debug exception reason: BREAK instr Register dump: PC : 0x400803c0 PS : 0x00060036 A0 : 0x00000000 A1 : 0x3ffe94d0 A2 : 0x3ffe972c A3 : 0x3ffdd82c A4 : 0x00000000 A5 : 0x0000ff00 A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00060023 A9 : 0x00000000 A10 : 0x00000004 A11 : 0x7fffffff A12 : 0x80089c57 A13 : 0x3ffd93d0 A14 : 0x00000003 A15 : 0x00060023 SAR : 0x0000001e EXCCAUSE: 0x00000001 EXCVADDR: 0xffffffd0 LBEG : 0x40099934 LEND : 0x40099962 LCOUNT : 0x00000000 Backtrace: 0x400803c0:0x3ffe94d0 0x7ffffffd:0x00000000 ================= CORE DUMP START ================= KE4AABYAAABsAQAA KNj9PxCU/j/wl/4/ QJT+P5CX/j9vWdkAlE/8P5RP/D8o2P0/jE/8PxQAAAAUYPw/FGD8PyjY/T8AAAAA BQAAAPSD/j9NUFRocmVhZAABwKgEAgMAAQAAAPCX/j8AAAAAIAgGAAUAAAACAAAA AAAAACyX/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAi0ADw== AQAAAMADCEA2AAYAAAAAANCU/j8sl/4/LNj9PwAAAAAA/wAAAAD/AAAAAP8jAAYA AAAAAAQAAAD///9/V5wIgNCT/T8DAAAAIwAGAB4AAAABAAAA0P///zSZCUBimQlA AAAAAFecCIDQk/0/0DEIQATy+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAATy+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAP4AAADAk/4/AAAAACSlCIBnRQ+A4JX+P+CW/j/EMpU/ 2VQPgDCV/j8YpUA/eK5APwAAAABgAAAAAAAAAAAAAADdRA+AUJX+PwIAAADQMpU/ AgAAAAIAAAABAAAALhMAAHQOD4Bwlf4/xFQPQAIAAAAA95Q/AgAAAAAAAABQz0A/ 3A4PgKCV/j9cr0A/AgAAAAAAAADIMpU/5F/8PwEAAAAAAAAA0DKVPwEAAAC2CgAA aMIPgMCV/j8BAAAAAAAAAAAAAADQMpU/AQAAAF4UAABnRQ+A4JX+PwgAAACyypU/ zDKVPzQzlT8AAAAAAQAAAHQOD4CAlv4/gF78P4Be/D/glv4/gAiVP2dFD4Dglf4/ 4Jb+P8QylT8QCpU/KDOVP+/KlT+xAAAApaWlpaWlpaWlpaWlpaWlpXQOD4CAlv4/ gF78P4Be/D/2tA+AG8qVPw8AAAAIAAAANDOVPwAAAAAAAAAAoDKVP/gylT/0MpU/ DgAAAPj3lD8AAAAAAAAAAMwylT8AAAAAMP///7PKlT9+sg+AwJb+P7ANlT8AAAAA AsqVPwAAAAAAAAAAAAAAAAAAAAD495Q/AAAAAAAAAACgMpU/hAAAAA8AAACAlv4/ zNANgOCW/j8AAAAA4PeUPwAAAAD495Q/CJf+P2CX/j8AAAAAcJf+P+D3lD8AAAAA AAAAAAAAAADM0A2A4Jb+PwAAAADg95Q/IwAGAAAAAAAEAAAA////fwAAAAAAAAAA AAAAAAAAAAAAAAAAcJf+P+D3lD8AAAAAbbIPgIBe/D+AXvw/4Jb+P0CX/j8AEAAA 4PeUPwAAAAAAAAAAAAAAAOD3lD8AAAAABAAAAP///38AAAAAkJf+PwAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAJyX/j8AAAAA gAAAAAAAyELNzMw9AAB6RADESLKAlhjAMKGzNZW/1nYAwJ93NCXsugAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA= QEX9P8BD/T84Rf0/ wEP9P9BE/T9DQ5ARvEr9PzBP/D9ARf0/KE/8PxkAAABhqy+0R/AlA0BF/T8AAAAA AAAAADxB/T9JRExFAEBGvI5As6mzCDQAAAAAADhF/T8AAAAAIQAGAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADJc9w== xDIIQMQ6FEAwBgYA/LIIgIBE/T8gAAAAAQAAAAAAAAC0kPw/HFH8P8RO/D/QkPw/ MzMzAwAAAABQDwAAAAAAAFDW+z8DAAAAIwAGAAoAAACYXPw/AAAAAOBlDkAcZg5A AAAAAL00CEBQ1vs/SMAIQESf+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABQ1vs/AwAAACMABgAAAAAAoET9PwAAAAAAAAAA AAAAALSQ/D8cUfw/xE78PwAAAADQRP0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA AQAAAAAAAAAEAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANxE/T8AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA== tEr9PzBJ/T+sSv0/ MEn9P0BK/T/LaPHHME/8P0hF/T+0Sv0/KE/8PxkAAADGuxumk4A0c7RK/T8AAAAA AAAAALBG/T9JRExFALycrqaYoTWirL4AAQAAAKxK/T8AAAAAIwAGAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAILGXw== xDIIQMQ6FEAwBAYA/LIIgPBJ/T8gAAAAAQAAACAAAAC0kPw/IFH8P8RO/D/wkPw/ AQAAAAAAAAD///9/V5wIgDBq/j8DAAAAIwAGAAAAAADwSf0/IAAAAAAAAAAAAAAA AAAAAL00CEAwav4/SMAIQLSk+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAEEr9PwAAAAABAAAA AQAAAAQZ/D8gUfw/xE78PwAAAABASv0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAExK/T8AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA= pE39P3A1/T9QN/0/ cDX9P/A2/T+DWdkAUNX9P2Q//T+kTf0/FE/8PwcAAAAYmf0/GJn9P6RN/T8Qmf0/ EgAAAFQp/T90aVQAdADYAU/dtl/w/v0A////f1A3/T8AAAAAIQAGABIAAAABAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKav1w== xDIIQCSlCEAwBAYASdIVgDA2/T/smP0/wDb9PziZ/T8AAAAAQJn9PwAAAAAkpQiA EDb9PwAAAABkAAAAHFH8PwAAAAAEGfw/AAAAABAAAABkkfo/AAAAAC29FUA2vRVA AAAAAL00CEAAAAAASMAIQGSR+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAEA2/T8gNv0/DAAAAEjACECNVxWAcDb9P8ST/D/ANv0/ AAAAAB9Z2QAUTv0/AAG8P2QAAAAAGAAAAQAAAAAAAACYVxWAgDb9PwAAAACIOAhA Y+IUgKA2/T/Ek/w/wDb9P2PiFICgNv0/xJP8P8A2/T9kAAAAH1nZAPb///8BAAAA AAAAAMA2/T/86hVAAAAAAGCa/D9YVhVAAAAAABxR/D8AAAAA8Db9PwAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAD8Nv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA SNX9P1Bs/j/ob/4/ UGz+P4Bv/j8EWtkAwNb9P6xN/T9I1f0/FE/8PxQAAACQdvs/kHb7P0jV/T8AAAAA BQAAAOxb/j9NUFRocmVhZABsAG8AZwAAAQAAAOhv/j8AAAAAIQAGAAUAAAAAAAAA AAAAABxv/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAi0ADw== xDIIQGyyCEAwBAYAQdUNgBBt/j8EWtkAIFH8PwQZ/D8BAAAAAwAAAEAAAABssgiA 8Gz+PwEAAAAEWtkASNX9PwEAAAD+AAAAAAAAAB4AAAC10Q2A0Gz+PxibCUAjmwlA AAAAAL00CEABAAAASMAIQPTJ+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAADRg/D8AAAAAAQAAAAAAAAA6OhCAMG3+P5YAAADkX/w/ PF78P/////8DAAAAQAAAAFhED4BQbf4/AAB6RAAAAAABAAAAAQAAANhs/j9Abf4/ dA4PgHBt/j+kSkE/AQAAAAEAAAABAAAAAAAAAEYMAADcDg+AkG3+P6RKQT8BAAAA AAAAALTslD8PAAAAUG3+P2jCD4Cwbf4/AQAAAAAAAAAAAAAAtOyUPwEAAAAWDQAA Z0UPgNBt/j8IAAAAfsiVP6zslD8BAAAAAAAAAAEAAAB0Dg+AcG7+P4Be/D+AXvw/ 0G7+PwAAAABnRQ+A0G3+P9Bu/j8OAAAA5OyUPwAAAADg7JQ/AAAAAAUAAAAAAAAA paWlpaWlpaV0Dg+AcG7+P4Be/D+AXvw/9rQPgNhu/j8OAAAAAwAAAPDslD8AAAAA AAAAAJDslD/k7JQ/4OyUPw0AAAAYMZU/AQAAAAAAAACs7JQ/AAAAADD///9/yJU/ frIPgLBu/j+gDZU/AAAAAKLHlT8AAAAAAAAAAAAAAAAAAAAAGDGVPwAAAAAAAAAA kOyUP1wAAAAOAAAAcG7+P8zQDYDQbv4/AAAAAAAxlT8AAAAAGDGVP/hu/j9Qb/4/ AAAAAGBv/j8AMZU/AAAAAAAAAAAAAAAAzNANgNBu/j8AAAAAADGVPyMABgAAAAAA BAAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAAGBv/j8AMZU/AAAAAG2yD4CAXvw/ gF78P9Bt/j8wb/4/ABAAAAAxlT8AAAAAAAAAAAAAAAAAMZU/AAAAAAQAAAD///9/ AAAAAIBv/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAAAAACMb/4/AAAAAIAAAAAAABZDmpkZPgAAekQAxEiygJYYwDChszWVv9Z2 AMCfd+JqHLsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA= uNb9P1CA/j/sg/4/ UID+P4CD/j9GWtkAHE/8P1DV/T+41v0/FE/8PxQAAACQdvs/kHb7P7jW/T8AAAAA BQAAAPBv/j9NUFRocmVhZAAANwA5ADQAAQAAAOyD/j8AAAAAIQAGAAUAAAAAAAAA AAAAAByD/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ== xDIIQGyyCEAwDAYAQdUNgBCB/j9GWtkAIFH8PwQZ/D8BAAAAiIVAP1h3QD9ssgiA 8ID+PwEAAABGWtkAuNb9PwEAAAD+AAAAAAAAAB4AAAC10Q2A0ID+PyCoDkBMqA5A oG8CAL00CEABAAAASMAIQPTd+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAADRg/D8AAAAAAQAAAAAAAAA6OhCAMIH+P8gAAADkX/w/ AAAAAAEAAACIhUA/WHdAP1hED4BQgf4/AAB6RAAAAAABAAAAAQAAAIzPlT89AAAA dA4PgHCB/j+kSkE/AQAAAAEAAAABAAAAAAAAAEYMAADcDg+AkIH+P6RKQT8BAAAA AAAAAJT7lD8JAAAAUIH+P2jCD4Cwgf4/AQAAAAAAAAAAAAAAlPuUPwEAAAAWDQAA Z0UPgNCB/j8IAAAAps6VP4z7lD+o+5Q/AAAAAGCC/j90Dg+AcIL+P4Be/D+AXvw/ 0IL+PwAAAABnRQ+A0IH+P9CC/j8MAAAAvPuUPwAAAAC4+5Q/AAAAAAUAAAAAAAAA paWlpaWlpaV0Dg+AcIL+P4Be/D+AXvw/9rQPgNiC/j8MAAAAAwAAAMj7lD8AAAAA AAAAAHD7lD+8+5Q/uPuUPwsAAAA4MZU/AQAAAAAAAACM+5Q/AAAAADD///+nzpU/ frIPgLCC/j/ADZU/AAAAACLOlT8AAAAAAAAAAAAAAAAAAAAAODGVPwAAAAAAAAAA cPuUP1QAAAAMAAAAcIL+P8zQDYDQgv4/AAAAACAxlT8AAAAAODGVP/iC/j9Qg/4/ AAAAAGCD/j8gMZU/AAAAAAAAAAAAAAAAzNANgNCC/j8AAAAAIDGVPyMABgAAAAAA BAAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAAGCD/j8gMZU/AAAAAG2yD4CAXvw/ gF78P9CB/j8wg/4/ABAAACAxlT8AAAAAAAAAAAAAAAAgMZU/AAAAAAQAAAD///9/ AAAAAICD/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AQAAAAAAAACMg/4/AAAAAIAAAAAAAEhDzcxMPgAAekR4/1Yy2w9JwHj/VjKD+aJW AMCfV91L5bkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA XD/9P/A9/T9UP/0/ 8D39P/A+/T+AWdkArE39PxxP/D9cP/0/FE/8PxQAAAD8dvs//Hb7P1w//T8AAAAA BQAAAFg3/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAFQ//T8AAAAAIQAGAAUAAAAAAAAA HNv7PwAAAACINA1AAAAAAAsAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA== xDIIQGyyCEAwAAYAH84NgLA+/T+AWdkAIFH8PwQZ/D8BAAAAHwAAAKyv/T9ssgiA kD79PwEAAACAWdkAXD/9PwEAAAD+AAAAIwAGAAQAAACbig6AcD79PzSZCUBimQlA /////700CEABAAAASMAIQGSZ+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAFw//T8BAAAA/gAAACMABgAAAAAA0D79PwAAAAABAAAA +ExAPwEAAAAfAAAArK/9PwAAAADwPv0/AAAAAAAAAAAAAAAAAQAAAM5W/D8AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/D79PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAA= JEz9P2Bf/T+4YP0/ YF/9P1Bg/T8AAAAACE/8PwhP/D8kTP0/AE/8Pw8AAADwVf0/8FX9PyRM/T/oVf0/ CgAAALxW/T9UbXIgU3ZjAArV4F8MQVQAAAAAALhg/T8AAAAAIQAGAAoAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHU+ew== xDIIQJm+CEAwAAYAAAAAACBg/T8AAAAAAAAAAAAAAAAsUfw/JFH8PwkAAACZvgiA AGD9PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAL00CEAAAAAASMAIQMS6+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAMS6+j8AAAAAAAAAAAAAAAAAAAAAUGD9PwAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAABcYP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA= 5Cf9PzAm/T/cJ/0/ MCb9P3An/T+Ua5HeqHn7P3gi/T/kJ/0/pE78PwEAAABAVf0/QFX9P+Qn/T84Vf0/ GAAAAOAj/T9pcGMxAIQfm79hxtPs3IcAAQAAANwn/T8AAAAAIQAGABgAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEw23Q== xDIIQDIUCEAwBAYAJKUIgPAm/T8BAAAA/////yBR/D8BAAAABBn8PyADBgAyFAiA 0Cb9P+AA8D8BAAAAuBj8PwEAAAD+AAAAIwAGAAAAAADwJv0/AQAAAAAAAAAAAAAA AAAAAL00CEABAAAASMAIQOSB+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAD8HAiAECf9PxRV/T8AAAAA IFH8PwEAAAAEGfw/IAMGAAAAAABQJ/0/BE78PwAAAAAAAAAAQhUAAAAAAAAgAwYA /////wAAAAAETvw/8E38P2BV/T8AAAAAFFX9PwAAAAAAAAAAcCf9PwAAAAAAAAAA 9EoIQAEAAAAAAAAAAAAAAGESCICAff4/AQAAAAAAAAAAAAAAAAAAAHwn/T8AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA= oHn7P5D3/T9I+f0/ kPf9P+D4/T8AAAAAbBr+P+wn/T+gefs/pE78PwIAAABsefs/bHn7P6B5+z9kefs/ FwAAAEzp/T9idENvbnRyb2xsZXIAAAAAAAAAAEj5/T8AAAAAIQAGABcAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAG7N2g== xDIIQCSlCEAwAAYAEWwIgFD4/T9Aefs/sPj9P4x5+z8AAAAAlHn7PwAAAAAkpQiA MPj9PwAAAAD/////HFH8PwAAAAAEGfw/AAAAABsAAAC0+vo/FAwAADSZCUBimQlA /////700CEAAAAAASMAIQFRT+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABo/fo/zJP7PwAAAAC7EBqAkPj9P0B5+z+w+P0/ AAAAAFUVAAD+AAAAAAAAAP////+Q+P0/AQAAALD4/T+Mefs/AAAAAJR5+z8BAAAA AAAAALD4/T+0Q/w/2EP8P/////8AAAAAFgAAAP///38AAAAA4Pj9PwAAAAAAAAAA AQAAAAAAAAAAAAAAAAAAAAAAAADUQ/w/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAADs+P0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA= ZBr+P8AY/j9cGv4/ wBj+P/AZ/j/d0bJoNCv+P6h5+z9kGv4/pE78PwMAAAB4/P0/ePz9P2Qa/j9w/P0/ FgAAAGAQ/j9oY2lIb3N0VADU4YtKhmEAAAAAAFwa/j8AAAAAIQAGABYAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJVimg== xDIIQCSlCEAwAgYADFgZgIAZ/j9M/P0/wBn+P5j8/T8AAAAAoPz9PwAAAAAkpQiA YBn+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAABkAAAAAAAAAAAAAADSZCUBimQlA AAAAAL00CEAAAAAASMAIQGR0+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAEyf/D8AIAAAACEAAAAAAAAAAAAAwBn+PwSf/D8AAAAA AAAAAFUVAAD+AAAAAAAAAP/////AGf4/DJ/8PwAAAACY/P0/AAAAAGD9/T8AAAAA AAAAAPAZ/j8AAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/Bn+PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA== LCv+P5Ap/j8kK/4/ kCn+P8Aq/j+EX/5KNDP+P2wa/j8sK/4/pE78PwQAAAA8Hf4/PB3+Pywr/j80Hf4/ FQAAACgh/j9oY2lINFQAnwtntuWe97YAAAAAACQr/j8AAAAAIQAGABUAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIZvkQ== xDIIQCSlCEAwAgYAiOEZgFAq/j8QHf4/kCr+P1wd/j8AAAAAZB3+PwAAAAAkpQiA MCr+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAADSZCUBimQlA AAAAAL00CEAAAAAASMAIQDSF+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAA4AAAAMn/w/Drf7P/8AAAAAAAAAkCr+P1Si/D8AAAAA AAAAAFUVAAD+AAAAAAAAAP////+QKv4/VKL8PwAAAABcHf4/AAAAAPQe/j8BAAAA AAAAAMAq/j8AAAAAAAAAAAAAAAAAAAAADrf7P/8AAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzCr+PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAA= LDP+P9BT/j9oVf4/ 0FP+PwBV/j/erP08AH77PzQr/j8sM/4/pE78PwUAAADgL/4/4C/+Pywz/j/YL/4/ FAAAAGxD/j9idHVUAAt2of6AkjFVkmUAAAAAAGhV/j8AAAAAIQAGABQAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAESBlw== xDIIQCSlCEAwDAYA5HAYgJBU/j+0L/4/0FT+PwAw/j8AAAAACDD+PwAAAAAkpQiA cFT+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAACAAAAAAAAAAAAAAAJxJGUCqSRlA BwAAAL00CEAAAAAASMAIQHSv+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAQAAADgV/4/hAL9PwAAAAAAAAAA0FT+P0ii/D9sekI/ AAAAAFYVAAD+AAAAAAAAAP/////QVP4/mHEYQGx6Qj8AMP4/AAAAAOgw/j8AAAAA AAAAAABV/j8AAAAAAAAAAAIAAADoePs/CgAAAHw4CEAAFwAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADFX+PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA +H37P8AO/j9YEP4/ wA7+P/AP/j9zW7NxHE/9PzQz/j/4ffs/pE78PwYAAADse/s/7Hv7P/h9+z/ke/s/ EwAAAFwE/j9CdGNfdGFzawCnT4z6m00AAAAAAFgQ/j8AAAAAIQAGABMAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/XIw== xDIIQCSlCEAwAAYAoNcXgIAP/j/Ae/s/wA/+Pwx8+z8AAAAAFHz7PwAAAAAkpQiA YA/+PwAAAAD/////HFH8PwAAAAAEGfw/AQAAACAAAAACAAAA2Ff+PzSZCUBimQlA /////700CEAAAAAASMAIQGRq+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAANhX/j8THwAA/gAAACAEBgAAAAAAwA/+Pwyd/D8AAAAA AAAAAFYVAAAAAAAAAAAAAP/////AD/4/DJ38PwAAAABQeEI/AAAAACx8+z8AAAAA AAAAAPAP/j8AAAAAAAAAAAFJAgAYV/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/A/+PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA FE/9P5Cr/T9Irf0/ kKv9P+Cs/T8DPNcnVLP9PwB++z8UT/0/pE78PwUAAAAgm/0/IJv9PxRP/T8Ym/0/ FAAAAEyh/T9ldmVudFRhc2sAvtxfICUAAAAAAEit/T8AAAAAIQAGABQAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIBZKw== xDIIQCSlCEAwCAYA6DkUgFCs/T/0mv0/kKz9P0Cb/T8AAAAASJv9PwAAAAAkpQiA MKz9PwAAAAD/////HFH8PwAAAAAEGfw/AQAAAAAAAAAwrP0/PKz9PzSZCUBimQlA AAAAAL00CEAAAAAASMAIQFQH+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATCupC0AAAAAkKz9P2yQ/D8AAAAA AAAAAGNnBgD+AAAAAAAAAP////+QrP0/bJD8PwAAAABAm/0/AAAAAPic/T8AAAAA AAAAAOCs/T8AAAAAAAAAABAAAABgAwiOhKYBPywJvD9AAAAAAAAAAHwQ/T///z+z /gAAAPgKvD9w5wMA9Aq8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAADsrP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA= TLP9P6DK/T+4zP0/ oMr9P1DM/T/8acAAoFH7PxxP/T9Ms/0/pE78Pw4AAAB8rf0/fK39P0yz/T90rf0/ CwAAALy0/T9JUlFzAKWlpaWlpaWlpaUAAQAAALjM/T8AAAAAIQAGAAsAAAAAAAAA AAAAAOzL/T8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ== xDIIQCSlCEAwAgYAT4AOgGDL/T9Qrf0/AMz9P5yt/T8AAAAApK39PwAAAAAkpQiA QMv9PwEAAAD/////IFH8PwEAAAAEGfw/AAAAAAYAAACS1JU/5K39PzSZCUBimQlA /////700CEABAAAASMAIQMQm+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAHqADoCAy/0/wEKVP1CxQD/M0A2AoMv9Pwhd/D8AAAAA AAAAABRmwAAAAAAAAAAAAP////+gy/0/CEMOQAAAAAAAAAAAIMz9P8jL/T8gzP0/ AAAAADDM/T/8XPw/AAAAAAAAAAAAAAAAzNANgKDL/T8AAAAAAAAAAIBe/D8AAAAA CgAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAADDM/T/8XPw/AAAAAG+ADoCAXvw/ gF78PwAAAAAAzP0/ABQAAAhDDkDAQpU/AAAAAAAAAACAXvw/AAAAAAoAAAD///9/ AAAAAFDM/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAAAAABczP0/AAAAAIAAAAAAAKBAAOoDQAAAIEFkAABL+Ci8v4b/PDVOJi4/ AMCfP/I2pToAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA= mFH7PwBQ+z+QUfs/ AFD7PzBR+z9qrsXTzBz9P1Sz/T+YUfs/pE78PwQAAAAIR/s/CEf7P5hR+z8AR/s/ FQAAAJRH+z9wbVQAUU6VezP89OEXWo4A////f5BR+z8AAAAAIQAGABUAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPR3+Q== xDIIQCSlCEAwBAYAyT0SgMBQ+z/cRvs/AFH7PyhH+z8AAAAAMEf7PwAAAAAkpQiA oFD7PwEAAAD/////IFH8PwEAAAAEGfw/IwAGAAAAAAAzMzMDvTQIQDSZCUBimQlA /////700CEABAAAASMAIQKSr+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAADoAwDQUPs/PHf8PyAABgAAAAAAAFH7PzB2/D90iUE/ AAAAAARZ2QAwdvw/dIlBP/////8AAAAAAAAAAAAAAACYUfs/AQAAAP4AAAABAAAA AAAAADBR+z8AAAAAAAAAAAYAAAADAAAAAAAAAAAAAABsd/w/MHb8PywBAAAAAAAg AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFH7PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAA== xBz9PzAb/T+8HP0/ MBv9P1Ac/T8+eL7qYNj7P6BR+z/EHP0/pE78PwMAAAAkU/0/JFP9P8Qc/T8cU/0/ FgAAAMAQ/T9lc3BfdGltZXIAFB/KKREAAAAAALwc/T8AAAAAIQAGABYAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGyOkg== xDIIQCSlCEAwCAYATSMNgPAb/T/4Uv0/AAAAAERT/T8AAAAA+FL9PwAAAAAkpQiA 0Bv9PwAAAAD/////HFH8PwAAAAAEGfw/XD/9PwAAAAD//z+zAAAAADSZCUBimQlA /////700CEAAAAAASMAIQMR2+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAABxR/D8AAAAABBn8P1w//T8AAAAAMBz9P6xN/D+0Tfw/ AAAAAElZ2QAqIAIAXD/9P/////8wHP0/yFj7P7RN/D9EU/0/AAAAAPhS/T8AAAAA AAAAAFAc/T8AAAAAAAAAAAAAAAAAAAAAtE38PwAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAABcHP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA WNj7P7DW+z9Q2Ps/ sNb7P/DX+z/CTRtVoNn9P8wc/T9Y2Ps/pE78PwIAAADowfs/6MH7P1jY+z/gwfs/ FwAAAFTI+z93aWZpAKTDvEt7T8Ejq5EAAAAAAFDY+z8AAAAAIQAGABcAAAABAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOAr2Q== xDIIQCSlCEAwBgYAnGkSgHDX+z+8wfs/wNf7PwjC+z8AAAAAEML7PwAAAAAkpQiA UNf7PwAAAAD/////HFH8PwAAAAAEGfw/CgABBBwAAAC9FxKAUNf7PzSZCUBimQlA /////700CEAAAAAASMAIQGQy+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAGhqEoCA1/s/BAAAAKDqEEAAAAAAsNf7P8C3/D+Ad/w/ AAAAAEtZ2QDAt/w/gHf8P/////+w1/s/wLf8P4B3/D8QAAAAxAAAAABU+z/kKPw/ AAAAAPDX+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAA GgAAAGNqEkBYi0E/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPzX+z8AAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA= mNn9PzCo/j/0q/4/ MKj+P5Cr/j95WdkArFL8P2DY+z+Y2f0/pE78PxQAAADAUvw/FGD8P5jZ/T8MYPw/ BQAAAPiX/j9NUFRocmVhZABsAG8AZwAAAQAAAPSr/j8AAAAAIQAGAAUAAAABAAAA AAAAACyr/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAi0ADw== xDIIQCSlCEAwDAYAmNENgPCo/j/oX/w/AAAAADRg/D8AAAAAAAAAAAAAAAAkpQiA 0Kj+PwEAAAD/////IFH8PwEAAAAEGfw/BQAAAB4AAAD//z+zAAAAABibCUAjmwlA AAAAAL00CEABAAAASMAIQAQG/D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAQZ/D8FAAAA/gAAAAEAAABUsw+AMKn+P+Rf/D8BAAAA AAAAAH9Z2QAAAAAAAAAAAP////8AAAAAAQAAAAAAAAA0YPw/AAAAAAEAAAAAAAAA 3UQPgFCp/j/kX/w/cEWVPwAAAAABAAAAAQAAAJ4UAAB0Dg+AcKn+PySzD0ABAAAA AQAAAJAwlT8AAAAAIwAGANwOD4Cgqf4/mM5APwEAAADcDg+AoKn+PxibCUAjmwlA AAAAAHBFlT8BAAAAHgUAACW6D4DAqf4/AAAAAAAAAAAAAAAAcEWVPwEAAACqFAAA Z0UPgOCp/j9sRZU/hdCVP2xFlT8hAAAAAwAAAAEAAAB0Dg+AgKr+P4Be/D+AXvw/ 4Kr+P1ALlT9nRQ+A4Kn+P+Cq/j9kRZU/UAuVP8RFlT/J0JU/kgAAAAUAAAAAAAAA paWlpaWlpaV0Dg+AgKr+P4Be/D+AXvw/9rQPgBnQlT8OAAAABAAAAMRFlT8AAAAA AAAAAEBFlT+URZU/kEWVPw0AAADo+JQ/AQAAAAAAAABkRZU/AAAAADD///+QMJU/ frIPgMCq/j/QDZU/AAAAAALQlT8AAAAAAAAAAAAAAAAAAAAA6PiUPwAAAAAAAAAA QEWVP4AAAAAOAAAAgKr+P8zQDYDgqv4/AAAAAND4lD8AAAAA6PiUPwir/j9gq/4/ AAAAAHCr/j/Q+JQ/AAAAAAAAAAAAAAAAzNANgOCq/j8AAAAA0PiUPyMABgAAAAAA BAAAAP///38AAAAAAAAAAAAAAAAAAAAAAAAAAHCr/j/Q+JQ/AAAAAG2yD4CAXvw/ gF78P+Cp/j9Aq/4/ABAAAND4lD8AAAAAAAAAAAAAAADQ+JQ/AAAAAAQAAAD///9/ AAAAAJCr/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAABAAAAAACcq/4/AAAAAIAAAAAAAMhCzczMPQAAekR4/1Yy2w9JwHj/VjKD+aJW AMCfV91L5bkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAA== pFL8PzCU/T+8l/0/ MJT9P1CX/T9/WdkArE78P6DZ/T+kUvw/pE78PxQAAAAUYPw/tNn9P6RS/D8MYPw/ BQAAAMBn/T9NaWNyb1B5AAAAAAAAAAAAAQAAALyX/T8AAAAAIQAGAAUAAAAAAAAA AAAAADxe/D8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA== xDIIQCSlCEAwDgYAmNENgPCU/T/oX/w/AAAAADRg/D8AAAAAAAAAAAAAAAAkpQiA 0JT9PwEAAAD/////IFH8PwEAAAAEGfw/BQAAABoAAAAwlf0/f1nZAAGeCUARnglA /////700CEABAAAASMAIQMTx+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAP////+9NAhAAQAAAEjACEBI1Q2AMJX9P+Rf/D8BAAAA AAAAAH9Z2QAAAAAAAAAAAP////8AAAAAAAAAAAAAAAA0YPw/AAAAAAEAAAAAAAAA stUNgFCV/T8BAAAA5F/8PwAAAAABAAAAAwAAACMABgB42g2AcJX9Pzxe/D/MIUA/ wJX9PwAAAAAAAAAAAAAAAJbcDYCglf0/wJX9P5IeQD+W3A2AoJX9P8CV/T+SHkA/ AAAAAAAAAAAAAAAAAgAAAODMDYDAlf0/AAAAAAAAAAAGAAAAAAAAACIAAAAIAAAA AAAAAACW/T8Qlv0/LBr8PyAAAAAAAAAA4PmUPwgAAAAAAAAAAJb9PxCW/T8AAAAA kJX9PwAAAAAAAAAApFr8PwAAAABQl/0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl nwIAACEABgAgQk9PVC5QWQD//////2Jvb3QucHkA//////////////////////// //////////////////////+lpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaXEMghA6MkNQDAABQAAAAAA UJf9PwAAAAAA//////////////////////////////////////////8AAAAAAAAA AAAAAAEAAAAAAAAA/////wAAAAD/////////////////////xUITgQAAAAAyAAAA AgEAAAAAAAAAABkAAJb9PwAAKAAAAAAAAQAAAAiX/T/Qlv0/AAAAAAAAAAAAAAAA AQAAAExU/D8AAAAAYR1APwAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAFyX/T8AAAAA gAAAAACAO0UAAEBAAAB6RADESLKAlhjAMKGzNZW/1j4AwLc/AJaZugAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA= cCL9P+Ag/T9oIv0/ 4CD9PwAi/T8N2Sdf7Cf9P6xO/D9wIv0/pE78PwEAAADoVP0/6FT9P3Ai/T/gVP0/ GAAAAGwe/T9pcGMwAN7bVrWuBUWam44AAAAAAGgi/T8AAAAAIQAGABgAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACfgUQ== xDIIQCSlCEAwAgYA/BwIgKAh/T+8VP0/AAAAAAhV/T8AAAAAvFT9PwAAAAAkpQiA gCH9PwAAAAD/////HFH8PwAAAAAEGfw/FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAL00CEAAAAAASMAIQHR8+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAABxR/D8AAAAABBn8PxcAAAAAAAAA4CH9PwBO/D8AAAAA AAAAAEgUAAD+AAAAFwAAAP////8AAAAAAE78P/BN/D8IVf0/AAAAALxU/T8AAAAA AAAAAAAi/T8AAAAAAAAAAPRKCEAAAAAAAAAAAAAAAADFEQiAYDz+P4xO/D+UTvw/ AAAAAAAAAAAMIv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAA= ================= CORE DUMP END ================= Rebooting...
Can you post the complete core dump so we can decode and discover where the error is coming from?
anyone?
any tip to get me further is welcome.
