    Pytrack - name 'machine' is not defined
    pytrackgpslopy
    10 Posts 3 Posters 2.3k Views 3 Watching
      stefan85e
      Re: Pytrack usage?
      I got this when I try to upload the code: I use this one:
      https://github.com/sandyjmacdonald/lopy-gps-maps
      but the problem I have is with the (lopy-receiver.py) part of the code
      I try to formate the code so its easy to read but I fail on that part.
      import _thread
      import utime
      from machine import WDT
      from machine import RTC
      from network import LoRa
      Set RTC for timestamping (although it's not currently used)
      rtc = machine.RTC()
      rtc.ntp_sync("pool.ntp.org")
      utime.sleep_ms(750)
      print("\nRTC Set from NTP to UTC:", rtc.now())
      utime.timezone(7200)
      print("Adjusted from UTC to EST timezone", utime.localtime(), "\n")
      Set up the LoRa in longer range mode
      lora = LoRa(mode=LoRa.LORA, frequency=868000000, tx_power=14, bandwidth=LoRa.BW_125KHZ, sf=7)
      l = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
      l.setblocking(False)
      Set up web socket
      wdt = WDT(timeout=5000)
      addr = socket.getaddrinfo("0.0.0.0", 80)[0][-1]
      s = socket.socket()
      s.settimeout(1)
      s.bind(addr)
      s.listen(1)
      print("listening on", addr)
      Threaded server
      def _serve():
      wdt.feed()
      method, route, proto = None, None, None
      ts = utime.time()
          try:
              cl, addr = s.accept()
          except OSError:
              continue
          print("client connected from", addr)
              try:
                  line = cl.readline()
                  print(line)
                  ## Only handle GET requests
                  if line[0:3] == b"GET":
                      method, route, proto = line.split(b" ")
                  if not line or line == b'\r\n':
                      break
              except MemoryError:
                  cl.send(" ")
                  cl.close()
                  continue
          ## Boilerplate JSON response
          response = """HTTP/1.1 200 OK
      Access-Control-Allow-Origin: *
      Cache-Control: no-cache
      Pragma: no-cache
      Content-Type: application/javascript\r\n\r\n{
      "position": {
      "latitude": %f,
      "longitude": %f
      "message": "%s",
      "timestamp": %i
          ## Crude hack to handle URL routes
          if route is not None:
              route = route.split(b"/")
              route.pop(0)
              print(route)
              ## If position.json is requested then receive LoRa message from sender
              if route[0] == b"position.json":
                  msg = l.recv(64)
                  ## Decode and split out into latitude and longitude
                  if not msg == b"":
                      msg = msg.decode("utf-8")
                      lat, lon = [float(i) for i in msg.split(",")]
                      response = response % (lat, lon, "success", ts)
                      print(response)
                  ## Otherwise, send 404
                      response = """HTTP/1.1 404 Not Found
      Pragma: no-cache
      print(response)
              ## Handles missing routes by sending 404
      Pragma: no-cache
          cl.send(response)
          cl.close()
      Start the thread
      _thread.start_new_thread(_serve, ())
        robert-hh @stefan85e
        @stefan85e said in Pytrack - name 'machine' is not defined:
        rtc = machine.RTC()
        You did not import machine. So this line should read:
        rtc = RTC()
          stefan85e @robert-hh
          @robert-hh So what should I do then!?
          I added the lib machine.py and did try upload it
          • X Offline
            Xykon administrators @stefan85e
            You shouldn't try to upload a machine.py because machine is a built-in micropython module. https://docs.pycom.io/chapter/firmwareapi/pycom/machine/
            I suggest you try @robert-hh's suggestion to replace rtc = machine.RTC() with rtc = RTC()
            Christian Ehlers
              stefan85e @Xykon
              @xykon
              When i change that I get this:
              The time is wrong... Its from 1970 :)
              • X Offline
                The RTC holds the time since January 1st 1970... that's just how the RTC works.
                In the Pytrack demo code we have the following:
                rtc = machine.RTC()
                But if the module can't connect to pool.ntp.org it cannot set the time. Make sure that your module can reach the ntp server.
                Christian Ehlers
                  stefan85e @Xykon
                  @xykon om using a pytrack how do I know how to do that?
                  • X Offline
                    @stefan85e You would most likely connect to a router to have an internet connection which allows you to connect to pool.ntp.org
                    Of course you can also set the time manually using rtc.init
                    Christian Ehlers
                      stefan85e @Xykon
                      @xykon said in Pytrack - name 'machine' is not defined:
                      rtc.init
                      rtc = machine.RTC()
                      rtc.init((2014, 5, 1, 4, 13, 0, 0, 0))
                      print(rtc.now())
                      thats a way to do it, but I dont want to set the time my self :)
                        @stefan85e Having Pytrack AND Wifi, you have two sources for the time:
                        a) a NTP server. For that you have to espablish an internet connection. Look at the documentation & examples for WiFi and Internet access, Section https://docs.pycom.io/chapter/tutorials/all/wlan.html, heading: "Connect to a router".
                        b) GPS. This is a little bit more tricky, since easy to use examples are missing. You can at least use the examples from thy Pytrack existing library and use that to derive the time information.
